foreman1063
Everything posted by foreman1063
  1. Ok, thanks for the input. I was hoping for more of a plug and play scenario but guess I'll have to roll up my sleeves and get to work.
  2. Needs to be from a 91 or 92, MPI 2.5L truck. Thanks
  3. Any body here done a similar swap. I'll have the motor with all accessories, fuel injection, computer and harness. Any thoughts on how difficult it will be tying the newer harness and computer to the older MJ?
  4. Looks like a nice kit but I'd have a hard time sinking $1300 into a d30.
  5. I've had good luck with a punch and a hammer
  6. Image Not Found
  7. Nice job swinging those forms, looks like you've done it before.
  8. Either list it for room to go down to a price that the buyer thinks he's getting a steal or list it at a good price to start with (like it sounds like you do) and say firm, no negotiations. Then don't respond to low ball offers.
  9. Very nice write up! Just FYI, I made a little slide hammer to remove the pivot pins. Worked like a charm and cost $0.
  10. I'll be there in late April with my TJ. That's when we go every year and the weather, on average is beautiful.
  11. Hmm, works for me but try this. http://www.ironman4x4fab.com/Products/TB.html
  12. Check out these as well.
  13. I've been looking for that.
  14. Nice, set it as the wallpaper on My Galaxy III
  15. Good luck with the addition.
  16. Pour the concrete right up against the panels, just put some six mil plastic between the panel and concrete to form a break. Also remove any screw that will be below the concrete and you will be able to remove the panels later if it becomes necessary.
  17. What vehicle/year is the 60 in? Have you checked Rock Auto?
  18. Maybe CLR would do it.
  19. foreman1063
    Mj Smiley
    . :MJ 1: . I wanna do it
  20. Absolutely, needs to be cleaned first, I had one done on an old land cruiser that held up fine. Before I spent to much though, I would find junk case on cl or in the junk yard and use the housing to replace the cracked one.
  21. Get someone to TIG weld the crack.
  22. I think he's saying that nothing in the new cluster is working, probably a bad cluster.
  23. Probably picked up a bad gauge cluster from the jy.
  24. Yeah, how about some pictures slacker. :D Sorry I wasn't much help yesterday, was on the trail riding most of the day and didn't get to check my phone very often. Let me know if you need a hand with your gauges or turn signals.
