&%#$* Transfer Case
It would appear the friggin' transfer case is popping.
Chain perhaps?
Did it a year or so ago.  Got one out of a junkyard and now this one is doing it.
How new of a 231 can I put into this thing?
What fits?
I don't want to get another "old" one again and have it last only a year.
What is this popping sound your talking about?
I've been trying to diagnose a popping noise when I let go off the clutch....
I'm thinking it may be my clutch..I've checked u-joints and they're good...but after reading This thread I may have to put it up on jackstands to check it out....
It instantly happen when let off the clutch to accerlarate after first gear...
I would assume he only gets the popping sound when 4WD is engaged?    Thats why he is thinking TC
I have heard that sound many times myself..........like mentioned above the chain (once the T-case is out) is about a 40 minute repair  :thumbsup:
Chain perhaps?
What fits?
Even if you get one out of a 2001 XJ (which will have the new-style, inferior, vibration-prone output shaft), it will be 13 years old. Why not just put a chain in the one you have?
  • 1 month later...
Just an update. Bought a chain on ebay. Installed pretty easily. Frankly removing the tcase from the truck was the hardest part. Sat on the workbench for a bit as other things got done first. You know how that is. Reinstalled this past weekend. All is good.
now back to the brakes. :)
When I installed a heavy duty slip yoke eliminator (for which you have to get into the case just a little bit deeper than just replacing the chain), I did it under the truck; didn't bother to take the case out from under, or even unbolt it from the transmission. Jacked up the truck, set a transmission jack under the cross member, unbolted the cross member from the frame rails and lowered it down a few inches.
