Location
North Georgia Mountains
902 profile views
hillbilly51's Achievements
Comanche Fan (3/11)
Hi !
There's no pictures anymore on this topic :Is it possible for you to update this or send it to me ?
I really need this 'cause I've got troubles with my NP231 linkage!Thanks in advance !
Weird Issues With Dana 30 In The Front....
hillbilly51 replied to BootsNTrucks's topic in MJ Tech: Modification and Repairs
That is a caged needle bearing (yes it's steel). It supports the inboard end of the stub shaft. The bearing is a SCE 108 and the inner seal is a SKF 15843 (or comparable) -
Hey I need to do some PM on my 88 Comanche Chief 4.0L 5 speed Peugeot. Dana 30 Axle with Central Axle Disconnect. Is there a opinion on the best Crank Position Sensor? Airtex/Wells? Standard Motor Products? Dorman?...Other? Also, I need to fix a oil leak on the right front axle. I believe the needle bearing on the spindle shaft has failed, and has caused the inner seal to fail. This is on the Central Axle Disconnect system. Anyone have the part numbers for the bearing and seal? Will a Timekin SBK-1 Bearing/Seal kit fit this truck? Also, does anyone make a kit that is used to convert the closed cooling system to a open system? Any good write up's on this subject? One with a Radiator Cap that eliminates the plastic jug? Thanks a lot for any response
This is a picture of the NP231 shifter that I made for my 88 Comanche Chief. I've had in in the truck for over a year and haven't had any problems. Works perfectly . I've got detailed sketches if anyone is interested in building one. Some welding is required. Most of the parts are from the original shifter......with modification
Me too. I just installed a new thermostat on my 88 Comanche 4.0L the other day, and that is exactly what I did. I didn't have any problem at all burping the system. On the 80's models 4.0 engines, the closed loop cooling system with the pressurized expansion tank can be a real pain in the a** when trying to get air out of the cooling system. This simple modification helps a lot.
How Bad Really is the BA10?
hillbilly51 replied to joester1908's topic in MJ Tech: Modification and Repairs
My 88 Comanche Chief 4.0L has 133K miles and is on it's third BA10/5. I've never driven this truck hard and have always maintained the gear oil. The first transmission to break was when the truck had about 90K miles. The symptom was a "click, click, click,click" when my wife started the truck and drove it down my driveway. I knew that the noise was internal to the transmission so I pulled it and took it apart for inspection. Some how, or for some reason, one of the first gear teeth on the main cluster was broken off. The inside of the transmission looked pristine. I priced a new cluster gear, but decided to simply replace the transmission. I've still got that transmission and may get around to fixing it one day. I bought a used replacement on E-***, but it was a couple of months before I installed it. I should have checked the oil when I received the gear box, but I waited until I had it installed. When I did check it, about a cup full of water and black oil came out....that was all. The transmission had several bearings that were grinding, and always made a noise until it failed. I did get about 25K miles out of it though. The transmission that I now have was bought at a local junk yard and was guaranteed to be good. It has been, and still shifts smoothly and runs quietly. This time, I replaced the clutch with a new Luk kit. That said, I will never replace it again. I will make the change to the AX-15 with the external slave cylinder if it ever needs replacing. All in all, if you don't abuse the transmission and run recommended tire sizes, the BA10 performs pretty well. hope this helps -
Goodyear Gator Back belt squeal
hillbilly51 replied to hillbilly51's topic in MJ Tech: Modification and Repairs
That's a good idea, I'll give it a try. I'm also gonna inspect the Harmonic Balancer. The only problem is that I have to remove the steel belly pan on my 88 Comanche Chief to see it. -
I recently replaced the serpentine belt on my 88 Comanche Chief 4.0L. I got a really good deal on a Goodyear Gator Back belt, and my old one was looking bad. Since then, I have had a problem with the belt squealing at all engine speeds. I have tightened it to what I consider excessive tightness and it still sings like a bird. I determined that the noise is coming from the water pump pulley which is driven by the back of the belt in this application. I replaced my engine thermostat yesterday (from 180 to 195 degrees F) and loosened the belt to have easy access to the bottom thermostat cover bolt. Since I've re-tightened the belt it's even louder than before. I loosened the belt so that I could spin all of the pulleys by hand and everything feels smooth. All of the bearings feel snug and rotate freely without any noise. The water pump turns freely by hand and there is no noise or movement in the shaft. The alternator is charging fine and the power steering is smooth. So is the A/C clutch bearing and the belt idler bearing. With the engine running, I sprayed some belt dressing on the belt and it immediately quieted down only to start squealing again in a minute or so. Has anyone else had a problem with this particular belt? Am I missing a potential bearing failure on the water pump or other component? This truck only has 133K miles and as far as I know, it's the original water pump and idler. I'm gonna order a new pump and idler so that I'm ready if it does fail. Any response is appreciated.
Loud Roar from Underside
hillbilly51 replied to Slimjater's topic in MJ Tech: Modification and Repairs
I've experienced "Death Wobble" a few times in my 88 Comanche Chief, and I know what it is like. Almost a life changing experience. It reared it's ugly head one time when I was on the freeway pulling a trailer with a yard tractor on it. 60 mph in the right lane on a long sweeping curve to the left....this with a transfer truck immediately on my left. One bump in the pavement and away it went. I thought I was a goner for sure. Luckily, there was a right side safety lane and I was able to coax the truck over into the lane and slow down until it stopped.. It's scary as he** if you're in a tight spot. -
Could it be the dreaded "Death Wobble"? You need to read about it. Search this forum. -
They are readily available aftermarket from various sources. Google... Fuel Line Repair Kit 83502745
My 88 Comanche with the D30 Dana front transaxle w/axle disconnect...has developed what I first assumed to be a wheel bearing noise. It's very noticeable when I turn the truck to the left and quiets down when I turn to the right. Otherwise, I hear a sound like a failed bearing all the time. It's not loud when I'm steering straight, but it's definitely still there. The noise is like a tire is going flat. I pulled both front hubs and checked the bearings. Both bearings are still snug and turn smoothly, and I don't believe that's the trouble. When I pulled the right front hub, the axle came out with it. Is that normal? or am I having a problem back at the axle disconnect. It seems like there should be something holding the axle in place...besides the wheel hub. I notice that Jeep didn't put a outboard bearing on the right side axle and that was suprising to me. I've had a small oil leak from behind the oil slinger where the axle shaft comes out of the axle housing. Should gear oil be in that area, or do I have a seal leaking inside? I thought that the axle disconnect was lubed by axle grease that's added behind the axle shift plate. Could the noise be coming from the caged needle bearing that supports the axle shaft outboard the axle disconnect? If I can't find the source, I'm going to start replacing wheel hubs, and work down from there. Any ideas? Thanks for any response. steve
The way that you describe it, it sounds like a explosion inside the oil sump. The only thing that would cause that would be gasoline in the oil . I'm just speculating because I'm not saying that's what happened or that I've ever seen it. It also could have been a backfire in the muffler, so I would check the exhaust system too. If the distributor housing is truly broken and not just the cap, something went wrong in a big way. Just curious....Have you looked under the engine to see if the oil pan is still intact?
Well, I finally checked my coolant temperature. I'd been driving the truck for about 20 miles and the engine was fully warmed up. Gage showed around 110 degrees. Coolant temperature with the engine running and coolant flowing thru the plastic resevoir...180 degrees. So I have a operational 180 degree thermostat in the engine. I checked the temp. sender and it was defective. Question. Will the Renix System run in closed loop at 180 degrees engine temperature or do I need to increase the temp to 195 degrees? The engine runs very well right now. Is there a way to check if the computer is running in closed loop. Oh yea.....Since I installed the Volvo fuel injectors my fuel economy has risen 9 MPG....checked it twice. The additional power is truly impressive. Feels like I'm driving a sports car. steve
