CGCWO Posted January 18, 2015 Share Posted January 18, 2015 Found original owner manual, registration from the three other owners, warranty booklet in the glove box of mine. Owners manual was still in original plastic, at least what was left of it. Link to comment Share on other sites More sharing options...
benjy_26 Posted January 19, 2015 Author Share Posted January 19, 2015 I know y'all like action pics, so here goes: I know...it's not ultra-mega-hardcore rock krawling, but it's fun to go dune blasting. :) Link to comment Share on other sites More sharing options...
benjy_26 Posted February 3, 2015 Author Share Posted February 3, 2015 Some progress: I purchased a Boostwerks Ultimate steering brace kit, as well as a 21 spline input np231 off of an 88 4.2 YJ (anyone need a low mile BA10/5?) and a 97 AX5 with 60,000 miles on it. Those should fit together, right? Anyway, I also need to get some front u joints, have my rear shaft shortened, purchase a front DS, anda drive flange for my 8.8 and I can make my SporTruck a 4x4. Oh, I also purchased (on a whim) a ZJ steering box to begin my p/s conversion. Meanwhile... Link to comment Share on other sites More sharing options...
xjrev10 Posted February 10, 2015 Share Posted February 10, 2015 Looking good! Love me a white MJ but I might be a little biased!! Link to comment Share on other sites More sharing options...
benjy_26 Posted February 11, 2015 Author Share Posted February 11, 2015 Thank you, sir! I have to agree, there's just something about a white MJ! Link to comment Share on other sites More sharing options...
CGCWO Posted April 5, 2015 Share Posted April 5, 2015 Looking good! I have a couple of questions for you regarding your 3" lift. I have 1.75" coil spacers now and I am planning on going to 2" lift coils with spacers or 3"coils without spacers. Did you have to use longer shackles or an AAL to get keep it pretty close to level? I really do not like the rake I had before the spacers and would like a little more level than it is now with them. I am only running 30 x 9.50s, but may go to 31 or 33 x 10.50s in the future. I prefer the taller skinny tire for looks and the fact I will be using it for mostly DD and occasional trips to the local lawn & garden. I don't need to convert to 4x4 and don't want to go any higher that 3" since ift may also see limited use for hauling my other toy (faired and bagged 2010 Vulcan 900 Custom). Link to comment Share on other sites More sharing options...
benjy_26 Posted April 14, 2015 Author Share Posted April 14, 2015 Thanks man. :) I appreciate the kind words. I actually left the rear end alone for now. I still have the stock 2wd SporTruck leaves with bigger shocks. I like it well enough and it clears the 31's just fine even with the high offset I'm running. I may go to metric tonne leaves just for more control while towing. Link to comment Share on other sites More sharing options...
Gatorgirl Posted January 15, 2016 Share Posted January 15, 2016 I sure like what you did with your Mj. I have 87 2wd 4 cy. 2.5 4 spd. Sportuck mine is beige. I'm the original owner. My gas tank fuel pump and sender all rusted out! Couldn't find a sender anywhere so went with a fuel cell and external fuel pump. I would like to put it back original, but don't know where to get a sender. Is your fuel system still original? Any idea where I can find a used sender, have checked all junk yards with no luck! Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 15, 2016 Share Posted January 15, 2016 You might want to check the classifieds for sale section. This might work depending on tank size: http://comancheclub.com/topic/49311-misc-items-oconomowoc-wi/ Link to comment Share on other sites More sharing options...
benjy_26 Posted May 11, 2016 Author Share Posted May 11, 2016 I sure like what you did with your Mj. I have 87 2wd 4 cy. 2.5 4 spd. Sportuck mine is beige. I'm the original owner. My gas tank fuel pump and sender all rusted out! Couldn't find a sender anywhere so went with a fuel cell and external fuel pump. I would like to put it back original, but don't know where to get a sender. Is your fuel system still original? Any idea where I can find a used sender, have checked all junk yards with no luck! Thanks! I'm having issues with my sender too. Hopefully I can find a clean used one. If not, I'll have to figure something out. Link to comment Share on other sites More sharing options...
benjy_26 Posted May 11, 2016 Author Share Posted May 11, 2016 Update: Haven't done much to the MJ, save for a bolt on bull bar, some LED pods, and maintenance. Oh, and I have been using the heck out of it! Link to comment Share on other sites More sharing options...
benjy_26 Posted May 11, 2016 Author Share Posted May 11, 2016 Link to comment Share on other sites More sharing options...
88whitemanche Posted May 11, 2016 Share Posted May 11, 2016 Sweet...good looking truck you got there! Link to comment Share on other sites More sharing options...
gogmorgo Posted May 11, 2016 Share Posted May 11, 2016 Your snow fields have an odd texture to them :D Kinda hard to tell in the tiny pics on my phone, but is that "bull bar" just the hoop part or is it the whole bumper? Either way it looks good, but now you need to get some lights up on that roof bar to match. Link to comment Share on other sites More sharing options...
benjy_26 Posted May 11, 2016 Author Share Posted May 11, 2016 Sweet...good looking truck you got there! Thanks! Link to comment Share on other sites More sharing options...
benjy_26 Posted May 14, 2016 Author Share Posted May 14, 2016 Two issues got adressed today: 1. Broken passenger side turn signal. 2: Got rid of the Arizona rake. Link to comment Share on other sites More sharing options...
daking Posted June 14, 2016 Share Posted June 14, 2016 When wore you at white sands? I have a home up near there, in Alamo. It's where I keep my toys, including my MJ. I need to take my MJ there for some photos. Best place to take black cars / trucks or white ones, the contrast makes the truck "pop" We need to get all the ELP guys and have a meet. There must be 4 or 5 here now. Link to comment Share on other sites More sharing options...
