johnny quest Posted December 30, 2013 Share Posted December 30, 2013 long story short, the previous owner stripped the interior out and gave me a coffee can full of rusty bolts. What size bolts do i need to attach the seatbelts to the interior? the reel is in place, it is just the other 2 bolts that need to be bolted down. ive found answers to what size torx bits will remove them (either t45 or t50), but id much rather put in some hex heads back in there. thanks! Link to comment Share on other sites More sharing options...
Oyaji Posted December 30, 2013 Share Posted December 30, 2013 Since seatbelt anchorages are a safety item (they even have their own regulatory standard for Europe, I am unsure about USA standards though), it is important to match the dimensions and qualities of the bolts used in every way in order to have confidence in them. Not only threaded length, shoulder length, head area and shape, but also hardness and maybe other things too are important considerations. Because of this and the fact that you wouldn't expect to remove them very often prompts me to suggest it would be best to just re-use the originals. Link to comment Share on other sites More sharing options...
johnny quest Posted December 30, 2013 Author Share Posted December 30, 2013 this is true. seatbelts are one of the most crucial safety areas. however, I don't have those bolts. I guess my original post was vague; the coffee can of rusty bolts was terribly incomplete. I have been using grade 8 bolts wherever strength has been important, and this is one of those areas. I found one post that mentioned that these were 7/16ths bolts, but have not been able to find anywhere else that confirms that measurement. Link to comment Share on other sites More sharing options...
Eagle Posted December 30, 2013 Share Posted December 30, 2013 I believe the seatbelt bolts are special. The threaded portion is smaller in diameter than the smooth portion of the shank, so when the shoulder of the bolt bottoms out the belt can rotate around the shaank. I don't think you'll find them in a Sears hardware store. Try a junkyard, or Comanche Club member. Link to comment Share on other sites More sharing options...
1987Comanche Posted December 30, 2013 Share Posted December 30, 2013 The bolts have a T-50 head. Not sure if standard or metric but I have a few rolling around in the basement. The unthreaded portion of the bolts will be difficult to match up as this area allows the seat belts to pivot/rotate. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 30, 2013 Share Posted December 30, 2013 To answer your question, these are the bolts you need. Depending on the condition of the anchor nuts, you may need to use a thread chaser (not tap) to clean them up. http://www.oconeeoffroad.com/servlet/the-37313/S-dsh-6034457-omix-dsh-ada-BOLT-7-fdsh-16X1.375/Detail http://www.cyberjeep.com/xj/pr/seat-belt-bolt-spaced-716-x-1375 And elsewhere. Link to comment Share on other sites More sharing options...
Keyav8r Posted January 5, 2014 Share Posted January 5, 2014 Egad! $15 for a seat belt bolt! Those CyberJeep guys must be planning on retiring early. Take a T-50 Torx bit (1/2" drive ratchet will give you more leverage) with you to a JY. Find an XJ and pull them out. They're a little harder to get to if the seats are still in the Jeep, but not so hard it can't be done. Someone on the Forum refers to these type items as "pocket parts", not that I would know what that means. Link to comment Share on other sites More sharing options...
Blue XJ Posted January 5, 2014 Share Posted January 5, 2014 Torx head shouldered 7/16" fine thread bolts. Good luck finding replacement ones in a store, maybe McMaster sells them, but make sure you get the correct grade. Link to comment Share on other sites More sharing options...
Mattwheels Posted January 5, 2014 Share Posted January 5, 2014 I'll take a look in my XJ parts car and see if I don't have a couple in there Link to comment Share on other sites More sharing options...
64 Cheyenne Posted January 6, 2014 Share Posted January 6, 2014 I'm not sure, but I think the length of the shoulder is different between the mount locations eg: F/side, retractor mount and static end. Link to comment Share on other sites More sharing options...
Blue XJ Posted January 6, 2014 Share Posted January 6, 2014 I'm not sure, but I think the length of the shoulder is different between the mount locations eg: F/side, retractor mount and static end. I think you are correct. Link to comment Share on other sites More sharing options...
Keyav8r Posted January 7, 2014 Share Posted January 7, 2014 They're the same for the static (buckle) end between Renix era XJs and MJs. I pulled the static ends from an XJ at P&P because the buckles on the ones in my MJ were trashed. Bolts in the flor were the same. Link to comment Share on other sites More sharing options...
WahooSteeler Posted November 20, 2017 Share Posted November 20, 2017 Reviving this old thread as I need a replacement floor anchor bolt on the driver side shoulder harness. Old one was rusted and stripped and had to be drilled out. I do believe the retractor bolts and the anchor/static bolts were the same length when I removed the others. Top pivot one was longer, as were the ones for the buckle anchors I believe. Anyhoo, anybody got 1 or 2 laying around that I can buy? No pick n pulls around here to grab out of an XJ....... Link to comment Share on other sites More sharing options...
Mbryson Posted December 9, 2018 Share Posted December 9, 2018 Thanks! This helped me get the correct bolt today Link to comment Share on other sites More sharing options...
AZJeff Posted December 9, 2018 Share Posted December 9, 2018 I have some lower bolts (for the inboard tunnel side and the outer rocker panel side) of my MJ I would be glad to donate to the cause. They are shoulder bolts with about a 3/8" of unthreaded shoulder and the standard T20(?) head. Let me know if you want them. Link to comment Share on other sites More sharing options...
mjeff87 Posted December 9, 2018 Share Posted December 9, 2018 I can grab some out of the 'yard here for ya Wahoo...but not right at the moment. We're in the midst of a blizzard here right now lol. How's it up there on the mountain? CHO looks like it's getting clobbered right now too, so I imagine you are too. Supposed to be in the low 50's here this weekend coming up tho, so I could swing down if you needed me too Link to comment Share on other sites More sharing options...
WahooSteeler Posted December 9, 2018 Share Posted December 9, 2018 44 minutes ago, mjeff87 said: I can grab some out of the 'yard here for ya Wahoo...but not right at the moment. We're in the midst of a blizzard here right now lol. How's it up there on the mountain? CHO looks like it's getting clobbered right now too, so I imagine you are too. Supposed to be in the low 50's here this weekend coming up tho, so I could swing down if you needed me too Coming down steady here Jeff, expected 6-8 inches. Doesn't help that my truck is not engaging in 4wd right now! Transfer case is engaging but axle is not. Visual on the CAD lines in the engine bay looks ok, haven't crawled under it yet. But I digress............ I'm good on the seat belt bolts, got some from Team Cherokee......thanks for offering though! Link to comment Share on other sites More sharing options...
mjeff87 Posted December 9, 2018 Share Posted December 9, 2018 Pull the darn CAD cover off and slide the coupler over to lock the axle shafts together. Pull the vac lines and cap them, replace cover and never look back again. Were about 6" here now, with another 3-4 to go Link to comment Share on other sites More sharing options...
Amccutc21 Posted December 12, 2018 Share Posted December 12, 2018 Since this is an old post and I have a related issue, I don't feel bad hijacking this thread. I'm putting back my interior and can't remember if all 3 bolts on each side are the same length? I believe one anchor point on each side had a smaller bolt if I recall, is this correct? I didn't do a good job of organizing bolts as I was pulling and don't want to run the wrong size anchor bolt into the wrong location and deal with possible associated headaches. Link to comment Share on other sites More sharing options...
AZJeff Posted December 15, 2018 Share Posted December 15, 2018 On December 12, 2018 at 8:41 AM, Amccutc21 said: Since this is an old post and I have a related issue, I don't feel bad hijacking this thread. I'm putting back my interior and can't remember if all 3 bolts on each side are the same length? I believe one anchor point on each side had a smaller bolt if I recall, is this correct? I didn't do a good job of organizing bolts as I was pulling and don't want to run the wrong size anchor bolt into the wrong location and deal with possible associated headaches. The upper bolt that attaches on the top of the B pillar has a longer unthreaded shoulder on it than the two that attach at the floor. The retractor attaching bolt has no shoulder, of course. Link to comment Share on other sites More sharing options...
