My 1987 Mj
  • Replies 158
  • 3 months later...
Update : finally finally after all these years , I have purchased an Ax15 for 250$
came with bell housing, lower mount , And shifter. Only has 110,000 miles on it. Super excited to start collecting parts for the swap.
here’s some pics
god I love my 88.
7EDEF750-559B-40CA-9215-C4C6F3AED0C7.jpeg.666a25d452780e42c97cd9a2a1576b35.jpeg44566DCA-FFC3-484C-933D-48E8A5B55146.jpeg.17457853b959b38e3906cd3a69a358f9.jpeg
super excited to swap this in !
7 hours ago, Fernando87mj said:
No still gotta source that and look more into what I need to run for the clutch to work :holdwrench:
I used a brass compression fitting to adapt my old metal clutch line to the plastic line of the new trans.  but I also lucked out and had a bleeder on the external slave.  apparently they didn't all have them.  :dunno:
Pretty good info Pete ,
I had read about some people having to modify the firewall for the clutch master and in all honestly I don’t want to cut the old girl up , I want to keep it as original as I can.
  • 1 month later...
Been lusting after one of these for soo long,  so when the opportunity came up I couldn’t pass it up.
   Thanks to gJeep I have a nice new to me sports bar for this one. Still want one for my 88 one day.
   Super happy about it. Still need to repair the threads on the brackets and install them. Couldn’t help myself to at least mock it up to see how it looked.
   It looks glorious.
1C1B0CA5-E595-46AD-A241-993EC14ED26E.jpeg.f8ffde70ce1a0f191c11487b666a246e.jpegF02A599C-1ED8-45E5-9D82-0E9B9E956908.jpeg.1ebdc10bdd37d92baaeb1a3958d103c4.jpeg540EEF91-2443-4BFA-BB2A-C4CCA139C13E.jpeg.9bdbeafdf39f22d1ed6816224113febd.jpeg
  • 2 months later...
Decided to finally man up and get that old boat anchor Peugeot out. Wasn’t a horrible job, much easier than the new Honda’s I have to fix.
  Worst part was the 2 nuts on the Down pipe being frozen stuck. Even after hitting it with the torch the nuts were still a pain.
That and separating the trans was a little annoying due to the weird shape of the Peugeot.
  But she’s out now.  Waiting on my 1973 304 v8 cj pilot bushing to arrive now.
 Bought a tranny jack for the job, the awkward shape of the Peugeot made it a little difficult to keep steady. DA3F793E-95E4-47B3-8378-FEF99ADB0E49.jpeg.734b835d03f6062f7609a1b7955424df.jpeg
 Those e12 bolts are getting replaced ASAP 4C2C6BC2-84A6-4C9C-91F3-7F56BE4B2C20.jpeg.3b8fc7e0f364b5905e01de01f1ed63dc.jpeg
Boat anchor is out 4731B23D-5B0F-4532-AFDE-0A3BE2DD1447.jpeg.d06db7fe32c7651830f6a0bfdd03f698.jpeg
ready to swap in that Ax15
um, Lowes?  Ace Hardware?  grade 8 studs of the appropriate size/pitch/length (length of the old bolt plus maybe an inch).  put the 2 nuts on the end of one stud to make a "bolt", tighten the nuts together, put that into the block and tighten, then remove the nuts and do the same to the other one.  install transmission, then install the nuts. :L:
Thanks for the suggestion Pete , I’m forsure not using those torx bolts again man :laugh:
Plenty of progress today,
Sort of....
removal of clutch , flywheel , and pilot bushing were pretty smooth. Tapped fresh threads into the “frame” went really smooth too. Went to install pilot bushing #1 ( Timkin pb77hd). and ruined it. Was the biggest pia to remove. Spent a good 2 hours trying to get it out.
Went and got bushing number 2 (dorman 690-042) installed with more caution and with heat and it Stuck out a tiny bit. Hopefully won’t cause issues.
   Tomorrow hoping to install flywheel , clutch , and maybe trans depending how
i feel :laugh:
boss was nice enough to let me borrow electric impact that made removal a breeze.
bread trick actually worked lol
difference in bushings
1B402DD0-29C7-4ECC-886A-6C38DFB17682.jpeg.fc5e9cbb7dbe66675ea3aa17e33195b1.jpegCB9DBFEF-9B51-4E7B-BE36-240A5C3F9453.jpeg.b37e5eaeab85d08c7c9d23cf6cf08aed.jpeg
ruined bushing #1
going to assume bushing #2 is good and going to send it
