Park13
Everything posted by Park13
Looking for good condition header panel, no color preference Thank you!
Long Bed Dana 44 1J7GJ26LXKL616635 1989 Jeep Comanche 4.0 L Automatic V 6 Dana 30 front, Dana 44 Rear, Metric ton version, Long Bed 107k miles Current Location: Las Vegas, was previously a Northern California truck Status: Daily Driven ! Bench Seat, Column shifter, single pane window, manual doors and windows, that's about it!
Spring / Shock perch 44 to 8.25 Swap?
Park13 replied to Park13's topic in MJ Tech: Modification and Repairs
I got a really good deal on 4.10 Gear setup with 1 ton steering on Dana 30 / 8.25 Much appreciated!! -
Is there a place that sells the U-bolt perch and with shock mount all in one? Getting ready to swap, and I understand the Chrysler 8.25 is 3” tube diameter, while the stock metric ton Dana 44 is 2 3/4” thanks!!
Pretty much finished with the headliner. Turned out pretty good. The piece i found on amazon was perfect size to curl around the edges. https://www.amazon.com/gp/product/B07VMBN2DR/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 i like the quality on this material.I used extra tape around the folded edges to make sure it doesn't peel again Also put a thermal insulation piece and glued it to the roof, above the headliner. Got a huge roll of it for $16 at home depot. It's not dynamat or the expensive vehicle material stuff, but I think it will do the trick. And have a bunch left over https://www.homedepot.com/p/Reflectix-16-in-x-25-ft-Double-Reflective-Insulation-Roll-with-Staple-Tab-Edge-ST16025/100012574 Used one whole can of adhesive too https://www.amazon.com/gp/product/B000HBNU9K/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Someone snag this one too!! https://atlanta.craigslist.org/nat/cto/d/alpharetta-jeep-comanche-mj/7116326725.html Please read the entire ad before responding.Selling a 1987 Comanche short wheel base 2wd truck. Never rusty and needs only minor body work for restoration. 4 cylinder manual transmission. Ac. Nice original twill seat. I bought it to do a 4.0 4x4 swap from a readily available Cherokee. Good straighter, zero rust start to a valuable project. 4 cylinder does not currently start. No spark. Not sure what is wrong, just haven't had the time to sort it out and frankly did not care as I was going to do the engine swap. Probably something relatively simple. No Battery included but will have one available to crank, check lights, etc if needed. Brand new tires on nice rims, good seat, clean, clean rust free bed and tailgate. Clean Ga title in hand. The ad will come down the minute it sells. Don't send an email asking if it's available or you will be ignored, sent to spam.Messages with a phone number included will get priority.Cash or Jeep trades only.
Someone go pick this thing up!!! https://rockford.craigslist.org/pts/d/marengo-jeep-comanche-1989/7113219346.html 1989 Jeep Comanche650.00 or best offer for truck. Runs and drives does have power steering leak.would sell parts truck is in decent shape.-Bed 100.00 decent shape-Bench seat 85.00 great condition-Brush guard 75.00 good shape-doors 40.00 each good shape-hood 40.00 good shape-rear window 50.00 good shape-wheels and tires 80.00 for all fourDoors, hood, lights, grill and brush guard should fit and same style Cherokee.
This should fix folks flashing brights at me :) best $20 i've spent so far Rear lightbar underneath the tailgate, hooks up to trailer light. https://www.ebay.com/itm/49inch-LED-Rear-Brake-Signal-Reverse-Tailgate-Park-Light-Strip-Bar-Truck-Pick-Up/312834918587?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Attached behind the tailgate on the frame and tacked to a sturdy piece of drywall cornering for $3 at home depot.. Rattle canned the drywall cornering black.. And thats it!
Well.. I got another deal on a pair of axles that i couldn't pass up! JK Dana 30 and 44 with 4.88 gears and grizzly mechanical lockers. I like the idea of JK axles, but 4.88's are too big. Only want to be at 32" tires I'm thinking 4.10 is right. Hmm...
I saw one drive past my house today, right when i got on my bicycle. It was a rattle can flat black short bed with red parts. I pedaled so hard to the light to try and yell at him. LOL
The 8.25 came off a 98 XJ, setup with leafs over axle and left side rear shock / right front shock mounts.
Rear coil swap/ full Comanche rebuild
Park13 replied to 1988gecko's topic in MJ Hardcore Tech: Epic Journeys to Greatness
SOLID!!!! Thats a beefy build my friend. I'm taking notes -
Man that blue is such a stunner. Looks like you're on the home stretch from here!
Got a super deal today on axles and steering. Chrysler 8.25 rear with 4.10 gears, and Dana 30 w 4.10 front with 1 ton steering, WJ knuckle swap, big double piston brakes, and adjustible Track bar with a drop bracket (some not pictured). I am a lucky man to say the least Now I'm pondering the leaf over axle or leaf under... Didn't want to go higher than 4" lift. But if I go leaf over, i'll probably be pushing 5 1/2 tall". Original leafs are still in real good shape. Extra clearance would be nice though.. Hmm... Any thoughts on this pickle?
Rock on!!! Much appreciated
Do you happen to remember what bushings you put in?
The rear rear mounts are both good for eyelets, but you are right about the Fox ones being a little too small.. Can I drill out a millimeter or two to make them fit? Or would it be bad to have metal on metal contact?
Any S10 Camper Shellsnon MJ's?
Park13 replied to benjy_26's topic in MJ Tech: Modification and Repairs
Yup, I fit a S10 camper shell pretty well
