One Way To Do It.
hitman72
Get that guy some concrete blocks STAT!!!!!
WRONG! concrete blocks can fail suddenly and totally. Wood blocks do not fail in the same sudden way. A concrete block failure can kill you, not so with wood blocks.
Sorry forgot to use the sarcastic font. Yep wood is fine I use wood blocks to hold up equipment that weigh 35 tons.
Maybe we can start on this from the other end? For the negative nellies: other than offending your sense of style what is wrong with that wood being used as a stand?
Ok i'll play. Technicality you should only use wood blocks to support things when the are stacking cross grain not with the grain of the wood. It is possible for the block to split in this position. But I see nothing seriously wrong with it.
