Me&my86MJ Posted August 2, 2018 Author Share Posted August 2, 2018 Got aluminum valve cover and new style gasket to combat plastic valve cover warpage and oil leaks. Also cut some heat vent holes and added some skulls cut from aluminum. Link to comment Share on other sites More sharing options...
Pete M Posted August 4, 2018 Share Posted August 4, 2018 a 13k winch? I can't look at it without thinking of some marketing guy saying, "we need to one-up the competition. Give me more power!". That should be enough to get you out of pretty much anything. Link to comment Share on other sites More sharing options...
Me&my86MJ Posted August 4, 2018 Author Share Posted August 4, 2018 Pete you know it right, must have more Pow-er, I actually found it on Amazon for under $300 and with free shipping. Couldn't pass it up. Link to comment Share on other sites More sharing options...
Me&my86MJ Posted August 5, 2018 Author Share Posted August 5, 2018 Got valve cover installed with newer style gasket and no more oil leaks . Link to comment Share on other sites More sharing options...
Me&my86MJ Posted August 26, 2018 Author Share Posted August 26, 2018 Trimmed up the stock fender flares on front and finally got them reinstalled after losing stupid tin brackets. Now I am thinking I need to trim rear ones too. Link to comment Share on other sites More sharing options...
Pete M Posted August 28, 2018 Share Posted August 28, 2018 the rears are far more accommodating to big tires. I needed just the slightest trim on the inner lower curl to clear 33s. Link to comment Share on other sites More sharing options...
Me&my86MJ Posted August 29, 2018 Author Share Posted August 29, 2018 On 8/27/2018 at 7:42 PM, Pete M said: the rears are far more accommodating to big tires. I needed just the slightest trim on the inner lower curl to clear 33s. You telling me I can't just toss some 37.5 on there.... Link to comment Share on other sites More sharing options...
Me&my86MJ Posted August 29, 2018 Author Share Posted August 29, 2018 Cause my lady said i can have 4deetwos when i am 42 but 37.5 are ok for now. Link to comment Share on other sites More sharing options...
Me&my86MJ Posted September 5, 2018 Author Share Posted September 5, 2018 On 8/27/2018 at 7:42 PM, Pete M said: the rears are far more accommodating to big tires. I needed just the slightest trim on the inner lower curl to clear 33s. I figure you are running SOA, what lift do you have in front, did you use larger shackles in rear? Link to comment Share on other sites More sharing options...
Me&my86MJ Posted March 6, 2019 Author Share Posted March 6, 2019 Got a few goodies for the manche Link to comment Share on other sites More sharing options...
btipsword1 Posted March 6, 2019 Share Posted March 6, 2019 What did you do for the front driveshaft? Link to comment Share on other sites More sharing options...
Me&my86MJ Posted March 6, 2019 Author Share Posted March 6, 2019 24 minutes ago, btipsword1 said: What did you do for the front driveshaft? I used 90s Jeep Grand Cherokee v8 front driveshaft for my front. Link to comment Share on other sites More sharing options...
btipsword1 Posted March 8, 2019 Share Posted March 8, 2019 On 3/6/2019 at 3:19 PM, Me&my86MJ said: I used 90s Jeep Grand Cherokee v8 front driveshaft for my front. Thanks dude, looks good! Link to comment Share on other sites More sharing options...
Me&my86MJ Posted March 8, 2019 Author Share Posted March 8, 2019 3 minutes ago, btipsword1 said: Thanks dude, looks good! Thank you again, have a special few goodies coming too. Certainly can't wait Link to comment Share on other sites More sharing options...
Me&my86MJ Posted April 3, 2019 Author Share Posted April 3, 2019 Just got me some Super Swamper Boggers and Pro Comp rims. Link to comment Share on other sites More sharing options...
Pete M Posted April 3, 2019 Share Posted April 3, 2019 gnarly! Link to comment Share on other sites More sharing options...
JMO413 Posted April 4, 2019 Share Posted April 4, 2019 Looks awesome! Link to comment Share on other sites More sharing options...
Me&my86MJ Posted April 4, 2019 Author Share Posted April 4, 2019 7 hours ago, Pete M said: gnarly! Your jeep with boggers is what has always inspired me to want some. 46 minutes ago, JMO413 said: Looks awesome! Thank you, it's the boggers, boggers on anything makes it look better. I bet I will look even better with them on me, mounted to a comanche, squeezing my contents out like a tube of toothpaste. Link to comment Share on other sites More sharing options...
Me&my86MJ Posted June 16, 2019 Author Share Posted June 16, 2019 Sometimes it's the littlest things that make the bigger/biggest things work. Had to cut the front fenders and add a little lift and bump for new tires. Link to comment Share on other sites More sharing options...
Me&my86MJ Posted July 24, 2019 Author Share Posted July 24, 2019 Checked clearance and then hit the trails. Link to comment Share on other sites More sharing options...
89 MJ Posted July 24, 2019 Share Posted July 24, 2019 How did it do? Link to comment Share on other sites More sharing options...
Me&my86MJ Posted July 26, 2019 Author Share Posted July 26, 2019 On 7/24/2019 at 4:41 PM, 89 MJ said: How did it do? It did very well, no rubbing, or extra noises. My 2.5l struggles going up hills at highway speeds but has no issues at lower offroading speeds whatsoever. Also was able to make my way into play area over filter places at opening of it and had a ton of fun in there. Even got to watch a full size blazer get stuck and almost tip over. Link to comment Share on other sites More sharing options...
Me&my86MJ Posted January 19, 2020 Author Share Posted January 19, 2020 Made brackets and painted them so I could install AUX lights, managed to reuse old AUX switch pannel for new floating switch. It seems when I made passenger side wiring longer and with larger gauge wire to meet power wire from switch it is now receiving 99% of power making driver side aux light look unpowered(if you look real close you can barely see a faint bit of illumination). I am going to rewire making harness look identical side to side, if anyone has had similar issues happen or can confirm that is or is most likely the issue, I would like to thank you in advance. Link to comment Share on other sites More sharing options...
Pete M Posted January 19, 2020 Share Posted January 19, 2020 if one side works and the other doesn't, the problem lies in something other than wire size. both sides should illuminate if both sides have connection to 12 volts. one side won't suck the power away from the other just because it has a bigger wire. electricity will flow in both wires. Link to comment Share on other sites More sharing options...
Me&my86MJ Posted January 19, 2020 Author Share Posted January 19, 2020 15 minutes ago, Pete M said: if one side works and the other doesn't, the problem lies in something other than wire size. both sides should illuminate if both sides have connection to 12 volts. one side won't suck the power away from the other just because it has a bigger wire. electricity will flow in both wires. Hmmm, well both sides are working kinda sorta, driver side just seems to be super weak. I have already checked to make sure both pods illuminate when 12v is supplied and they did to same or similar brightness. Issue only happened once I extended/added wire from passenger side and it happens to be a lot larger gauge like 10 or 8 gauge compared to 18 gauge pods have. Link to comment Share on other sites More sharing options...
