ParadiseMJ Posted June 29, 2013 Share Posted June 29, 2013 The reverse light switch for a manual trans is only a reverse light switch. It plugs in to the side of the tranny and goes to a flat 4 wire plug near the oil dipstick. Link to comment Share on other sites More sharing options...
cruiser54 Posted June 29, 2013 Share Posted June 29, 2013 Are you absolutely sure that the 7.5 amp TRANS fuse under the dash is good? Look for a bent pin in the NSS connector also? Does the Power/Comfort button work? (it's on the same TRANS fuse under the dash). In case someone with a 91 (or possibly 92) has a similar backup light problem, this only applies to a Renix systems. There is no under dash Trans fuse for the HOs. The POWER/COMFORT switch is fed by an independent 10A fuse up in the PDC. Pulling this fuse defaults the AW4 to the POWER mode. Good to know. Link to comment Share on other sites More sharing options...
cruiser54 Posted June 29, 2013 Share Posted June 29, 2013 This information does not apply to those with a manual transmission. Wanna bet? According to my Renix MJ diagram, the reverse light circuit is fed by a 7.5 amp TRANS fuse. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted June 29, 2013 Share Posted June 29, 2013 This information does not apply to those with a manual transmission. Wanna bet? According to my Renix MJ diagram, the reverse light circuit is fed by a 7.5 amp TRANS fuse. So ParadiseMJ and I are wrong? I just wouldn't have thought there would be a TRANS fuse used on a stick shift Jeep. Just like ParadiseMJ said, I would have thought the backup light switch on a manual would be just that, a switch. But I know you're far more knowledgeable about Jeeps than I am, so I surrender haha. Link to comment Share on other sites More sharing options...
mvusse Posted June 29, 2013 Share Posted June 29, 2013 This information does not apply to those with a manual transmission. Wanna bet? According to my Renix MJ diagram, the reverse light circuit is fed by a 7.5 amp TRANS fuse. Correct. I just tested this a minute ago an my 1987 2.5/AX5 manual transmission: ignition on, shifter in reverse to turn the reverse lights on. I then pulled the 7.5 amp trans fuse and the reverse lights went out. Link to comment Share on other sites More sharing options...
cruiser54 Posted June 29, 2013 Share Posted June 29, 2013 This information does not apply to those with a manual transmission. Wanna bet? According to my Renix MJ diagram, the reverse light circuit is fed by a 7.5 amp TRANS fuse. Correct. I just tested this a minute ago an my 1987 2.5/AX5 manual transmission: ignition on, shifter in reverse to turn the reverse lights on. I then pulled the 7.5 amp trans fuse and the reverse lights went out. I woke up this morning knowing someone would try this overnight. Thanks. Link to comment Share on other sites More sharing options...
motorbikejedi Posted June 30, 2013 Share Posted June 30, 2013 AHHHHHHHH I am soo excited, 4 years with no revese lights, 1 headlamp hooked up to a toggle switch on the rear bumper later, it was just that dang fuse missing from previous owner so I never thought it was supposed to be there. ! I never imagined that reverse light was hooked up to the trans fuse!!!! I could never find a wiring diagram to confirm that but it doesnt matter now, they work!!!! Now I have to rip out that hillbilly reverse light I had rigged up! So I am also confirming, I have a 2.5 with a 4 speed manual and the revrse light run with that trans fuse. This truck is in way better shape than it ever has since I've had it. I just got the new gas tank in, U joints, fixed the revese lights, new wood dash and radio from a cherokee, fixing all the lights and this puppy will be 100% road ready! Thanks for the help! Link to comment Share on other sites More sharing options...
cruiser54 Posted June 30, 2013 Share Posted June 30, 2013 AHHHHHHHH I am soo excited, 4 years with no revese lights, 1 headlamp hooked up to a toggle switch on the rear bumper later, it was just that dang fuse missing from previous owner so I never thought it was supposed to be there. ! I never imagined that reverse light was hooked up to the trans fuse!!!! I could never find a wiring diagram to confirm that but it doesnt matter now, they work!!!! Now I have to rip out that hillbilly reverse light I had rigged up! So I am also confirming, I have a 2.5 with a 4 speed manual and the revrse light run with that trans fuse. This truck is in way better shape than it ever has since I've had it. I just got the new gas tank in, U joints, fixed the revese lights, new wood dash and radio from a cherokee, fixing all the lights and this puppy will be 100% road ready! Thanks for the help! You'll be crapping in tall cotton real soon!!!! Link to comment Share on other sites More sharing options...
wadeM Posted April 3, 2014 Share Posted April 3, 2014 Reverse light switch could be unpluged, damaged or malfunctioning. where is this switch located i have not been able to find the switch. Link to comment Share on other sites More sharing options...
cruiser54 Posted April 3, 2014 Share Posted April 3, 2014 What if there was a short in the reverse lamp bulbs themselves? Link to comment Share on other sites More sharing options...
Tactical Bacon Posted April 4, 2014 Share Posted April 4, 2014 Reverse light switch could be unpluged, damaged or malfunctioning. where is this switch located i have not been able to find the switch. On my AX15, it's on the passenger side. But I dunno where it would be if you have the AX4, AX5, AW4, or TF727. Link to comment Share on other sites More sharing options...
88whitemanche Posted April 4, 2014 Share Posted April 4, 2014 Ax5 is on the passenger side.... Link to comment Share on other sites More sharing options...
Tactical Bacon Posted April 5, 2014 Share Posted April 5, 2014 One of those times where it's good to tell us what you have so we can better help you. Link to comment Share on other sites More sharing options...
CGCWO Posted January 27, 2015 Share Posted January 27, 2015 Resurrected, I have a 2.5/4spd manual where would the switch be? Fuse is good, new bulbs, cleaned up sockets (PO had 1157s jammed in but not seated). Link to comment Share on other sites More sharing options...
cruiser54 Posted January 27, 2015 Share Posted January 27, 2015 Resurrected, I have a 2.5/4spd manual where would the switch be? Fuse is good, new bulbs, cleaned up sockets (PO had 1157s jammed in but not seated). Driver's side of the transmission. Link to comment Share on other sites More sharing options...
CGCWO Posted January 27, 2015 Share Posted January 27, 2015 thanks! Was trying to look, but ran out of light tonight. Link to comment Share on other sites More sharing options...
GrandComanche Posted April 22, 2021 Share Posted April 22, 2021 Question here fellas. When transporting my transmission to the shop to be fixed, the reverse light plug or switch broke. I'm having a hell of time finding a replacement. Will this work as a viable fix? https://www.quadratec.com/products/52156_0005.htm Link to comment Share on other sites More sharing options...
scaleless Posted April 22, 2021 Share Posted April 22, 2021 For BA10 or AX15? AX15: https://www.rockauto.com/en/moreinfo.php?pk=932883&cc=1180314 BA10: https://www.amazon.com/dp/B00108E3P4 Link to comment Share on other sites More sharing options...
