Next Generation Of Off Road Tires?
Biotex
Different companies have been toying with these for 10-15 years now. They have yet to catch on... obviously. I think they are having trouble finding a happy medium between good flexibility, and resiliency. I would love to see something like this be a workable usable solution, but I don't think they are there yet.
I'm reading they should hit the market in August. Maybe they are there!
I like how it's on a mil spec hmmvw, the military would be the last people to use that.
LOL...... whut? The military would be the FIRST to use tires like this. Bullets + air filled tires = no bueno.
You could probably put a hundred rounds into those and they'd still function.
Huh? Pretty certain most of the developement of those has been paid for by the US DOD. A tire that you can drive over calthrops, can take fire, doesn't need to be serviced (add air, for the people wondering what that means), and will dazzle the towelheads. Pretty much everything they want. And it'll probably be expensive too, so that's even better.
Not sure how much of an offroad tire that would be.
I don't see how it would be able to wrap an obsticle like an aired down pneumatic tire.
Maybe not good for crawling rocks, fallen trees and fording streams, but I bet they would work very well on soft or hard-packed sand. Think Middle East.....
I'll bet it is no fun when they get mud inside those spokes.
Regular tires would throw it off eventually, but bet those spoke would hold enough to cause balance issues.
I don't see why they couldn't add an outer skin to the spokes to subvert that issue
^That always confused me. Don't the HMMWV's have onboard air? Or was that just the H1?
I believe they have CTIS. Even better than onboard air, when it works. However, that doesn't mean they instruct them to air down the tires in the event that they might get stuck. Also, I'm not sure if the CTIS allows you to air them down easily.
That's what I was thinking of, just didn't know the acronym. Although I thought the whole point of it was so you could air down/up without needing to get out of the vehicle...
Okay, thanks. CTIS was an option on the H1's so I assumed it came on the HMMWV's. Guess not.
I don't think it was an option, more like standard equipment? That's why I thought it would be on the HMMWV.
It typically blows an o-ring/seal every couple years, deflating all the tires at once. It's a sore sport with H1 owners :rotfl2:
