ftpiercecracker1 Posted July 1, 2012 Share Posted July 1, 2012 E brake assembly has had it, along with the bracket under the bed, actually, the whole setup needs replacing. I looked around and have found a few places that carry the cables or what appears to be the cables, but i have batted zero when it came to finding the assembly that bolts to the inside of the cab. I've heard these trucks are notorious for having POS e-brakes let me know where i can find a new one, thanks please don't say dealership, please don't say dealership, please don't say dealership Link to comment Share on other sites More sharing options...
Alexia Posted July 1, 2012 Share Posted July 1, 2012 E brake assembly has had it, along with the bracket under the bed, actually, the whole setup needs replacing. I looked around and have found a few places that carry the cables or what appears to be the cables, but i have batted zero when it came to finding the assembly that bolts to the inside of the cab. I've heard these trucks are notorious for having POS e-brakes let me know where i can find a new one, thanks please don't say dealership, please don't say dealership, please don't say dealership I will be getting rid of mine, but I have been batting zero as well trying to get the cable off to remove it! Seems like I need six hands to hold the clips, pop the cable off, and pull it out all at once. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted July 1, 2012 Share Posted July 1, 2012 The dealer doesnt have them either. But they do still have them for the YJ, which is made similarly and may be made to work. Or you could pull yours out and see if the locking latch spring is still in place. It could be that the spring just isnt there anymore and won't let it hold. If thats all it is, you install a new small spring, and that might just fix it. Though Ive heard of the teeth wearing off to, so if thats your problem, youll just need a new assy. Good luck. Link to comment Share on other sites More sharing options...
sinkrun Posted July 1, 2012 Share Posted July 1, 2012 Many have upgraded to a hand brake lever from a cherokee you will need the cherokee console and I am not sure what else? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted July 2, 2012 Share Posted July 2, 2012 I have a mint pedal assembly, and a set of the under bed bracketry in good shape. Pm me if you're interested. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted July 5, 2012 Author Share Posted July 5, 2012 I have a mint pedal assembly, and a set of the under bed bracketry in good shape. Pm me if you're interested. i pm-ed you, never heard back. I am interested, if you didnt get the message Link to comment Share on other sites More sharing options...
LarryH88bt Posted July 6, 2012 Share Posted July 6, 2012 I've heard these trucks are notorious for having POS e-brakes Now that you mention it, I can never get mine to tighten just right. It's either too much or too little. And ever since I broke the cable at the pedal assembly, I'm afraid to tighten it more and risk popping the cap off the cable again if I ever need an emergency stop. And adjusting the shoes doesn't help much. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted July 6, 2012 Author Share Posted July 6, 2012 Did you try adjusting the under bed bracket? I think that is the one that is designed to be tightened. As for me i think that i will try and find another e brake assembly, possibly from a different jeep and try to rig something up. dunno, i've got plenty of time to figure something out. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted July 6, 2012 Share Posted July 6, 2012 I'll get back to you today. Link to comment Share on other sites More sharing options...
carnuck Posted July 19, 2012 Share Posted July 19, 2012 I think it may be the same assembly as my Eagle I parted. When I work on the stuff at my cabin I'll try to remember to compare them. Link to comment Share on other sites More sharing options...
Silver88 Posted July 21, 2012 Share Posted July 21, 2012 I just had my e-brake cable replaced, got it from Rock Auto a little while back. The rear cables the installer got. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted July 22, 2012 Author Share Posted July 22, 2012 I recently removed my assembly and found that the whole thing is as loose as a goose, the pedal wobbles as well as the retaining tooth. Image Not Found here's my thought, why don't i just drill this ^ puppy out, replace it with a bolt and tighten till it quits wiggling Image Not Found same with this, replace with bolt and tighten, it seems the whole stupid assembly is held together by these "bass akward" pin things that can't be adjusted. :fs1: Image Not Found Also i had the brilliant :idea: idea to put a MUCH stronger spring in place of the one that holds the retaining tooth against the rotating plate deal. Link to comment Share on other sites More sharing options...
cruiser54 Posted July 22, 2012 Share Posted July 22, 2012 There was a recall on them for popping off after being set. Cracker, I'm interested in your fix. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted July 22, 2012 Author Share Posted July 22, 2012 These pictures are really making me mad. :hateputers: First they are to big, then i come back and they're too small. i've tried resizing them through photobucket till blue in the face, but it makes no difference. Is there someway i can talk to a moderator so i can figure this out once and all? I tried to follow the instructions on the "test 1 2" page, but it is for an out of date version of photo bucket. The version i am using is not the same. Newer? :dunno: Could someone show me how to do it? It is extremely frustrating. sorry for the rant . Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted July 22, 2012 Author Share Posted July 22, 2012 There was a recall on them for popping off after being set. Cracker, I'm interested in your fix. Thats exactly what mine was doing when i had everything together. Push down and it would never hold. If you kept your foot there it would hold the truck on a 90* slope, but it would let go as soon i you let your foot off. i will probably go ahead and do what i have planned, who knows maybe i will develop the very first DIY E-brake fix writeup. Which would also happen to be my first write up. That would be awesome. :drool: thanks for the interest :thumbsup: Link to comment Share on other sites More sharing options...
cruiser54 Posted July 22, 2012 Share Posted July 22, 2012 I think the photos are fine. It would be great to find a solution to the e-brake issue. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted July 23, 2012 Author Share Posted July 23, 2012 working on it. But it hasnt been easy. I am fairly confident i can make this work, its just gonna take some time. :wrench: I know it will work great once its done. ;) Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted July 24, 2012 Author Share Posted July 24, 2012 I honestly can't believe I pulled it off, but i've done it :jump: . Besides a few more adjustments, I have the assembly back together and it works beautifully. That being said i have yet to put it under "load" as in actually holding the truck in place so. . . (knocks on nearby wood) To be honest, it would probably be cheaper just to get another assembly from the junkyard, but I just like to tear stuff apart to see if i can make it better, and boy is it ever. :yes: I can give more detail and pictures if anyone is interested. Link to comment Share on other sites More sharing options...
vaquaro Posted July 24, 2012 Share Posted July 24, 2012 I honestly can't believe I pulled it off, but i've done it :jump: . Besides a few more adjustments, I have the assembly back together and it works beautifully. That being said i have yet to put it under "load" as in actually holding the truck in place so. . . (knocks on nearby wood) To be honest, it would probably be cheaper just to get another assembly from the junkyard, but I just like to tear stuff apart to see if i can make it better, and boy is it ever. :yes: I can give more detail and pictures if anyone is interested. :thumbsup: Please do , I'm currently jamming a old steering wheel lock between the e-brake pedal and the seat bracket :headpop: or using a wheel chock with a retrieval line attached . :cheers: Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted July 25, 2012 Author Share Posted July 25, 2012 :thumbsup: Please do , I'm currently jamming a old steering wheel lock between the e-brake pedal and the seat bracket :headpop: or using a wheel chock with a retrieval line attached . :cheers: I used to use an 8in belt knife :rotfl2: but anyway, about the fix. . . I will let you know now this project was NOT easy. I will try to do my best to take pictures and explain clearly, it won't be easy. also the way i did things might not be the best, so if you discover a better way i would love to hear about it. ;) Link to comment Share on other sites More sharing options...
vaquaro Posted July 25, 2012 Share Posted July 25, 2012 :thumbsup: Please do , I'm currently jamming a old steering wheel lock between the e-brake pedal and the seat bracket :headpop: or using a wheel chock with a retrieval line attached . :cheers: I used to use an 8in belt knife :rotfl2: but anyway, about the fix. . . I will let you know now this project was NOT easy. I will try to do my best to take pictures and explain clearly, it won't be easy. also the way i did things might not be the best, so if you discover a better way i would love to hear about it. ;) I'm looking forward to your write-up :yes: Thanks , Gord Link to comment Share on other sites More sharing options...
