Jk owner needs MJ advice
Whats up guys? Currently an 08 jk owner on a 3.5in lift with 37s. I'm looking into buying an mj
and i have two options right now and i need help choosing I have an option to buy one which is
4wd, I6, 5spd rusted pretty bad with 100k and the other has no rust but is 2wd with 200+k
5sp. Which would be a better platform to start with? I'm mechanically inclined and can also do
body work. Opinions needed please. Here are some pics of my jk
sorry pics are so big
I would buy the one with no rust issues. I like bodywork more then mechanical but these trucks get out of control when it come to rusting away. Its very easy to make these 4wd and if the miles worry you that can be fixed by putting a low miles motor in when you swap in the 4wd stuff.
since you want to make it your wheeler id buy the rust free 2wd. when you wrench on it you won't have to deal with the crust, and you will be able to swap in whatever axle/ratio you choose. if the higher mileage motor goes, used motors are not hard to find
  • 1 month later...
How about this? Dropping in the drivetrain out of a 2005 TJ Wrangler with the 6 speed manual and the 4.0. What would you need to grab off the donor 2005 TJ? I assume you would need the computer, harness, and gas pedal. Anything else?
might wanna try making a new thread about this..
That sounds like a good idea. Sorry, I got caught up in the excitement of this build as it is along the same lines of what I’m looking to do. I’m a newbie to this group but not to Jeeps in general. I have 13 Willys trucks in my stables along with a 2006 LJ Rubi. Three of mine are direct ancestors of the XJ Waggy. Here’s one of them.
http://thefcconnection.com/'50_wagon.htm
Can't wait to see this build through! Thanks for sharing your project with us.
  • 3 weeks later...
