ekulrenlig Posted January 3, 2007 Share Posted January 3, 2007 What 5-speed transmission and t-case came behind the 2.8L V-6 in an '85 Cherokee? AX-5 and NP207? Is there much of a demand for the 2.8L engine and 207 t-case? I found a complete engine, transmission, t-case setup for sale, but only need the transmission. I was hoping I could sell the engine and t-case to make my money back. Link to comment Share on other sites More sharing options...
mjeff87 Posted January 3, 2007 Share Posted January 3, 2007 Most likely an AX5 and 207....but it could be a T5 and NP228/229. If the TC has a fixed rear output, it's a 228/229. Jeff Link to comment Share on other sites More sharing options...
Eagle Posted January 4, 2007 Share Posted January 4, 2007 Most likely an AX5 and 207....but it could be a T5 and NP228/229. If the TC has a fixed rear output, it's a 228/229. Jeff The 228 or 229 was what they were using as the 'Selec-Trac" option back then, and just like the NP242 Selec-Trac on the newer XJs, I don't think the option was offered with the 5-speed. So it's most likely an AX-5 with NP207, but as noted, it could be a T-5 tranny. Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted January 4, 2007 Share Posted January 4, 2007 Most likely an AX5 and 207....but it could be a T5 and NP228/229. If the TC has a fixed rear output, it's a 228/229. Jeff The 228 or 229 was what they were using as the 'Selec-Trac" option back then, and just like the NP242 Selec-Trac on the newer XJs, I don't think the option was offered with the 5-speed. So it's most likely an AX-5 with NP207, but as noted, it could be a T-5 tranny. ot I know. but whats the difference between the Selec-Trac and the Command-Trac Link to comment Share on other sites More sharing options...
Oizarod115 Posted January 4, 2007 Share Posted January 4, 2007 select-trac has 4wheel drive full-time (AWD can be driven on road in any condition) command-track has 4wheel drive part-time offroad or very loose conditions only some select tracs had both fulltime and parttime like the 242... i don't know about the 229 though Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted January 4, 2007 Share Posted January 4, 2007 select-trac has 4wheel drive full-time (AWD can be driven on road in any condition) command-track has 4wheel drive part-time offroad or very loose conditions only some select tracs had both fulltime and parttime like the 242... i don't know about the 229 though whats the t-cases the 4.0 mj's would have? Ive got a 2.5, what one normally came behind that? Link to comment Share on other sites More sharing options...
Oizarod115 Posted January 4, 2007 Share Posted January 4, 2007 from 87-92 the MJ either had np231 or the np242 (selec-trac only with auto tranny) Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted January 4, 2007 Share Posted January 4, 2007 from 87-92 the MJ either had np231 or the np242 (selec-trac only with auto tranny) a 2.5L would have what behind it? a 231? Link to comment Share on other sites More sharing options...
86FUBAR Posted January 4, 2007 Share Posted January 4, 2007 bening the owner of a 2.8 manche (with 5speed) I would keep the whole shebang caus u never know when ur gona need a new engin (mine blew, go figure) , I'm curntly picking up 2 4x4 s10 blazers wit the 2.8 1s a manual and the other is an auto and I'm gona keep as much as i can for spare parts , i sugjest u do the same. Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 4, 2007 Share Posted January 4, 2007 bening the owner of a 2.8 manche (with 5speed) I would keep the whole shebang caus u never know when ur gona need a new engin (mine blew, go figure) , I'm curntly picking up 2 4x4 s10 blazers wit the 2.8 1s a manual and the other is an auto and I'm gona keep as much as i can for spare parts , i sugjest u do the same. I'm with you on that. The 2.8 doesn't have much (if any) resale value, but has a nasty habit of exploding. Hence it'll save headaches to keep a spare one around. Link to comment Share on other sites More sharing options...
ekulrenlig Posted January 4, 2007 Author Share Posted January 4, 2007 Hey, quit stealing my topic! No, these are all excellent questions and answers. 8) But anyway, is there much of a demand for the 2.8 L engine? Or the NP 207 or 228/229? Correct me if I'm wrong--the AX-5 has a 14 spline input shaft and the T-5 has a 10 spline input shaft, so the T-5 could not replace the AX-5?? a 2.5L would have what behind it? a 231? I think pre '88 usually has a 207 and '88+ has 231. ot I know. but whats the difference between the Selec-Trac and the Command-Trac Doesn't the shifter selections usually indicate if you have selc-trac or command-trac?? Link to comment Share on other sites More sharing options...
ekulrenlig Posted January 4, 2007 Author Share Posted January 4, 2007 oops guess it took me too long to write that. Actually I have the 2.5L engine...I just need a tranny. Can someone teach me how to quote people correctly? Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 4, 2007 Share Posted January 4, 2007 But anyway, is there much of a demand for the 2.8 L engine? Or the NP 207 or 228/229? Nope, nope, and nope. Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 4, 2007 Share Posted January 4, 2007 Can someone teach me how to quote people correctly? [quote name="ekulrenlig"] Can someone teach me how to quote people correctly?[/quote] You change the name in the "" part and the text goes between. Link to comment Share on other sites More sharing options...
ekulrenlig Posted January 4, 2007 Author Share Posted January 4, 2007 You change the name in the "" part and the text goes between. Thanks! Link to comment Share on other sites More sharing options...
Pete M Posted January 4, 2007 Share Posted January 4, 2007 from 87-92 the MJ either had np231 or the np242 (selec-trac only with auto tranny) No evidence has ever come forth for a 242 ever being offered in an MJ from the factory. Link to comment Share on other sites More sharing options...
Joop Posted January 4, 2007 Share Posted January 4, 2007 While talking about it.. Is there any other models out there that used the ax5 or t-5 case, not necessarily a jeep? Need one my self but not many jeeps over here Link to comment Share on other sites More sharing options...
ekulrenlig Posted January 10, 2007 Author Share Posted January 10, 2007 So here are a couple pictures of the 2.8L V-6 I was looking at. http://good-times.webshots.com/photo/2006309410098834518IkJLaE http://good-times.webshots.com/photo/2230196600098834518niHOTj Can anybody tell what tranny and t-case those are? They have about 90,000 miles and alot of those miles came from being towed behind a motorhome. It ran good and had great oil pressure. How much do you guys/gals think it's worth? Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted January 10, 2007 Share Posted January 10, 2007 So here are a couple pictures of the 2.8L V-6 I was looking at.http://good-times.webshots.com/photo/2006309410098834518IkJLaE http://good-times.webshots.com/photo/2230196600098834518niHOTj Can anybody tell what tranny and t-case those are? They have about 90,000 miles and alot of those miles came from being towed behind a motorhome. It ran good and had great oil pressure. How much do you guys/gals think it's worth? looks exactly like mine. the AX-4 Link to comment Share on other sites More sharing options...
ekulrenlig Posted January 11, 2007 Author Share Posted January 11, 2007 Well, it's suppose to be a 5 speed? So AX-5? Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted January 11, 2007 Share Posted January 11, 2007 Well, it's suppose to be a 5 speed? So AX-5? should be, I'm currently trying to track down a AX-5. I would highly appreciate a 5th gear on my 2.5L Link to comment Share on other sites More sharing options...
ekulrenlig Posted January 11, 2007 Author Share Posted January 11, 2007 So how much $ do you think all that is worth? Link to comment Share on other sites More sharing options...
feerocknok Posted January 11, 2007 Share Posted January 11, 2007 I'd be willing to pay $350 for that. Link to comment Share on other sites More sharing options...
