Everything posted by ekulrenlig
I've got an 87 with the 2.5L, 5-speed, 4x4, posted for $500. And an 86 with the 2.5L, 5-speed, 2x4, posted for $300. Both are located in Michigan, and both have rust problems around the wheel wells, but could make a good parts truck for you. Check the link if interested, there is a link in it for a bunch of pictures. viewtopic.php?f=24&t=19835
Anyone want to haul a Comanche from Northern Michigan to Pennsylvania for two fellow Comanche Club users??
I've got an 1987 MJ with the 2.5 and 4x4 posted in the for sale section. Would be a good parts truck for you. Located in Northern Lower Michigan. Asking $700 obo.
Where can I get an AX-5?
ekulrenlig replied to ekulrenlig's topic in MJ Tech: Modification and Repairs
To the best of my knowledge, my NP 231 is the original transfer case, however the previous owner supposedly rebuilt it. I just wanted to verify the spline count for the output shaft. JeepcoMJ: (I forget how to quote somebody) How do you know if you have a long or short output seal depth? -
Thats too much work. Just going for quick and easy here. Anyone else know of a good place to get one. Bosses money, might as well do it right. -
I have not been on here for a while since my comanche "died", but alas my comanche may live again!! I have just about convinced my boss to buy my comanche from me for a work vehicle. He's gonna pay me for it, and pay for the repairs (new tranny) and I'll probably still get to drive it. Not a bad deal if I do say so myself. So my question is, where can I find a good deal on a transmission, either rebuilt or new? I believe I have the NP231, is that 23 spline or 21?
Well, it's been about 2 weeks and I haven't had any problems since.
I've got the same problem. Thought it was the throwout bearing too, had a new clutch kit put in, but the noise is still there. I was later told that it's not the throwout bearing if the noise stops when you push in your clutch. Likely the "pocket" bearing on the input shaft making noise when the input shaft and cluster shaft are spinning at different speeds. It probably won't make the noise in 4th gear, when the shaft ratio is 1:1.
You could try asking one of these guys. http://www.jeeps-offroad.com/yj-technic ... -help.html
What engine parts are compatable between the 2.5L and 4.0L engine? Water pump? Alternator? Starter? Coil? Belts? Pulleys? Radiator? Air intake? What else?
Well, I'll keep you posted. So far its starting fine. Yeah, got it, thanks. I'd love to add another needed part to my list. I might as well buy a new truck with all the parts that should be replaced. How much does a decent set of cables go for?
If this is the case, why would it start up so easily with a jump?[/url]
Well, I took the battery and starter to get tested and both tested good. Checked over the cables, seem ok, not the greatest shape, but ok. Tried to loosen the bolt for the ground on the engine to clean it, but couldn't loosen it, sprayed WD40 on it, but still stuck. Then I put the battery and starter back in. Turn the key and it started right up. Starts fine now. Not really sure what the problem was. Maybe a bad connection somewhere, but seems odd that it started with a jump from another vehicle. Maybe the ground on the engine wasn't making good contact and the WD40 helped. I don't know. What do you guys think it was?
Yeah, sounds like we're having the same problem. I've cleaned the battery terminals, whacked the started, and still just clicks. I haven't tested the battery, but all my accessories work fine. Any ideas? Starter?
No start this morning. Just clicked when turned the key. All my accesories and lights seemed fine and bright. Jumped it with another car, it clicked once and then started up. Let it run for a little while, shut it off, tried again....just clicks. I think it is my starter or starter solenoid. Any way to figure out for sure which one it is? Starter relay maybe? Help me out please. Would a weak battery be related to this problem?
Everything I have found about the T-4/T-5 shows that the input shaft length and spline count are different than the AX-4/AX-5. Is this true? If so, how did they use them interchangably? Did they use the same input shaft for the two trannies?
Someone correct me if I'm wrong, but you'll have to get a door from a 4-door cherokee.
Transmission compatability
Yeah, I'd like to stick with the 5 sp. -
Excellent, thank you Eagle, thats what I wanted to know. Now, your next task is to find out which of those transmissions will mate up to my transfer case. :bowdown: -
Yes, I have the 2.5L engine. Do you know what model trannys for the 2.8L chevy engine would work? From what years and makes can I find this tranny in chevys? Is this 2.8L the same 2.8L used in early 80's XJ/MJ? -
So, a tranny from a 2.8L chevy engine will replace an AX-5?? What modifications are needed? Also, what range of years for wranglers with the 2.5L have a swapable tranny for my AX-5 (87 MJ)? -
Thanks guys for all the info. So what range of years in Wranglers will have swapable trannies with my AX-5, without having to modify a whole lot? BTW--The 91 engine/tranny setup I mentioned earlier is sold, along with a t-case that needs a chain and an almost new radiator for $300. You guys didn't answer my questions fast enough. Haha. ;)
So I can just use my TC shifter assembly and transmission shifter on the YJ tranny without any modifications? The only modification I might have to worry about is the floorboard from the TC clocking? I just found another engine and tranny setup from a 91 Wrangler with the 2.5L, with around 140,000 miles. Will this setup fit in my MJ as well? Apparently either the tranny or engine has been rebuilt, but the seller doesn't know which one. How much do you think this setup is worth paying for?
So basically if I use a tranny from a YJ or TJ it will be a PITA? Am I better off finding one from and XJ or MJ?
If I got the bell housing from the dakota, an AX-15 will bolt right in? Are any other modifications needed for that? Any trans behind a Chev 2.8L will work? Do you know any model numbers? Would this bolt right in without any modifications, except the CPS hole? Which would be the best way to go, the dakota bellhousing with AX-15, or the Chev trans, or just stick with an AX-5?
