MiNi Beast Posted February 12, 2011 Share Posted February 12, 2011 well about to go mess with the 4.o puke, have a bad gas leak from an injector, think its the o ring so picked up a set and go from there. fun fun at least its sunny out today. :yes: Link to comment Share on other sites More sharing options...
foreman1063 Posted February 12, 2011 Share Posted February 12, 2011 Don't know if you've messed with injectors before or not but Vaseline is your friend when re-installing the injectors after the new o-rings. :thumbsup: Link to comment Share on other sites More sharing options...
MiNi Beast Posted February 12, 2011 Author Share Posted February 12, 2011 yeah I know, but I to lazy to go back in the house, so warmed them a bit with a lighter, (kids do not try this at home, was done by a redneck certified backyard mechanic) so they in and all is back together, looked like 2 injectors were replaced at one point. Wish I had some 5.0 injectors to install but not in this pos engine, couple more months then I can blow it up. :banana: Link to comment Share on other sites More sharing options...
1990 Pioneer 4x4 Posted February 12, 2011 Share Posted February 12, 2011 yeah I know, but I to lazy to go back in the house, so warmed them a bit with a lighter, (kids do not try this at home, was done by a redneck certified backyard mechanic) so they in and all is back together, looked like to injectors were replaced at one point. Wish I had some 5.0 injectors to install but not in this pos engine, couple more months then I can blow it up. :banana: Do the 5.0 injectors really make that big of a difference? Link to comment Share on other sites More sharing options...
ratrapp Posted February 12, 2011 Share Posted February 12, 2011 not a stock engine Link to comment Share on other sites More sharing options...
JeffN Posted February 12, 2011 Share Posted February 12, 2011 The 5.0 injectors give a much better spray pattern that can help with some extra power and better fuel economy. some people report up to 5mpg gained Link to comment Share on other sites More sharing options...
MiNi Beast Posted February 12, 2011 Author Share Posted February 12, 2011 not really on a stock engine. the idea behind the 5.0 injectors is to deliver more gas, as you have opened it up and have more air going to it as well. I'll be doing a .30 over build with cam on a H.O. motor with bigger throttle body, intake and headers/exhaust, and will be complimenting the combo with 5.0 injectors. stay tuned come spring when I start after the axles are installed. :D Now, installed new o-rings and still leaking bad, and it was what I expected but was hoping not, the injector itself was leaking, the back 2 on the line. I actually had this same thing happen to me back on my first jeep, 89 Wagoneer, must be a 89 thing, :hmm: , so anyways pulled 2 injectors from the intake off the H.O. I just picked up, slapped it in and no more leaks. :wrench: So cased closed on this one. not bad for tickering a bit. :thumbsup: now off to mount winch and groove tire and mount them on their rims as well. :banana: Link to comment Share on other sites More sharing options...
CTswampyankee Posted March 1, 2011 Share Posted March 1, 2011 I installed a set of used 5.0 stang injectors in my renix 4.0. I notisted it runs a little stronger an idles a lot better. My engine is all stock with just a hollow cat, flowmaster, and the injectors. I only put them in since my buddy had them just sitting around. Link to comment Share on other sites More sharing options...
MiNi Beast Posted March 1, 2011 Author Share Posted March 1, 2011 I installed a set of used 5.0 stang injectors in my renix 4.0. I notisted it runs a little stronger an idles a lot better. My engine is all stock with just a hollow cat, flowmaster, and the injectors. I only put them in since my buddy had them just sitting around. Well always good to hear. Glad that they work out for you. :cheers: Link to comment Share on other sites More sharing options...
MiNi Beast Posted March 31, 2021 Author Share Posted March 31, 2021 what a crappy write up and..... Link to comment Share on other sites More sharing options...
fiatslug87 Posted March 31, 2021 Share Posted March 31, 2021 Yes, the OP should be flogged. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted March 31, 2021 Share Posted March 31, 2021 2 hours ago, fiatslug87 said: Yes, the OP should be flogged. On a serious note, for reference, note that most injectors are rated at 3 bar (43.5psi) and not 39psi which is what our stock FPR flows with no vacuum attached or at WOT. 24lb injectors rated at 43.5psi obviously will flow less at 39psi. On my latest build I got some 6 hole 27lb injectors which give me around 24lbs at 39psi. Some Ford injectors are also rated at 39psi but always worth confirming Link to comment Share on other sites More sharing options...
MiNi Beast Posted March 31, 2021 Author Share Posted March 31, 2021 makes sense. i now have them 4 hole version ones and runs smoother. Link to comment Share on other sites More sharing options...
cruiser54 Posted April 1, 2021 Share Posted April 1, 2021 THE HISTORY OF THE 4.0 BEST INJECTORS FOR RENIX AUGUST 6, 2016 CRUISER54 128 COMMENTS The original Renix injectors made by Siemens-Deka were only “one holers”. That means the fuel was discharged through only one hole. Not the most efficient design by today’s standards. Modern injectors have at least 4 spray holes for better fuel atomization. Another issue is the original injectors were prone to leaking fuel at a seam and spraying gas all over hot manifolds. Not good!! A nice upgrade is to use Volvo injectors. The use of these injectors was pioneered by Programbo from Cherokee Forum when he suggested them to DFlintstone there. Flintstone was the guinea pig and reported excellent results. I have experienced the same results as have many others. The 746s, as they’re called, have the 4 hole design and the complete Bosch part number is 0 280 155 746. These injectors can be purchased refurbished for not much money and are a direct bolt-in. WARNING: AVOID THE CHICOM KNOCKOFF INJECTORS!!! BUY ORIGINAL BOSCH/VOLVO REFURBISHED INJECTORS HERE IN THE USA. Trevor.skankfootracing@gmail.com Link to comment Share on other sites More sharing options...
