I've seen a photo of an MJ like that, so at least one person has done it. Those are the pressure-equalizing ports so I'm not sure if it's all that wise of an idea to seal them. on the other had, my trucks all leak like sieves so they may not be that necessary. :dunno:
plus there's the almighty Thunder Chief. :D
There's an MJ in Camdenton that has them removed. I haven't gotten close, hopefully next time I see it I'll be able to stop. But from a distance, it looks ok if done properly.
Hmmmm not sure if I like the look or not... anybody else? I'm worried it'll be too bland there without it.
Like this?
your image didn't show up..
Yellow longbed, with no vents.
tho I had to paste the address in another window to see it.
I did not like them at first and considered the diamond plate idea, but after cleaning things up (and figuring out how they went on) they're growing on me. It definitely makes MJ's easier to identify, as if.
  • 4 weeks later...
  • 4 years later...
I recently saw an eliminator with shaved cab vents, it made me find this old thread. What I'm wondering is if one was to do this would you install a cab vent elsewhere, or would you let it go since our trucks aren't exactly air tight anyways?
Previous owner on my truck shaved the can vents but the truck just doesn't look right without them so I out them back on...but there's a truck here with the can vents mounted on the hood....
http://comancheclub.com/topic/31624-project-silver-and-black/page-7
My truck without the cab vents
I think I like it? Did the PO of your truck worry about venting elsewhere. If not have you noticed any ill effects? In the link i noticed the orange truck with cab vents on hood, but no mention of them in thread? Very cool idea, I'm sure he had to cut and open up the plastic vents surely not just cosmetic?
No he didn't do any extra venting anywhere...he just foam the vents up then primered the whole body including the vents...once I knew sort of how to remove the primer around that area I removed the primer and put the pcs back on....
That build irrc he bought that truck like that from a members(jbain) friend that already had the cab vents into the hood...
so he foamed them up then welded steel over it right, or just foam then primer?
That other truck is cool, may look the build up to see how he done the hood vents.
Would be weird to see one without, they are sort of iconic on these trucks I think and as said make them easy to spot quickly.
