rear axle flip
It won't work. Think about the Diff cover fill hole. Its designed to put a certain amount of fluid in the diff and if you lower it by flipping the axle it won't hold as much fluid and you will burn the gears. Also you have the axle breather tube that will be facing down and dumping fluid.
If you flip the axle over the wheels will spin backwards.
:cheers: Good point the best point of them all :cheers:
The ring gear will end up on the wrong side on the pinion ;) it'll do 70mph backward but only15-25mph forward :rotfl2:
:yes: then you'll have rebuild your engine and starter so it runs backward :rotfl2: :rotf: :yes: :thumbsup:
Mike
my friend keeps telling me if i flip my rear axle and bolt it back up it will give me soa without any welding is that true :dunno:
I would have to say let you friends do this to there truck's, while you do a little cutty cut and some zappy zappy welding and do it the right way.
then see who's truck comes out better.
Mike
Has anybody tried Viagra on their MJ, XJ? Just wondering if they got a 6" lift out of it or not.
Yeah, it works. Only problem is it doesn't last for more than 4 hours..
Recycle it through the a/c lines. :clapping:
