jeepaholic
Everything posted by jeepaholic
exhaust manifold has a crack in it. should I just weld them up and go with it or get a set of aftermarkets?
So I have a 88 model that has been running just fine. Parked it and when came back to it the thing will crank and run for a minute then die. Throttle response is there but will only run for a few seconds. Cranks right back up and does same thing. Checked the bleeder on the fuel rail and have plenty of pressure.. Any suggestions?
it appears to have a leak between the manifold and the pipe...I took it apart thinking there will be a donut gasket..Nope..looks like the pipe is made like a JIC fitting..so now what..I did notice the pipe further back has been smashed significantly which I am sure has increased the back pressure.. Thought of fixing the damaged section and bolting it back together to see..Any thoughts?
could a mucked up steering stabilizer shock cause it...
brand new rotors and even took them and had them checked to make sure they were "true"...plus if it were brake or rotor issue you would feel it at low speeds as well wouldnt you? :dunno:
Ok..its not the death wobble...not the rotors either...but this joker shakes severely at 60+ braking..so much so it feels as if the tires are bouncing off the ground...slow braking no issue...tie rods track bar???or all of the above....
who has good spring packs???
jeepaholic replied to jeepaholic's topic in MJ Tech: Modification and Repairs
:headpop: just talked to hellcreek....6 week lead time til he fires up his oven again..... :headpop: -
how about the ones at Motion Offroad...they have 4.5" lift packs rated at 960# capacity or 1200# capacity for the same price..$375.00 :dunno: -
any other suggestions??they gotem but wow.. :eek: -
finally got fuel pressure, but still no run.
jeepaholic replied to snacob14's topic in MJ Tech: Modification and Repairs
the cherokee pump will not work(as far as i know)...yours sure sounds like what both my MJ's were doing...Replaced CPS, fuel filter, ballast resistor, and finally fuel pump...Waallaaah purrrrred like a kitten...So replaced the pump on MJ#2....Waaallllaaah purred like a kitten... :clapping: -
I need a good set of packs that will equate to about 4.5-5" of lift..already am spring over on a dana 60 axle + blocks...combination of weak stock packs and blocks results in a lot of hop as well as wrap...already know NOT Rusty's.
2MJ's neither stay runnin??????????
the 87 and 88 were both the same...but fuel pump fixed both trucks..what are the odds of 2 at the same time going out.....replaced the 87 and it ran like a top....figured what the hey and replaced the 88....boom it ran too... -
where am i gonna find this part....orielly and ozone both say not available...but they also act like I am speaking pig latin.... -
enlighten me...where the heck is the ballast resistor....and could this be the same problem for the one that barely cranks and spits/spudders?? -
I have an 87 and 88...both have been sitting for a while but they have before. crank run for a few seconds and cut off like you hit a kill switch...one of them cranks like a champ and does this...the other one does not crank so good and just spits and sputters then dies...perhaps the crankshaft sensor on the spittin/spudder but i just put a brand new one on it..gonna try another one on it in case i got a bad one....but the other one cranks runs good then dies....help me :wrench: I am so confused..oh both are 4.0/manual
Anybody have feedback on this air compressor??????
jeepaholic replied to jeepaholic's topic in The Pub
guess nobody has tried one of these...For 480.00 I might go ahead and roll the dice... -
Sold at northern tool...Morgan Series Reconditioned Stationary Vertical Air Compressor — 80 Gallon, 240 Volts, 14 CFM, Model# RE6580A
simple soa question???
I was checking out the kit from rocky-road..it looks like there kit comes with everything but control arms...rough country's kit seems to include everything for 999.95...The two kits look to be about the same price when you add in the optional stuff to equal the rough country... -
Its the original pack (like new) and stock axle...If this is the case and I need to go with 6.5" coils in the front I will also need control arms and transfer case drop right...How about pricing me this and also a set of new motor mounts (4.0) if you can. -
How much lift is a simple rear soa with no blocks gonna create...aproximately...
anybody 4-linked their MJ???
best place to acquire said springs would be??? -
this is how she came back.. -
I am going to put a detroit locker in the front..and also extra leaf in the rear...for the time being...but still thinking of linkin it....the hop was so bad it made me car sick..lol...not to mention it sounded like the engine, transmission, transfercase, and both axles was going to come out from under it..I will post the aftermath pics when i get home
