1990 Pioneer 4x4 Posted October 18, 2009 Posted October 18, 2009 I don’t get it; why does my motor die each time I get into deep water? It happened twice today. High water mark for the day.
Automan2164 Posted October 18, 2009 Posted October 18, 2009 :eek: Just be careful not to hydrolock that thing... ;) Looks like fun. :yes: Rob L.
CWLONGSHOT Posted October 18, 2009 Posted October 18, 2009 Because its NOT DESIGNED as a submarine!!!! :doh: :doh: :doh: Water crossings, need to be done SLOWLY and CAREFULLY. Even then only done if necessary and at KNOWN areas where the depth is not too deep to cause stalling. Personally, I don't go in the water. But the couple times I have needed to, I stop at the top of the tire. Obviously you have exceeded the depth your jeep can cross, find a shallower spot. Better yet... STAY OUT OF THE WATER!!! :yes: :yes: CW
whowey Posted October 18, 2009 Posted October 18, 2009 Where that mark is.. he isn't in danger of hydro locking the motor. Even the opening in the stock intake is higher than that. You have to be careful when entering water to make sure that you aren't going to submerge the engine. Most likely you are shorting out something. Take a look at your block ground. It might be loose, and you lose connection, causing the engine to stall.
comanche87 Posted October 18, 2009 Posted October 18, 2009 Lift it up high if u wanna play in those waters!
mvusse Posted October 18, 2009 Posted October 18, 2009 He might be fine sitting there, but when moving, the truck creates a bow wave in front of it that could easily cover the air intake. A snorkel may be in order.
Pete M Posted October 18, 2009 Posted October 18, 2009 A snorkel may be in order. Look closely. or at his avatar if you can't spot it in the lake pic. :thumbsup:
whowey Posted October 18, 2009 Posted October 18, 2009 i wanna try that There are a couple of places at the Cliff's you can drop in over your hood when its wet....
Pete M Posted October 18, 2009 Posted October 18, 2009 i wanna try that I don't. My trucks are rotting fast enough as it is. :(
1990 Pioneer 4x4 Posted October 18, 2009 Author Posted October 18, 2009 i wanna try that I don't. My trucks are rotting fast enough as it is. :( Thanks Pete, that dose of reality ruined my fun. :(
1990 Pioneer 4x4 Posted October 18, 2009 Author Posted October 18, 2009 Got carpet? Yes, and I’m having troubles getting it dry. Started out bailing, then wet vac, dry rags, and the fan has been blowing on it since last night. It's still wet... What would you do (besides staying out of the water)?
89eliminator Posted October 18, 2009 Posted October 18, 2009 Got carpet? Yes, and I’m having troubles getting it dry. Started out bailing, then wet vac, dry rags, and the fan has been blowing on it since last night. It's still wet... What would you do (besides staying out of the water)? i had a minimal amount of water come through my doors back in spring. i ended up taking the entire carpet out and letting it dry. it took a solid 4 days to fully dry but that partially because of a few humid days.
CWLONGSHOT Posted October 18, 2009 Posted October 18, 2009 That water crossing seemed like fun at first huh..... :doh: CW
Akula69 Posted October 18, 2009 Posted October 18, 2009 There is no way I know of to get the carpet completely dry while its in the truck. The problem isn't the carpet per se, its all the noise and insulating padding they put under the carpet and jute. Best bet is to take it out to dry it.
Pete M Posted October 18, 2009 Posted October 18, 2009 Yup, I would yank the entire carpet out. the padding underneath is what rots our floors.
Jakeman17 Posted October 19, 2009 Posted October 19, 2009 i wanna try that There are a couple of places at the Cliff's you can drop in over your hood when its wet.... I need 4wd first
whowey Posted October 19, 2009 Posted October 19, 2009 i wanna try that There are a couple of places at the Cliff's you can drop in over your hood when its wet.... I need 4wd first No you don't.... unless you actually plan to get through the holes..... :yes:
possum Posted October 19, 2009 Posted October 19, 2009 Don't let them fool you. These trucks are plenty capable with a little lift and just 2wd. I very rarely need pulling out and I keep up with the 4x4s.
Dirteatr717 Posted October 19, 2009 Posted October 19, 2009 take the carpet out and bedliner it Ive been thinking of doing that :brows: best bet is to take it out ;)
freakjeep93 Posted October 19, 2009 Posted October 19, 2009 yea i dint even bother saving my carpet ive already broken the frame on 1 comanche so I'm not takin any chances
Eagle Posted October 19, 2009 Posted October 19, 2009 Once the carpet gets wet, you pretty much have to take it out to dry. Yes, it'll eventually dry in place -- but not before you generate a whole lot of mildew and mold spores, which you will then be breathing for as long as you own the vehicle.
