Twisty Posted July 23, 2006 Share Posted July 23, 2006 So here is my MJ, practicaly the day that she arrived home with us. D44 b*@$£!! It needs brakes, front and rear. Nothing happens when you press the pedal...it goes to the floor. The shift computer is not there. When in D it goes to 4th gear. 1-2, 3, and R work fine. Rear lights don't work either. Minor body work and its as good as new. NO serious rust on the floor, rockers, or frame. Not too bad for $125. My goals are RE 5.5" lift, 35" tires. Link to comment Share on other sites More sharing options...
Twisty Posted July 23, 2006 Author Share Posted July 23, 2006 Ive been picking away at small things over the past few weeks. Ive been spraying the brake lines with PB Blaster so i can take them off, but one of them just snapped in half. now the axle can come out so i can sand/paint it and put some brakes on. Ive also taken out the shift computer out of my XJ, and put it in the MJ. I looked and the fise was gone too, so i changed that and i think its working. onto the pics! how it sat this afternoon... Floors. Only surface rust mind you..nothing has gone through... Pic of rear axle, and a nice little can on PB blaster... Pic of drivers side rocker pannels... Donor XJ... And this is hanging down from the frame. brake lines go to it...then to the axle, what is it exactly? do i need it? thats it for now. thanks for looking. soon i will be taking out the axle, and sand blasting, and painting it. then assembling the brakes on it then putting it back. oh and those wimpy 3 ton jackstands will be replaced by some 6tons that i got today. they are too short and feel un-safe to be under. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted July 23, 2006 Share Posted July 23, 2006 The little dingus hanging down is your rear proportioning valve. It works with weight, the more you put in the bed the gerater breaking in the rear. Here is a thread for you to read. There TONS on here about this. Do a search and youll see what I mean!!! http://comancheclub.com/forums/viewtopi ... ning+valve I removed it and replumbed my entire brake line system. Trouble is you will get full brake power to all wheels, NO BIAS. SO the rears will lock up first because they are lighter. Personally I didnt have any problems with this as most PU's I have owned did simular things. You CAN swap in the prop valve from your donor XJ and call it good. GOOD LUCK, that Jeep look's like its been sitting for some time!!! Nice score w/the D44!!! :bowdown: :bowdown: CW Link to comment Share on other sites More sharing options...
Wildman Posted July 23, 2006 Share Posted July 23, 2006 Twisted - Great find for the $$ :clapping: CW is right about the rear porp valve, I chop mine off and used the Tee at the front porp valve, and after a couple of panic stops, my front wheels lock up, not the rears, with no problems. save your self some time and just cut all of the old break lines, wheel cyls and even the front calper right out, I just did my 89 this way, because of sitting and rotting, and all of the above parts were shot. Parts are cheeper than the time to try to save the old (Advance Auto) have most of the parts on the shelf, Hoses had to be ordered and not bad in price. Also, I found that with the truck sitting for some time, all of the seals in the axels, T-case were all shot (dryed out) and leaking. but you might get better luck with yours. :dunno: This Form here was a great help for me getting it done :bowdown: Good luck, and in no time you will be :driving: your NEW Link to comment Share on other sites More sharing options...
feerocknok Posted July 23, 2006 Share Posted July 23, 2006 What is that bolted on the rear side of your leaf springs? Get'er PB blasted, and post more pics! Good find! Link to comment Share on other sites More sharing options...
Twisty Posted July 23, 2006 Author Share Posted July 23, 2006 What is that bolted on the rear side of your leaf springs? Get'er PB blasted, and post more pics! Good find! hehe good question. he said they were "helper springs" but i don't really see how they do anything. CW...thanks a lot, ill be searching in about 1 minute!! Link to comment Share on other sites More sharing options...
87manche Posted July 23, 2006 Share Posted July 23, 2006 I had"helper" springs too. Seemed worthless to me. I think as you compress the leaf spring the overload leaf cranks on the end of the helper, and keeps it from sagging so much. Link to comment Share on other sites More sharing options...
Twisty Posted July 24, 2006 Author Share Posted July 24, 2006 so tonight, with the help of my brother, we pulled out the rear axle, and i put it on 2 ton jackstands outside. ive ground off the bolts holding on the axle backing plate...now i just need to take the backing plate off. then the sanding/painting/rebuilding of brakes will take place!! sorrry no pics. ill take some soon. Link to comment Share on other sites More sharing options...
Twisty Posted August 29, 2006 Author Share Posted August 29, 2006 sooo little update time. should have the sand blaster working this week, so ill blast my D44 to put back in the jeep. havent decided if I'm going to paint it with POR15 or rustoleum yet. ordered new backing plates from Jeep. from autozone i got... REAR -Drums -Shoes -Hardware kit -Wheel cylinder kit Front -Calipers -Rotors -Pads i still have a few more things to get before i can start...but ill have enough to keep me busy for a long time. Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted August 29, 2006 Share Posted August 29, 2006 I'm doing an entire brake job on my '89 MJ. Rear proportioning valve is going away, I'm going to just plug the hole in the splitter block beside the master cylinder. So far for brakes and tailpipe ive sunk $400 + the $500 I paid for the MJ. I'm lovin' it. The spec's are in my sig. Link to comment Share on other sites More sharing options...
DansGreyMj Posted August 29, 2006 Share Posted August 29, 2006 u should take those light off the roof :eek: Link to comment Share on other sites More sharing options...
87manche Posted August 29, 2006 Share Posted August 29, 2006 u should take those light off the roof :eek: then he'll have holes in the roof. Link to comment Share on other sites More sharing options...
feerocknok Posted August 29, 2006 Share Posted August 29, 2006 u should take those light off the roof :eek: then he'll have holes in the roof. real trucks have lights on the roof. Link to comment Share on other sites More sharing options...
Guest Posted August 30, 2006 Share Posted August 30, 2006 real trucks have lights on the roof. maybe if it was a 1 ton dually Link to comment Share on other sites More sharing options...
DansGreyMj Posted August 30, 2006 Share Posted August 30, 2006 damn this log in feature Link to comment Share on other sites More sharing options...
Pete M Posted August 30, 2006 Share Posted August 30, 2006 Dan, are the cookies on your computer set right? Link to comment Share on other sites More sharing options...
Twisty Posted August 30, 2006 Author Share Posted August 30, 2006 well i brought the axle shafts down to a shop today to have the new backing plates put onto the shafts. there was a collar that was pressed on to the shaft and i couldnt get it off. hopefully it won't cost a lot of money. Link to comment Share on other sites More sharing options...
pingpong Posted August 31, 2006 Share Posted August 31, 2006 That collar has to be cut off, and a new pressed on if I am thinking of the same collar you are talking about. Link to comment Share on other sites More sharing options...
DirtyComanche Posted August 31, 2006 Share Posted August 31, 2006 It can be pressed off and pressed back on. But yeah, takes time. Time is money... Link to comment Share on other sites More sharing options...
pingpong Posted August 31, 2006 Share Posted August 31, 2006 It would have to be a pretty big press, cause my 20ton press would be just abouot impossible to press it off on. They are not that expensive. Link to comment Share on other sites More sharing options...
Twisty Posted August 31, 2006 Author Share Posted August 31, 2006 they replaced seals, bearings, and retainers....cost me $207.02. do you guys think it was worth it? Link to comment Share on other sites More sharing options...
Twisty Posted September 4, 2006 Author Share Posted September 4, 2006 update time...WITH pics! so i got working on that D44 this weekend. on sunday i wirebrushed the living daylights out of it and beat it with a chisel hammer to get the rust off. then i used marine clean, and metal ready to prep the axle. i don't think i did it right tho because there was a lot of white stuff left over after i rinsed off the metal ready, but i cleaned that off and went ahead with the painting. before paint after paint i only got 1 coat done, and i did it late so the dew is now sitting on paint that isnt dry yet :roll: Link to comment Share on other sites More sharing options...
Twisty Posted September 4, 2006 Author Share Posted September 4, 2006 o yeah, and the parts i ordered from autozone for my MJ don't fit. the guy who ownded it before me swapped out an XJ axle and the calipers/rotors/pads are totaly different. Link to comment Share on other sites More sharing options...
feerocknok Posted September 5, 2006 Share Posted September 5, 2006 This is the same axle?! Link to comment Share on other sites More sharing options...
Twisty Posted September 5, 2006 Author Share Posted September 5, 2006 This is the same axle?! not sure what axle you are talking about here, but for the rear, its the same one that i bought the truck with. Before. After. the front axle is a bit weird here. apparently he flodded the axle with water, and he had to replace it, so he replaced it with a different axle that is NOT the same as the MJ axle...so now i need different front brake parts :nuts: i have the origional front axle that came with the truck, because it was in the bed when we towed it home. the calipers/pads/rotors fit THAT axle, but not the axle that is on the MJ now. The axle that is on my 1990 XJ is the same as the one on the MJ so thats how i came to that conclusion. Link to comment Share on other sites More sharing options...
