HOrnbrod Posted December 7, 2014 Share Posted December 7, 2014 Interestingly part #2 is different from my 91 with the valve to the 97-01 hoses. I'm pretty sure the hoses will fit in the little plastic holder though. If they should be swapped you could do it at the heater core end since the nipples are the same. Maybe someone will eyeball a confirm of the routing. The 91 holder might work, But I picked up a new one for the 97+ models at the dealer. It was only about $5 IIRC. P/n 55035933. Or you could always do it like this: Link to comment Share on other sites More sharing options...
MiamiMJ Posted April 9, 2016 Share Posted April 9, 2016 Forgive me for reviving such an old thread. But, also hate to start a new one. The PO has some weird hoses and fittings that don't look like they'll hold up for much longer. So I'm going to swap things out. Can the 97+ hoses also be used on a Renix era ('89; eliminated HCV)? Or do I need to order the heater hoses for an '89 and make a fitting where the HCV was? Thanks. Link to comment Share on other sites More sharing options...
Marine1Texas Posted April 9, 2016 Share Posted April 9, 2016 MiamiMJ, on 08 Apr 2016 - 10:06 PM, said:MiamiMJ, on 08 Apr 2016 - 10:06 PM, said:MiamiMJ, on 08 Apr 2016 - 10:06 PM, said:MiamiMJ, on 08 Apr 2016 - 10:06 PM, said: Forgive me for reviving such an old thread. But, also hate to start a new one. The PO has some weird hoses and fittings that don't look like they'll hold up for much longer. So I'm going to swap things out. Can the 97+ hoses also be used on a Renix era ('89; eliminated HCV)? Or do I need to order the heater hoses for an '89 and make a fitting where the HCV was? Thanks. Just use standard heater hose from the autopart store. I deleted the Heater Bypass Valve. Run the bottom of the bottle to the bottom of heater core direct, from top of heater core direct to water pump. Run a direct hose from thermostat to top of the bottle. You will need only hose's clamps and one 5/8 to 3/4 hose adapter. since top off bottle has that little 5/8 connector. just don't forget to plug the vacuum line that connects to the old bypass valve. I noticed no real difference in temps in the cab from this. I think every thing is under 10 buck to do it. I have no clue if 97+ molded hoses can be used on a Renix! Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 9, 2016 Share Posted April 9, 2016 Of course you can use off the roll heater hose by the foot for this, but the OP asked: Can the 97+ hoses also be used on a Renix era.......... CAN the 97+ molded hoses be used on a Renix? I'd like to know also................... Link to comment Share on other sites More sharing options...
gogmorgo Posted April 9, 2016 Share Posted April 9, 2016 Isn't there some kind of funky setup going from the heater hoses into the surge tank? The '97+ hoses go direct from water pump to heater core. If need be I suppose you could always slice it in the middle and put in a T... But it wouldn't be as clean as what I think the OP is looking for. Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 9, 2016 Share Posted April 9, 2016 Isn't there some kind of funky setup going from the heater hoses into the surge tank? :dunno: There's a lot of funky stuff on a Renix........ Link to comment Share on other sites More sharing options...
DirtyComanche Posted April 9, 2016 Share Posted April 9, 2016 If you convert your Renix to an open system you can use the 97+ hoses. Otherwise you will have to splice T-fittings into them to hook to the expansion bottle. Link to comment Share on other sites More sharing options...
tadchad Posted August 11, 2016 Share Posted August 11, 2016 Forgive me for reviving such an old thread. But, also hate to start a new one. The PO has some weird hoses and fittings that don't look like they'll hold up for much longer. So I'm going to swap things out. Can the 97+ hoses also be used on a Renix era ('89; eliminated HCV)? Or do I need to order the heater hoses for an '89 and make a fitting where the HCV was? Thanks. Did you ever bypass the HCV? can you just use the 97+ era houses, I just got a Comanche and I believe its a renix???? 1987 2.46L, 4 Cyl, TBI 2wd ??? I want to do the same thing on mine because I noticed a small leak the other day, this is my valve: Link to comment Share on other sites More sharing options...
cruiser54 Posted August 11, 2016 Share Posted August 11, 2016 If you convert your Renix to an open system you can use the 97+ hoses. Otherwise you will have to splice T-fittings into them to hook to the expansion bottle. This^^^. Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 11, 2016 Share Posted August 11, 2016 He has a 2.5. Same thing? Link to comment Share on other sites More sharing options...
cruiser54 Posted August 12, 2016 Share Posted August 12, 2016 He has a 2.5. Same thing? I don't think so. IIRC, they were open system. Link to comment Share on other sites More sharing options...
Rockfrog Posted August 13, 2016 Share Posted August 13, 2016 Yeah, the 2.5's were open, and used a coolant heated intake manifold. One hose goes from water pump to core. The other goes from thermo housing to intake manifold, then another hose goes from intake manifold to core. Bulk hose is best here. Sent from my SGH-I337M using Tapatalk Link to comment Share on other sites More sharing options...
Piraterunner9 Posted October 4, 2016 Share Posted October 4, 2016 I'm not getting any vacuum to my valve at all. Where do I go from there? Do I have to pull the fan off? Or does it have anything to do with the adjacent vacuum hose that goes to that little evap ball or whatever it is up front behind the bumper? Link to comment Share on other sites More sharing options...
Piraterunner9 Posted October 4, 2016 Share Posted October 4, 2016 I meant pull the "dash" off. Link to comment Share on other sites More sharing options...
cruiser54 Posted October 4, 2016 Share Posted October 4, 2016 You're getting way ahead of yourself. Make sure you have vacuum at the ball and then at the firewall. Link to comment Share on other sites More sharing options...
