what does this do? its attached to my brake pedal or right above it
ok some things i plan on doing to it over the course of the year:
during the winter I'm gonan do some small upgrades like the sway bar and maybe some minor things inside the cab like hornbrod did in the DIY might try the washerbottle relocation thing if i feel like i can do it.
bed liner
dry box
bed caps
custom bush bumpers if i can get my friend to help me weld them up.
still trying to find out what i need to lift it.
gonna put a 8.8 with discs (do i need to modify the master cylinder and the brake booster ?)
bush wackers
new paint job
33's
rock rails
rear locker then one day front locker
I'm new to all this stuff I'm used to building stuff like beat up 100 dollar cars and going and making them dune buggies till they break but this is different i really like this truck liek we all know how much we love are comanche's ive been looking for one for like about a year now and i finally found one once i got the money this time. now I'm starting my lift the comanche fund also the send pete his money fund so i don't get knee capped.
i like to ask alot of questions as some of you might have learned but i want to do a trip through the states in 1 or 2 years after ive started my apprentiship in heavy duty mechanics. so any help and advice would be great.
i also wanna thank goblazers_6 he went and looked at the comanche before i drove down to the states and bought it.
No problem. But you still owe me a case of beer.
I've been waiting for you to post up some pics on the site. That is a perfect MJ to start a build with. Have fun! :cheers:
  • 1 month later...
i painted up my valve cover it was leaking anyways. i also have my rear bumper made and started on my front just need to paint it then i'll post some more pictures
  • 1 month later...
just did my headliner gonna get seat covers next
the other side
here's my bumper i made
got 2 side pictures
here's a far back photo
I'm going to paint it green this summer and hopfully have a lift kit in it
Do those "dangly bits " on the rear bumper change color with the seasons ?...blue=winter ,green=spring ,yellow=summer ,brown=fall :dunno: Looks like a good project :popcorn: :thumbsup:
I think they change to blue when it hasn't been used in a while. :chillin:
:yes: :agree:
nice truck.
whenever I see truck nuts, I go grab a piece of sticky printer paper, cut a chunk off, and write "I'm ghey" on them then stick it to the nuts.
truck nuts are just stupid. I got a set of chrome ones if anyone wants something to throw in the fire pit and make big sparks.
nice truck.
I don't care about truck nuts either way, but a buddy of mine had them on his Ranger that was on air. Yeah he went around town draggin his nuts everywhere......but one day he drug them off..... :( ...he hasn't been the same since...
  • 1 year later...
some new old pictures from when i was down the Duffy on a road trip.
this was a really nice blue lake forget the name of it.
this bridge has bats all over the bottom of it so your not allowed to drive it anymore
put the canopy on but I only like to use it on trips and camping.
rear view of the canopy
also updates on the Comanche are found out its not the clutch going so now I have to go over it and figure out what it could be that makes it run like $#!&. thinking maybe clogged catalytic converter or TPS. i also took the o2 sensor off and it just would not start.
sweet little truck man, and nice to finally get a real look at it. i really like that rear bumper too.
nice truck.
And gross. I don't get it. Nice truck but the plastic male genitalia ruins it for me. It's like a picture of a hot chick with some dude standing next to her with his junk hanging out. Ruins it.
well i fixed up my battery cables bit thicker then the stock ones
didn't have any battery cable so i took it off my old 6000 pound warn winch
I also got around to fixing my fuel pump which was the cause of all my problems it was a Napa pump that ended up working after i went to every place in town and none had the right pump the part number was e7006 from Napa
Here's a picture of the old pump and the new pump comparison
Top view
side view
i had to modify it a bit but it wasn't hard i also as you can see in the picture converted the leads to the top to bolt on instead of clip on it came with 2 little clips to make it the clip on type but i did not like it
here is the top that bolts to the sending unit the rubber piece I used a gasket hole punch to make it nice
here is it after i modified it
i don't have any pictures but the kit came with two spacers i used the ones off the old Bosch pump and cut a bit of the bottom out so it would fit nice in the bottom of the sending unit also but its all back in the tank and my truck has never ran better
  • 8 months later...
Just a few new pictures of the truck
You will be all happy I replaced the balls with a moose
also have been doing some work on truck I bled the clutch and fixed my front crank seal as well as replaced my balancer but new one will not fit.
new one is on right
here is the difference between the two
new
old
and the reason I went with a new balancer
  • 3 months later...
Well had a minor accident when offroading and ended up with some front end damage.
This was in process
and finished product
Was very happy on look of hood when I painted it.
