robfg67 Posted January 19, 2011 Share Posted January 19, 2011 Brent, Jeep manufactured the YJ 1995 model year long and introduced the 97 TJ early so their really wasn't a time you couldn't go in and buy a new Wrangler. And for extra points...Jeep was dropping the 4.0L into the YJ, ZJ, and the XJ in the mid 90's. The engine manufacturing plant couldn't keep up with the demand so they put the engine on restriction for almost the entire 1995 model year of the YJ. :fs1: Link to comment Share on other sites More sharing options...
jamespwsullivan Posted July 6, 2012 Share Posted July 6, 2012 I've been plunking around the Internet-forums and such-and I ran across the acronym WMS. Somehow it refers to measurements of axles and I think it's about the width. I'm pretty dull in the head right now (two nephews visiting-boy do they have a lot of energy!) and I can't figure out what WMS stands for. Anyone? Link to comment Share on other sites More sharing options...
drcomanche Posted July 7, 2012 Share Posted July 7, 2012 Wheel Mounting Surface Link to comment Share on other sites More sharing options...
jamespwsullivan Posted July 8, 2012 Share Posted July 8, 2012 Thanks. And now that I know this it makes so much sense! Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 27, 2012 Share Posted August 27, 2012 Jeep Model Acronyms Bantam Pilot Model - 1940 BRC-60 - Bantam model - 70 produced BRC-40 - American Bantam Jeep for military BRC-40/4WS - Bantam 4 wheel steering Jeep model BRC-40 Checker - Checker's take on the Bantam design Quad - Willys design prototype - 1940 Pygmy - Ford's design prototype - 1940 CPJ - Chevrolet entry proto for the Military design group Mark II - Bantam production 1940-1941 MA - Willys production Jeep for the military 1,553 produced - 1941 GP - Ford's Jeep that the military ordered 1,500 of eventually 4,456 were produced - 1941 BRC-40 - Bantam's Jeep turned into the military 1,500 but in the end 2,605 were produced - 1941 MB(1) - Willys second generation Jeep design (the model produced in 1941 had a welded grill and 25,808 were produced) MB(2) - Willys second design that incorporated the Ford designed stamped grill - 335,531 were built GPW - Ford's Jeep built on Willys design specs, the breakdown of the designation is "G" Government, "P" Ford's designation for 80" wheelbase "W" Willys design 277,896 were built from 1941 - 1945 GPA - Ford's Amphibious Jeep 12,778 were built from 1942 - 1943 "A" fpr amphibious M-38 - Willys gov design of the CJ-3A from 1950 - 1952 only 61,423 were ever produced M-38a1 - Willys government design that would mostly resemble the CJ-5. 101,488 were produced from 1952 - 1957 M-170 - Long wheelbase Military Ambulance M-151 - MUTT ("Military Unit Tactical Truck") built from 1959 - 1978 M-718 - Ambulance version of the M-151 M-422 - Mighty Mite. Aluminum Marine Corps Jeep, air cooled V4 lightweight M-422A1 - Longer wheelbase version of the Mighty Mite M-606 - The Jeep M606 was a military version of the Jeep CJ-3B, built 1962 M-606A1 (12v) and M606A2 (24v), M606A3 Designed after the CJ-5 both for US Armed Forces and Export from 1965 through 1982 M-676 - FC truck the M676 (or type I) was a two door pickup which differed very little from a stock FC-170 M-677 - FC truck The M677 (type II) was a four door crew cab pickup having the same 103" wheelbase and thus a shorter pickup box M-679 - FC Marine Ambulance M715 - Kaiser-built military pick-up truck, similar to the Gladiator J2000 - J4000 trucks M-725 - military field ambulance CJ-V35 - Military custom order. Cross between MB, M38, CJ-3A. CJ-V35/U 1000 modified CJ-3As were produced for the U.S. Navy as the underwater vehicle XM-170 - Experimental cousin of the CJ-4 CJ-2 (Agrijeep) - Willys first commercial bid for the gen public, mostly in farm use CJ-2A - Willys second production Jeep for the gen public, 214,202 were built from 1945 - 1949 CJ-3A - Willy third design, this Jeep had 131,843 produced from 1949 - 1953 CJ-3B - Willys design this was much like the CJ-3A only the hood was much taller. To accommodate the F-head. 155,494 were produced from 1953 - 1968 CJ-4 - The missing link as some would call this one, it is an early design of what would become the CJ-5, only one is known to still exist CJ-4 (Mahindra and Mahindra) - a long CJ-3B built in India FC 150 - Jeep Forward Control Truck, based on the 81" wheelbase CJ-5 initially. FC 170 - Longer wheelbase (103.5) Forward Control truck, used Super Hurricane I6 CJ-5 - Willys (Kaiser) made from 1955 - 1970, then AMC took it from there and built them till 1983 when among criticism about getting tough on high rollover risk AMC reluctantly decided to drop the short base model form its lineup. in the end over 600,000 of them were produced CJ-6 - Willys (Kaiser) 1956 - 1970 and AMC 1970 - 1981, this one has a 101" wheelbase. From 1976-1981 they were export only. The only production number I have is 50,172 which sounds awful low to me for that many years CJ-5A/CJ-6A - Kaiser Elevated the Tuxedo Park package to a separate model in 1964 ended ? CJ-7 - Built by AMC starting in 1976, this Jeep had 93.4" wheelbase and had many offspring to its design CJ-8 - this AMC design was known as the Scrambler, it has a 103" wheelbase and with the half top took on a truck type look. built from 1981 - 1985 27,792 were built CJ-10 - 3/4 ton CJ Truck, export mainly to Australia CJ-10A - Aircraft Military Tug in the United States DJ-5A - Jeep built 2 wheel drive for mostly Postal delivery, they did also built a DJ-8 similar to the CJ-8 YJ - Wrangler, Started by AMC in 1986 and taken over by Chrysler in 1988, 632,231 were built up until 1995 TJ - 1997 - 2006, Jeep Wrangler TJ-L - Long wheelbase TJ available for overseas military use LJ - 2003 - 2006, Wrangler Unlimited KJ - Jeep Liberty XJ - Jeep Cherokee VJ - 1949 through 1951 original 2WD Jeepster ZJ - Jeep Grand Cherokee 1993 - 1998 MJ - Comanche - 1984-92 - compact pick-up FC - Forward Control Jeep Van Trucks FJ-3 and FJ-3A - Fleet Vans FJ - Eagle Talon WJ - Jeep Grand Cherokee 1999 - 2004 WK - Jeep Grand Cherokee 2005 - SJ - Denotes the full size Grand Wagoneers and Trucks 1963 - 1993 XK - Jeep Commander JK - Jeep Wrangler, 2007 - present Link to comment Share on other sites More sharing options...
shaved ice Posted September 11, 2013 Share Posted September 11, 2013 SOA - Spring Over Axle Link to comment Share on other sites More sharing options...
mvusse Posted September 11, 2013 Share Posted September 11, 2013 KK Jeep Liberty is now out. FC is mentioned toward the end, but FC150 and FC170 are already mentioned separately earlier. Link to comment Share on other sites More sharing options...
mvusse Posted September 11, 2013 Share Posted September 11, 2013 SOA is covered in the very first post of this thread. Link to comment Share on other sites More sharing options...
shaved ice Posted September 11, 2013 Share Posted September 11, 2013 Hey, I am new here. What do you expext? :) Seriously though, I was looking for it because I didn't know what it was when I saw it on the forum. Once I found it (thanks google), I realize I had done an SOA on one of my trucks before the internet was out. Link to comment Share on other sites More sharing options...
mvusse Posted September 11, 2013 Share Posted September 11, 2013 On 9/11/2013 at 12:01 PM, shaved ice said: Hey, I am new here. What do you expext? :) Seriously though, I was looking for it because I didn't know what it was when I saw it on the forum. Once I found it (thanks google), I realize I had done an SOA on one of my trucks before the internet was out. :thumbsup: Link to comment Share on other sites More sharing options...
dj5 Posted November 22, 2014 Share Posted November 22, 2014 DJ is dispatcher jeep Link to comment Share on other sites More sharing options...
cruiser54 Posted October 17, 2015 Share Posted October 17, 2015 YJ was called Yuppy Jeep when it first came out. Link to comment Share on other sites More sharing options...
texasjack Posted April 2, 2017 Share Posted April 2, 2017 THANK Y'ALL VERY MUCH THIS IS VERY HELPFUL TO AN FNG. Those of us who were "in country" will know that one. Texasjack Link to comment Share on other sites More sharing options...
carnuck Posted March 18, 2018 Share Posted March 18, 2018 On 1/16/2009 at 7:54 PM, BLHTAZ said: This is a basic list without going in to all the sub-catagories of the CJ & FSJ's... CJ - 1941 - 1986 DJ - 1954 - 1986 (different models and drivetrain designated by the last number and following letter) SJ - 1963 - 1992 (AKA FSJ) FJ - 1961 - 1965 MJ - 1986 - 1992 (Comanche) XJ - 1984 - 2001 (Cherokee and ‘84-90 Wagoneer Limited ) YJ - 1987 - 1995 (Wrangler) TJ - 1997 - 2006 (Wrangler) JK - 2007 - present (Wrangler) ZJ - 1993 - 1998 (Grand Cherokee) WJ - 1999 - 2004 (Grand Cherokee) WK - 2005 - present (Grand Cherokee) KJ - 2002 - 2007 (Liberty) KK - 2008 - present (Liberty) MK - 2007 - present (Compass / Patriot) XK - 2006 - present (Comander) This is the basic list I have in my head from being in dealership parts for several years. :cheers: I straightened a few out. Here’s the bigger list. https://en.m.wikipedia.org/wiki/List_of_Jeep_vehicles An example of the postal delivery Jeeps DJ-5G ‘78 to ‘80 was a carbureted 2.0L VW Audi motor with custom 904 automatic. I had one I was going to hook up to a VW/Audi 5 cyl diesel but my wife hated the ex- Ice Cream truck! Volvo used that motor with their version of an AW-3 transmission. I don’t think they got the Overdrive AW4 version. Link to comment Share on other sites More sharing options...
carnuck Posted March 18, 2018 Share Posted March 18, 2018 On 5/1/2009 at 10:39 PM, gogetemturbo said: How about wheel bolt patterns: CJ - 1941 - 1986 5 on 5.5DJ - 1954 - 1986 years 5 on 5.5?? Some 2wd ones were 5 on 4.5 with 14” Rambler wheels in the early years. SJ - 1963 - 1992 EDIT 6 on 5.5’63 to ‘73 were 5 on 5.5 except 1 tons (8 lug) and M715/M725s. FJ - 1961 - 1965 (Forward Control)??bolt patternMJ - 1986 - 1992 (Comanche) 5 on 4.5XJ - 1984 - 2001 (Cherokee) 5 on 4.5YJ - 1987 - 1995 (Wrangler) 5 on 4.5TJ - 1997 - 2006 (Wrangler) 5 on 4.5JK - 2007 - present (Wrangler) 5 on 5ZJ - 1993 - 1998 (Grand Cherokee) 5 on 4.5WJ - 1999 - 2004 (Grand Cherokee) 5 on 5WK - 2005 - present (Grand Cherokee) 5 on 5KJ - 2002 - 2007 (Liberty) 5 on 4.5KK - 2008 - present (Liberty) 5 on 5MK - 2007 - present (Compass / Patriot) 5 on 4.5??XK - 2006 - present (Comander) 5 on 5 Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
JimmysJeep Posted May 22, 2018 Share Posted May 22, 2018 This helps with a new Clubber on here! Link to comment Share on other sites More sharing options...
