texasjack
Everything posted by texasjack
  1. Rust Free Doors
  2. Brett I have pixs on Craigs under Jeep Parts.
  3. Kerry did not get the PM. SOLD Jack
  4. I am swaping the axle shaft on the left. I checked the bulkhead label and it had a 4.0 engine. Thank Y'all for the help!!!!!!!! Jack
  5. My 90 has a bent left rear axle. Will an 87 axle fit in the 90? The 90 is an automatic with 4.0 engine. The 87 is standard with 2.4 engine. Thank you Jack
  6. I have a 90 eliminator 6cyl automatic, stock and I am in Aledo, TEXAS
  7. texasjack
    Servo Oring
    I need an oring for the servo on a 90 model 2 wd, if anyone has one please let me know. Thank you Jack
  8. I just pulled a 4.0 out of my 90 MJ and I have all the engine brackets. Jack
  9. Thank you, I found one. The left and right are the same, the right one pulls to release the left one pushes to release. Jack
  10. I need a driver's side hood latch. Please let me know. Thank you Jack
  11. Thank Y'all for the advice. It sounds like if you take the replacement engine down to the long block stage it will work.
  12. Today when I was driving my Jeep the engine blew. I have located a rebuilt 96 cherokee with a 15000 engine for $800 asking price. The rear end is out of it. My question is will that engine work in my 1990? Thank you Texasjack
  13. I am looking for a spare tire hoist for my 1990 Comanche. If you have one please contact me @ pajack1939@sbcglobal.net
  14. Today i discovered one of my rear wheels is bent. I would like to get a wheel to replace the bent one. It is the factory 15 inch alloy wheel with 10 spokes. If you have one please contact me. Thank you TEXASjack
  15. Thanks I will try it without the blockage.
  16. I am installing a new dryer on my 1990 Comanche and there are two spring loaded plungers in the dryer connection. Do I need them and will the system work without them?
  17. If anyone needs A/C parts use Universal Air Inc. ask for Shelly Barnes and use your shop name, I am sure we all have a shop name. They are direct importers and they are on Heritage Parkway in Mansfield, TEXAS. South of Ft. Worth, TEXAS. They ship. I just purchased a NEW compressor for my Jeep for $90, the suction hose was $7.70, the expansion block was $10. They have an online catalog. Shelly is a nice lady. Texasjack
  18. Which relay in the relay panel is the A/C relay? I have no power to the A/C compressor clutch. HELP!!!! Thank you Texasjack
  19. texasjack
    Texans?
    Aledo, TEXAS 3 miles west of Ft. Worth I am working on a 1990 Automatic, 4.0 engine, A/C, faded red, SWB. When I bought it it was in a coma but is alive now. This is the most friendly club on the net!!!!!!!!!!!!!!!!!!!!!!! Jack
  20. My 1990 4.0 runs great when it is cold but when it gets to operating temp it has a rough idle. I put new plugs, wires and number one fuel injector. Checked compression and it is 145PSI. And suggestions would be appreciated. Thank you Texasjack
  21. Go to Craigs and purchase a running Cherokee, use the engine and sell the remaining parts. I see them for 500-900 complete jeeps. Texasjack
