BookspanS Posted September 17, 2008 Posted September 17, 2008 What axle do I have? And also, do I need this to stay? Cause if I don't then my dad and I are gonna build something in its place....No plans for a spare carrier under, gonna save for the baja carrier
XJGPER Posted September 17, 2008 Posted September 17, 2008 Dana 35, if you don't want a spare take the spare holder out :)
BookspanS Posted September 17, 2008 Author Posted September 17, 2008 Dana 35, if you don't want a spare take the spare holder out :) Ok thanks, and good, cause I am in the process of doing that now :brows: . Now i can think about stealing my dad D44 from his jeep :nuts:
BookspanS Posted September 17, 2008 Author Posted September 17, 2008 This is what I came out with after the work And is this a D44 by any chance?
XJGPER Posted September 17, 2008 Posted September 17, 2008 No, you should send it to me and i'll inspect it closer.... Thats paydirt there buddy.
BookspanS Posted September 17, 2008 Author Posted September 17, 2008 No, you should send it to me and i'll inspect it closer.... Thats paydirt there buddy. Well, its going to the dump sometime tomorrow (what i pulled from under it) and that axel is sittin under my dad's JK
XJGPER Posted September 17, 2008 Posted September 17, 2008 Dana 44's are rare but not impossible to find. I've found 4 of em from the local pick n pull. I bought one XJ for $75 that didn't have a strait body panel on it and it had a D44 under it... I can usually peddle d44's for 400-500 each around here on craigslist. Dave
maddzz1 Posted September 17, 2008 Posted September 17, 2008 No, you should send it to me and i'll inspect it closer.... Thats paydirt there buddy. Well, its going to the dump sometime tomorrow (what i pulled from under it) and that axel is sittin under my dad's JK I don't think it will be a direct swap from the jk to the Mj, but i am not sure.
fiatslug87 Posted September 17, 2008 Posted September 17, 2008 This is what I came out with after the work If you don't want the tire carrier put it in the Classifieds. I remember someone looking for one.
Pete M Posted September 17, 2008 Posted September 17, 2008 No, you should send it to me and i'll inspect it closer.... Thats paydirt there buddy. Well, its going to the dump sometime tomorrow (what i pulled from under it) and that axel is sittin under my dad's JK I don't think it will be a direct swap from the jk to the Mj, but i am not sure. Different wheel bolt patterns.
Chico Posted September 17, 2008 Posted September 17, 2008 No, you should send it to me and i'll inspect it closer.... Thats paydirt there buddy. Well, its going to the dump sometime tomorrow (what i pulled from under it) and that axel is sittin under my dad's JK I don't think it will be a direct swap from the jk to the Mj, but i am not sure. Different wheel bolt patterns. What else besides that and the "you need to cut/grind/weld the spring perches on. I saw Mopar now sells em for new JK's. Technically, would it be possible to use these on an MJ. Sorry for the Hi-jack.
Pete M Posted September 18, 2008 Posted September 18, 2008 Yes. In fact I read that the front control arm mounts are actually pretty darn close to the MJ/XJ/ZJ/TJ mounts and will work. I can't verify that, it's just what I read online. The rears would need to be cleaned off and leaf perches added. The wheel bolt pattern would be 5 on 5", so you'll need new rims. You'll need the proper flanges for the driveshafts, adapt the brake lines, wire in switches for the lockers, etc.
Pete M Posted September 18, 2008 Posted September 18, 2008 65" wide if I remember right. 2" wider on each side.
BookspanS Posted September 18, 2008 Author Posted September 18, 2008 Wow :eek: .....and my dad just wanted to know if he had a D44 or not
Sir Sam Posted September 18, 2008 Posted September 18, 2008 Yes. In fact I read that the front control arm mounts are actually pretty darn close to the MJ/XJ/ZJ/TJ mounts and will work. I can't verify that, it's just what I read online. The rears would need to be cleaned off and leaf perches added. The wheel bolt pattern would be 5 on 5", so you'll need new rims. You'll need the proper flanges for the driveshafts, adapt the brake lines, wire in switches for the lockers, etc. The front control arms are basically the same setup as is on the TJ XJ MJ ZJ WJ......... For about $850 you can get a new front axle with brakes, locker, 4:10s etc etc. I think the rear was either $1000 or 800 for the rear w/brakes, 4:10s locker etc. EDIT: Also, you can get JK wheels and tires pretty cheap. JK moabs generally sell for less than TJ moabs, no one needs the 5x5 bolt pattern yet, so there are many wheel and tire sets out there without a home. For someone doing a buildup wanting nice drivetrain parts they are a decent option for something new geared, and locked.
Motion Offroad Posted September 18, 2008 Posted September 18, 2008 For about $850 you can get a new front axle with brakes, locker, 4:10s etc etc. I think the rear was either $1000 or 800 for the rear w/brakes, 4:10s locker etc. Where are you getting these prices? Cheapest we've been able to find is ~$1300 for the front and ~$1200 for the rear. And that's getting a "deal"...
pingpong Posted September 18, 2008 Posted September 18, 2008 Yeah those prices are way low, and then you still have to have the shipped
BLHTAZ Posted September 18, 2008 Posted September 18, 2008 For about $850 you can get a new front axle with brakes, locker, 4:10s etc etc. I think the rear was either $1000 or 800 for the rear w/brakes, 4:10s locker etc. Where are you getting these prices? Cheapest we've been able to find is ~$1300 for the front and ~$1200 for the rear. And that's getting a "deal"... That is correct. I qouted a set of them the other day to a friend of mine that wants to put them under a TJ and it was about $1500 front and $1400 rear. They have also stopped building them with brakes now too. There are still some out there with the brakes on them, but all of the ones being built now will not have brakes on them, but the price is still the same.
Sir Sam Posted September 18, 2008 Posted September 18, 2008 For about $850 you can get a new front axle with brakes, locker, 4:10s etc etc. I think the rear was either $1000 or 800 for the rear w/brakes, 4:10s locker etc. Where are you getting these prices? Cheapest we've been able to find is ~$1300 for the front and ~$1200 for the rear. And that's getting a "deal"... I will make a call today and find current pricing.
BLHTAZ Posted September 18, 2008 Posted September 18, 2008 If it helps with anyones search, here are the part numbers for the JK D44 axles... Front - P5153825AB Rear - P5153826AB If you can find the ones without the "AB" on the end, they will likely still have the brakes on them, but the "AB" denotes the new versions without. :cheers:
Sir Sam Posted September 18, 2008 Posted September 18, 2008 Just got off the phone. p5153826ab - $1155(my price) He can't pull up the info for the new front end yet, if the pricing is the same as the old one it will run me about $975
jtdesigns Posted September 18, 2008 Posted September 18, 2008 If it helps with anyones search, here are the part numbers for the JK D44 axles... Front - P5153825AB Rear - P5153826AB If you can find the ones without the "AB" on the end, they will likely still have the brakes on them, but the "AB" denotes the new versions without. :cheers: AB = anti-brakes :popcorn:
BLHTAZ Posted September 18, 2008 Posted September 18, 2008 If it helps with anyones search, here are the part numbers for the JK D44 axles... Front - P5153825AB Rear - P5153826AB If you can find the ones without the "AB" on the end, they will likely still have the brakes on them, but the "AB" denotes the new versions without. :cheers: AB = anti-brakes :popcorn: :laughin: Not quite...It's just Chryslers way of telling us (dealership) that something has changed. The only two reasons that Chrysler updates a part number like that are a physical change being made to the part (brakes removed) or a change of supplier (no change...still Dana).
