ComancheKid45
    3
Everything posted by ComancheKid45
  1. Yeah basically.....not much difference unless its a decent length
  2. Is this the fairly heavly damaged truck for the accident? that could be an issue with driving it... :dunno:
  3. Thats possible.....basically i was just running an open Cat b/c there wasnt much to my 18" glasspack.......but i defently noticed a loss of power with that setup. Theres nothing qwrong with building anythng big, I'm sure different setups perform different for different people
  4. Well i can tell ya if you run basically just a straight pipe exhaust youll notice a loss of power when you really need it.....like climbing a mountain on a main road or something along those lines, Itll make alot of noise but i noticed very sluggish performance
  5. Ditched the 18" glasspack after only a month and replaced it with a Raptor muffler. Should have my PA speaker for my CB here soon also to install
  6. Alright well i installed my new muffler today......the Sound is still good but quieted down a bit, but my low end Seems 2 be back! :yes: ill see what effect it has on Fuel mileage as well :smart:
  7. Id rather have a Brute.....or better yet, a COMANCHE! :bowdown:
  8. Alright well here is what i found at 1st glance (thi is taken fron lying underneath it)......it was kinda cool locking up the rear wheels only on my slick driveway and pullin 180s but i knew it wasnt suppossed 2 do that....lol, idk how long its acctually been like this 2, it had 2 of been this way for a good while And here's my fix.....i have no idea where the bar went that connects to the axle so zipties will have 2 work for now...ill keep an eye on it, it should be fine. its pointing to the right as mentioned
  9. Alright well just outta curiosity i decided to finally look at my rear proportioning valve and it seems someone has messed with it before.....the arm in sitting straight pointing up and wired tight (mechanics wire) around the bracket. Would this cause the rear tires to lock easyer and produce somewhat poor braking? I can easly adjust it but its defently not pointing to the right like the pic shows and its been in that posistion for along time...
  10. Cool....I just picked up a Turbo Style muffler online and will get that installed later this week, anyway I'm thinking about reversing my glasspack (its directional) tomarrow for the heck of it & see if that changes anything and also should i put a peice of pipe through my gutted Cat or just leave it hollow and open?
  11. Alright well I'm digging up this topic again, i did hollowed out the glasspack and installed my 18" Glasspack alittle over a month ago and I'm going back to a muffler setup.....i love the sound but as mentioned low end power is GONE! lol its quite a turd at low RPM and gained very minimum power up high. I would suspect this is due to almost no backpressure. My Lesson is learned and my fix will be to keep the cat hollowed out but install a close to standered muffler to revive some backpressure which should restore most of my Low end torque that has dissapeared. Anyway if this question ever comes up for anyone here's a 1st hand answer, ill let ya know if anything changes after the new muffler install. Hollowed Cat+Glasspack= Awesome sound/ NO POWER! :no:
  12. I have 6 months on my Motion Offroad Budget Boost with no problems...
  13. I shoved an old Steering bearing outta 1 of my Quads under the support.....that seemed 2 have solved it for a few weeks now.....lol
  14. Yeah i had heard on some trucks (not all MJs) that removing the front valance under the front end can/may result in cooling issues b/c of the air flow disruption, i started a topic in the Tech Section and were discussing it a bit more. Thanks for the answer though :thumbsup:
  15. Yeah i like the look better with the cuts as well.......let me know where the best place to get pocket style Bushwackers is when ya get a set. I might dig into this early in the week, thanks for the input
  16. Alright I have 1.5" and 30x9.50 tires on 4.75" bs wheels.......would it be wise for me to keep it then?
  17. I know ive seen a few trucks with the front valence removed, mainly when an aftermarket bumper is added. My question is can or will this cause any overheating problems with obstructing the airflow on our trucks. I'm thinking of cutting my front flares at the Front bumper and removing that valence. I just want to make sure it wouldent cause any major problems with highway trips and so forth. Thanks! here's a picture of what I'm talking about, thanks to "Reason46" for this pic and idea
  18. I Ordered 4 Steel Wheels with Centercaps and Lugnuts for under $300 from Summit...
  19. I know this picture was from back with the stock bumpers but i like how you cut the front flares and eliminated that valance underneath the bumper. My Question is if you did any extended trips and did that valance missing cause any overheating issues or any issues in general......let me know whenever, thanks! :thumbsup: O Yeah the Truck is awesome!
  20. Done it numerous times and ill do it again! Geez those people are dumb :nuts: :fool:
  21. I added 1 final set of Aux. lights to the back of mine yesterday.....not its my Fathers YJ who up next for lights :clapping:
  22. I got it
  23. 4.0 AW4 I usually get about 11-12 city and 15-16 hwy but I'm on 30x9.50 tires with 3.55 gears and the stock speedo gear so id imangine its alittle bit better than i calculate
  24. 2 bad i can't drive like either 1 of em....lol :doh:
  25. LMAO you asked for it!
