neohic
Moderators
    2
Everything posted by neohic
  1. I’m on the hunt for a new head unit for my Eliminator and I love simplicity. Don’t think I’ve bought a new radio since 2005?… I’m a bit out of touch. What are the cool kids running these days? Here’s what I’m looking for: Auxiliary input that charges an iPhone would be nice Looks somewhat period correct if it’s got buttons and not like a spaceship Looking around online, I can easily find a ton of cheap junk. Right now I’m leaning towards the Power Acoustic CP-71w because it nearly looks like blank block off when it’s off, and I’m familiar with how it functions already being my ‘18 Ford Focus also runs on CarPlay. Are the usual manufacturers still the good ones or is there some whiz-bang units from cheaper sources that I don’t know about? Thanks, all.
  2. Drove to work the other day and made a mental list of creature comfort updates. I think I need to take a look at what it’ll take to clean up the original seats (maybe seat foam, back rest handles, and the little plastic deals and frames to make them flip forward?) and figure a different radio. The auxiliary input I added to the factory radio worked… and then it didn’t. Always something.
  3. That time of year again to put on the winter coat.
  4. PSA: When you change your fuel pump, make sure the new assembly o-ring is the same size as the old one otherwise your tank will leak… a lot.
  5. Posted this morning. It’s in a SEMA walk around video.
  6. From Finnegan’s Garage YouTube, @OffGridResearch
  7. Time for a VERY overdue day in the shop. When I first brought this truck home from its long storage slumber it sat for a little while longer because it needed the transmission pulled to change the input seal behind the torque converter. Was that all it needed?… nope. First in the list was pulling the fuel pump. Last winter it served daily driver status because the usual daily needed a water pump. The car was still under warranty which meant that it sat at the dealership for a couple weeks. Sadly, the truck let me down in terms of stumbling and dying a few times but I completely understand that this was my fault. Now that winter is rolling around again (we had 24” of snow fall over the past few days!), I figure it’s time to get it back to “reliable” status. What’s in the tank?…besides what’s left of last January’s gas?… … surprising not much. I was expecting to find a small, scummy pond! As for the pump assembly, I think I found where the stumbling was coming from. Classic case of a collapsed fuel line out of the pump along with an embarrassingly disgusting sock. Threw a new Carter pump and sock in the sending unit and even reused the high-speed, custom hose clamp I used to keep the pump together in a parking lot WAY back in 2006. Felt like bad luck to get rid of it! Next in the list was the lack-luster brakes. Again this was my fault. Cue the capital letters again, WAY back in 2010 when the truck was coming together again for its third life I never did anything but add a zip tie to the rear brake proportioning valve to get more juice to the rear disks… that was never actually enough. I did the typical delete and plugged the line from the distribution block. Will I need a prop valve with the rear disks?… stay tuned. A while back, Don had this same setup with good results. With the prop valve out if the way, we can clearly see the red overspray on the rear harness, the cheap Gabriel shocks that are surprisingly still hanging in there 14 years later, and the lack of bump stop extensions. Maybe some addition shop time on more upgrades? Maybe… maybe… Need to leave a little meat on the bone, ya know?
  8. Reach out to @500 MJ. I’d bet he still has boxes of them.
  9. There’s some good DIY shifter tech within the first few posts of this thread:
  10. I love this truck!! Can’t wait to see where this goes next. VERY well done, sir!
  11. Thanks, fellas!
  12. Passed my inspection! 98% done though. The front door isn't happening this year but I do need to make a door for the crawl space. Very pleased with it!
  13. Some good rear sway bar info here using a Blazer rear bar and axle brackets along with WJ links and chassis brackets:
  14. Those seats are long gone. I never mounted them in anything so I traded them away years ago.
  15. Time warp back to 2011, I tried a vinyl repair kit with good results.
  16. Thanks! I’m ready to be done with the project. Not much else planned for outside stuff this year. Gearing up for redoing my welding table in the shop though. Highlights include a new (very, very old) bench vice, figuring better grinder storage (I might have too many), and turning a single basin stainless sink into a down-draft table with a small Lincoln fume extractor.
  17. Not much has changed since yesterday, but most of the trim was painted and hung. Outside corner trim is started. I’m leaning towards a green door too. Same green as the funky green on my shop.
  18. Today was a busy day of hanging the remainder of the steel and wood siding. Trim, battens, crawlspace door, and then touch ups left to do.
  19. So rad!! All of it!! I’ve followed this truck since the beginning of the thread and it’s easily one of my favorites on the site. Everything is well thought out and obviously functional. Congratulations on the victory of the entire trip!
  20. Soffits are closed up, steel siding nailers are wrapped up, enough trim to get the drip edge done, and lowers corners are on. Doesn’t quite feel like the home-stretch just yet.
  21. I woke up to 33° this morning. Granted, there’s a high of almost 70°, but it’s definitely coming.
  22. Updates. Battens are mostly done so I started on pulling the rest of the old siding and framing the eves. I threw on the flashing on the back side temporarily. It started sprinkling on me but there’s a factory sealed edge over the front door. The temperature started dropping and the wind picked up. Chance or rain… maybe snow?… tomorrow.
