Lee21490
Everything posted by Lee21490
  1. Very possible. But wouldnt that cause issues when accelerating?
  2. Is it completely stock? Or lifted? etc.
  3. Okay, so this is driving me insane. Whenever i stop the truck from 15mph+ And keep my foot on the brake, There's a hefty clunk from the rear. It ONLY does it in gear, If i shift to neutral it doesnt.Seems its when it downshifts while braking. Thought maybe it was the tranny mount as it was pretty worn looking, So i just swapped it out & it didnt change anything. I've checked the ujoints and they look/feel fine. There's no slack in them. Any ideas? '86 comanche 95 4.0l & tranny SOA rear (doubt its wrap)
  4. +1 for the zj tie rod. I did mine a few months ago because of the same issue. Actually hit it pretty hard while wheeling the other day & didnt even budge it.
  5. Okay, I'm sure this has been asked a bunch of times before, But google is failing me atm.. So i want to throw a locker in my front axle, Figured while i was in there i'd upgrade the two peice vacuum disconnect shaft to a one peice.. And while i'm at that, I might as well swap both to the later model bigger ujoint shafts. Thats where I'm stuck, What years came with the larger ujoint shafts? I heard you have to use a different seal then stock for the one peice shaft? If anyone could link me to a good write up, That would be great.
  6. Galaxy s5. They just came out with the new "Active" version too, Which is dust/sand/water/etc proof. The regular s5 is water proof up to 3 meters @ 30minutes. I just have a cheap rubber/plastic case on mine & have dropped it all over town & never caused any damage. Speed wise it blows the iphone away, It has a better camera, 4k resolution videos & photo/video software that rivals very expensive digital cameras. You can choose pretty much any media player you want on andriod. I havent personally messed with it as i have a standalone flac player / portable headphone amp for on the go.
  7. Haha, Yea, I've been fixing weird $#!& the PO did for ages. A little of the mess is me though.
  8. Will do after I get off work
  9. I assume so. I wasn't the one that did the swap, PO said he swapped everything involved with the engine.
  10. The vacuum lines have pretty much all been replaced with new lines & The map was replaced not long ago. I'm pretty sure there isnt a vacuum leak. Not sure which of those tips apply to me since they're for renix & my entire wiring/engine/Computer/etc is from a 95 cherokee
  11. Plugs were still in it, It was WOT though. Wasnt op temp, But wasnt cold. I wouldn't worry about it because you only pulled one plug at a time. If it bugs you, do it again with all plugs removed at once. How does it run? Seems like there's always a slight missfire at idle & always seems a bit rich.
  12. Plugs were still in it, It was WOT though. Wasnt op temp, But wasnt cold.
  13. So when i swapped my spark plugs last night, I decided i'd throw a compression tester on it while i was there. Got 108 112 122 125 120 127 psi What is the compression psi for a 95 4.0l? Mine seem low :/
  14. I've been getting 10mpg ever since i got my 33x12.5 :ack:
  15. Thats why you pay the little extra to get tire insurance. Bought myself a set of 33x12.5x15 wrangler mt/r's & Sliced the $#!& out of one within the first two months of owning them, Bam new tire for free :D
  16. Did you put in the top bolts loose & Tighten the bottoms all the way? Might suck it up to it.
  17. Welcome to CC! I had a little issue mounting mine awhile ago, I ended up just lining it up, Drilling it out & Putting m14 bolts through it. You're talking about the drop bracket double shear, Right?
  18. Might be a new account filter, Some forums wait till you have X amount of posts before allowing photos to be posted.
  19. You could do a roll on liner
  20. Holy $#!&, I'm so glad i live in a place that gets almost no rust problems.
  21. What fender flares are on the xj?
  22. So i got an email from nate today, And i guess he's having some family problems atm and is behind schedule & said orders will take 3-4 weeks atm. Good thing I'm in no rush :D
  23. That's just for one though. Ebay has sets of 4 for around $100~ They even have a "Rivet style" Version too Cool deal! I think I'm going to pick up a set. I'm really tempted to order a set myself. Only thing is, idk if they'd cover my 12.5" tires. They look pretty flat on the body.
