Jeep Driver
Jeep Driver
    20
  1. Cool, but I know when to shift without a light.
  2. Yes and Yes.
  3. Image Not Found There should be a mark on the cam gear and on the crank gear and the marks line up together. If you drew a line directly through the center of the cam and crank, the marks would be on the line.
  4. At the PnP.......$8 to $12 or so. If I had a good one to put on Ebay.......$60.
  5. Bringing #1 piston to TDC does NOT mean you are on the compression stroke, the cam determines the compression or exhaust stroke. What makes you think you 'jumped time'?
  6. http://comancheclub.com/topic/36382-cruisers-renix-tips/ Study #13
  7. Distributor is 180 degrees off.
  8. The cluster has a power source from the FB, this is where the VM reads from.
  9. Here- http://www.jeepforum.com/forum/f11/renix-voltage-gauge-fix-684375/ It's easier to let someone else explain it. :)
  10. My lights and fan are powered through relays at the battery, not the fuse block. The heater fan is powered at the fuse block. The gauge is reading the load on the fuse block, that's it, nothing more, as to the cause of fluctuation.
  11. Mine does too, been that way for three years now, and will continue to be that way.
  12. I don't but I work with guys who do. They absolutely beat the $#!& out of them and they just keep on running.
  13. How about you spend the $15 and let us know. :P
  14. http://comancheclub.com/topic/45526-before-and-after/
  15. I won't say anything..........no........nothing.........
  16. Hairdryer and two hours of my time......gone!
  17. How do you tell? You just answered your own question.
  18. http://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=All-Terrain+T%2FA+KO&sidewall=Raised%20White%20Letters&partnum=065R7ATAKORWL&tab=Specs My concern with 16" up wheels is the cost of tires, looks like an additional $100 per tire at least. As it is.......I'm at $8-900 with tax and install locally for BFG 32s, or I'll be in the $12-1400 range for up size. The goal is to get rid of the Coopers and to stuff as much tire in the hole as possible, I like a full wheel well.
  19. http://www.summitracing.com/parts/mam-mr1x586500s/overview/
  20. If you like those, get some Moabs from a TJ Rubicon, they'll bolt right on. Paint them black to match those. @ $105 shipped, it ain't worth the effort, plus these are powder coated.
  21. Thank you for the information!
  22. Kinda diggn' these at the moment.
