Doubt it.
And do NOT make the assumption that a ZJ coil will sit one inch higher. Typically the difference is that the ZJ coil is the same length but of a higher spring rate, but not always! Besides, you don't want a forking high spring rate anyways, or you front will never flex....
Anyway, you can change the height of the leaf packs later by adding an extra main leaf (that's been cut) or swapping in flatter leaves. Coils can be spaced with extra stock isolators, or with real spacers. Basically, you try it and see what happens. Also, when going SOA the height will depend on the perches used, and the axle you have...
