11
The 'ell is this?
DirtyComanche replied to DirtyComanche's topic in MJ Tech: Modification and Repairs
Yeah, apparently it is. I could have looked it up, but I was too lazy. Dunno how bad it'll run without it. -
Florida plates have an orange in the middle, that looks like an "o". I saw a pic of a plate that read "A5S RGY".
Image Not Found What is it? Do I need it? It's in my way. I will kill it soon. Just like the deer on the road.
Nah, you were thinking of me. I was talking about using gloss black/flat black. But, black and very close colours work well.
See! I was right! :Canadaflag: :nuts:
The fenders are different. But, I don't know if it matters. I think the lines might be a bit different?
Longer Front OEM Brake Lines
DirtyComanche replied to Regger's topic in MJ Tech: Modification and Repairs
Well, some of those would be worth a shot. It's fairly obvious if the fittings are the right size once you compare them. But, good to know 'dem chevy lines might work. Incase I ever trash my SS lines. -
I'd buy it. But I'm boke, and live in BC...
The 2.5 sucks. Hopefully the crazy 2.5 guys won't try to kill me.
I burned in my tranny mount - it seems to be working well. Not that I had enough testing on it yet, as I only fired the engine and ran it for about 20 seconds. That was because I realized I had no power steering fluid :roll: I also got my e-fan setup together. But, I had to go out for dinner, so I didn't get it wired. Making the frame, and putting the fans on it. They're Ford Taurus Aux fans. Image Not Found Cutting things up so they'd fit. The radiator also had to be moved forewards. Image Not Found They're in place: Image Not Found I might pop it back out and make a shroud for it out of sheetmetal. At the same time I probably won't because they cover so much area as it is.
I might get you one of mine. I had it running on thursday, just to prove to myself that it still did. But I'll burn in the tranny mount and wire my fans, and then let it run for a while. Only problem is that it's gonna make the ceiling of the garage black. Who the f's thought stuccoing it was a good diea anyways?
muffler or straight pipe??
DirtyComanche replied to 1987MJfreak!'s topic in MJ Tech: Modification and Repairs
Well, there's a massive dent in the stock downpipe to clear the front driveshaft. I figure that alone is good enough. -
People say the 4.0 does. Doesn't matter. I ran around open header until I got sick of it. Run a glasspack now. Lot nicer on the trail. -
All it does is increase intake runner length, effectivly shifting the power band to a higher RPM range. Unfortunatly it has a negative effect on low end. However, on a motor that makes patheticTQ@2100 and horridHP@4500, it is really a neglible difference. At most you will pick up 1-2HP at the high end. Bang for the buck it blows.
Even if they do, I'd not recommend one.
Still don't have my D44 back! We broke the damn bearing press halfway through the install! Hopefully I'll get it back by saturday. Got my fans fixed, the tranny mount mostly working (gotta do a bit more welding on it), and the leaf hangers all welded up gooder. Just gotta do a bit more work on them, and build a driveshaft, and I think I'll be cooking. Unless I'm forgetting things? Oh yeah, the massive holes in my unibody at the front! And I still need to ream out my pitman arm. My main problem right now is that I can't find the part number for the flange that is used on the rodeo D44 rears. This would allows me to run a spicer 1310 U-joint on my 12B rear. No isuzu dealer in this town, have to make a road trip. Over the phone didn't work worth crap 'companion flange? what's that?' ugh.
I was thinking about trying to have two (one on each side of the driveshaft). Then I got a propane tank that came 2/3's full and is 140L or something stupid. For $65. The propane in it is work about $90.
Uh, power steering lines...
I ran the engine and bled off the air. Needed to see if the damn thing leaks. Now if I could just get my front axle back. -
They aren't hard. The old ones were actually rusted on so bad that I cut the lines off and used the impact to get the fittings out. Hence getting new lines. The only reason I was having problems is that I moved my radiator so the lower hose makes it a REALLY tight fit. Dunno about pulling apart the pump. I doubt it's bad at all. -
Uh, nevermind this. It helps if you try to put the line in the right port. -
I hate cameras. There's two intersections in town that you can't run becuase of them. All the others are fair game.
Umm, can anybody explain to me why the junkyard PS line I got off a 4.0 renix cherokee won't fit on my renix MJ steering box? The fitting is the wrong size...
Not a fan. Too much weight where you don't want it. I was a set portal-teks. Not gonna happen.
