DirtyComanche
    11
  1. Can't you only go down to 4.88 on the D30? Meh, whatever. I'd say 4.56 or 4.88.
  2. The hell is a sport trac? I don't think they're avaliable here... Anyways, if it is a truck like thing, it might have the ranger 8.8. Which is weaker. And evil.
  3. I had a pinched wire on my stereo. It pinch the illumination lead. It would cause the dash lights to work for a while, then blow fuses. Eventually it killed the dimmer switch too. So, take a look. And if not, replace the dimmer. It requires some contortionism.
  4. They are. Sad how I can never be sure.
  5. Are we sure? Back in 5!
  6. But was that latex, linseed, or standard oil barn paint?
  7. Bedliner works WAY better.
  8. Is that house paint? Ugh. Locked is always better.
  9. Yes but I'm going with 30 spline shafts and a rear disc conversion which I think means I can order them in any bolt pattern. Go 8-bolt. Makes the front 9" a lot easier on the builders and parts avaliability. To run 5x5.5 on D60 outers you have to redrill brake rotors and crap...
  10. Yeah, ford is evil. But, you can normally get around the bolt pattern problems with adapters or switching outer knuckle parts.
  11. I was just saying it for the hell of it. I know it's 5x5.5. Because a D44 hub won't work with a smaller bolt pattern. And ford refused to use the 6-bolt pattern of chevy and the evil imports.
  12. Pfft! Once I fix the leaf hangers. But, on a side note my XJ blew the idler pulley bearing. Then the belt smoked up and snapped. So, it turned a quicky wheeling trip into a bit of a b*@$£. That and the guy with the FSJ bent his frame, bent both front leafs, cracked the tranny, and burned up his starter. Thank god for trailers. Oh, I need a reamer that tapers 1.5"/foot.
  13. Early Bronco.
  14. That could go downhill in a hurry. I wonder if you'd get pulled over lots in it.
  15. EB bolt pattern is 5x5.5? You can make the D60 outers work with that. Call currie.
  16. Hi-9's are 9" third members that are custom built to make them high-pinion. And I mean, they're REALLY high-pinion. And portal-tek's are custom 9" housings with modified volvo portal boxes. http://www.portal-tek.com/ You can put a hi-9 in them and have the strangest driveshaft angle problem ever. It will actually be too steep in the upward direction!
  17. Most of the 9" fronts use D60 outers. Actually, never seen one without? You can actually homebrew them up too, but, it's a lot of work. I know a CJ that's running around with 9" front and rear and has been for about 15 years! Anywho, 9" axles are a great choice if you want to throw money around. Consider Hi-9's front and rear. Mmm. Or, portal-tek 9" axles. O-lalala.
  18. I'd notch the LCA brackets for clearance... You're going to have trouble with it bottoming out on them otherwise.
  19. You're limited at the hubs. You can't go larger than the 30 spline (IIRC) stock outers. If you break a chromo shaft there, it's all over. Then the only option is to put D60 outers on it. If the D44 will hold or not depends on a lot of things.
  20. Not a very useful pic, but that'll give you an idea of the width. The rear is too narrow right now. Almost all spacers are alright as long as they are the ones with studs pressed into them that you bolt on then bolt the wheel to. Image Not Found
  21. How much coin do you really want to throw around? I know of a D44 front that will be 64" WMS-WMS, and several good quality rears in the same size. But, it depends wether you think a D44 will hold your 38s... Mmm.
  22. It doesn't track wider! Even though it is wider! Front axle is 61" WMS-WMS. Rear is 58.5". The reason that it appears any wider is that the stock rims have a much lower backspacing as the smaller heeps. If you want to see how wide a wag D44 is with 15x8's with 3.5" BS under a MJ, just holler.
  23. If anybody cares, to tell a two-peice axle from a one peice all you need to do it look at the flange with the studs on it that you bolt your wheels too... if there's a big forking nut in the middle, it's two peice. No nut, one peice.
  24. I think the MJ is the best truck I've ever owned. But, the only trucks I've ever owned were MJs? Hmm.. They're good decent vehicles. Jeeps are realiable until you mod them. So, it allows you to learn things over time. Or, immediatly get @$$-deep in god knows what.
