11
Are you paying to have the knuckles turned? 'Cause if you can turn knuckles you can narrow it. Anyways, I hate my LPD44 for various reasons. The driveshaft bind is on the list, but really not a huge deal. The main deal is my driveshaft sits on rocks and gets obliderated, same with the pinion yoke. As to how much better the TNT long arms flex... Well, radius arms over-droop anyways, so it'll probably bind the shaft. I betcha could bind it with a HP axle. I mean, the pinion height change is what, 3.5"-4"? Spread over a driveshaft length of say, 26" working? The stock DC joints will flex to 30*, and can be ground to 35*. So, you're talking about 7-9* more in static driveshaft angle with a LP axle. Which is substantial. And ballpark. Find somebody that is running them with a LP axle (naxja) and ask how it went.
XJ to MJ, which parts will work?
DirtyComanche replied to cozee's topic in MJ Tech: Modification and Repairs
He's got a 2wd one, so it hardly matters. Oh, and the head on the HO motor is different. It is 'worthwhile' to swap it onto the earlier renix engine if a guy is willing to go through all the associated BS. And there's a bunch of that. -
Patent pending... Umm, right.
89 Pioneer. basically done
DirtyComanche replied to JeepcoMJ's topic in Member Projects: Your Comanches
That 4-eyes grille actually looks really good with the brush guard... And I doubted it. -
You can get new replacement ones off ebay or some website for cheap-ish. Or it's URF situation.
Umm. You're missing that they're turning the knuckles back and the housing foreward. So the knuckles and caster will remain at hte same angle, but the pinion will point sky-high. If a guy doesn't see street he can run zero caster though... Anyways, you'll bind the double cardon joint at the tcase with a bunch of flex. I don't even have my pinion turned up much, if any (at 8.5"ish), and I don't bind the u-joint at the pinion. Just the ones at the tcase. Which you can grind out to get 5* more. If your suspension doesn't droop/flex great, I wouldn't even worry.
WTB - One VERY LARGE buffing wheel.
DirtyComanche replied to DirtyComanche's topic in Member Projects: Your Comanches
Well, I welded on some attachment points for the front hoop. I wasn't too proud... But it'll be okay, I've got it dialed in now. I tacked the front hoop in too, only to find out the one side needs to be kicked in about 2* more. I hate the pointer on JD2s. Once I actually weld something I'll take some pics... Just because I'm a lady of the night. -
putting an MJ body on a j10 frame...
DirtyComanche replied to JeepcoMJ's topic in MJ Tech: Modification and Repairs
Nope. I don't need another silly project. Besides, my vehicles are already 100% gasoline free. -
If I was offered a N/A cummins, I'd pass it up. Go turbo or go home. They're very cheap and easy to hop up, and not horribly slow from the factory. And I think I'll change my weight estimate on a 6BT, apparently they're closer to 1200 turnkey. Ouch. -
I'm very aware of that. However, given the typical location of spring clamps (almost the ends of each bottom leaf) I don't see it as being a problem, as the amount of load carrying that is actually done by the spring at that point is very minor. And the amount of area that is within the HAZ of the weld is pretty much miniscule. My springs haven't broken. And I've bent two top leafs....
Sure. won't hurt anything if nothing else.
I'm so in debt now... Well, not really. But I'm not living cheap. I picked up a millermatic 180 today. Since the american dollar has gone to all hell, it was cheap. That's my justification at least. Now I'm going to go play with it, methinks. -
The factory spring clips are best. The el-cheapo ones you can get at auto parts stores and spring/brake shops aren't exactly great. Actually, I hate them. The factory ones are actually rivetted to the bottom leaf spring so they don't move around, but can be left loose to allow the springs to flex. Which is the major downfall of the aftermarket ones. But it sounds like you have none of the factory ones. So, you'll have to go aftermarket... Or be like me and weld a peice of cut up HSS to the leaf spring, er, don't do that.
If I knew, I'd tell you. Somewhere behind the tank, I guess. -
My 86 had 6x9s in the rear. The just cut out the stock holes in the plastic panelling to fit a 6x9, and screwed them to the plastic. Sound quality was not there.
I can't take the credit for this, I had a friend help me. It's his bender and he knows how to use it! But there was still a bunch of 'umm, hmm, let's just give'r and hope for the best!" which is a good attitude with DOM. Pics suck. Image Not Found Image Not Found Image Not Found I like the grille hoop. I think I'm going to run a YJ style grille actually :brows: We got that side hoop pretty tight. Just gotta do the other one and the hard/weird stuff is done. Then it's just making fairly plain peices, and figuring out how to weld it. That might be hard. -
I got totally sidetracked by the 4BT. S10eater has a 350 as well. Seems to fit pretty good. And there is at least one guy on here with an AMC 360, not finished but looked promising.
It most likely is. While a guy can pull off a rebuild on a higher milage motor without over-boring, typically it makes more sense to just bore it out a bit. However, there's almsot nothing to be gained in regards to power by this. Unless you're going to bore is .060+ over. Then you're running risks with the block's integrety.
2 peices of tube were bent! With about 1' of waste total! I'll get pics later. The light is wrong now. -
If I was a betting man, I'd bet he's a bot.
Or spend about $50 more and get a yukon chromo. Yukons are cheap. :popcorn:
Pics. Hood clearance is rather tight... Image Not Found I might have to cut it up major to fit an air filter. Or just not run one... Throttle rigging... Image Not Found I screwed it up and the cable is going to chafe a bit. But I'll fit it when I have a chance to get a 'new' cable from the boneyard. Got the HEI on. Image Not Found Not crazy about the plug wires... But it'll work. I'll get some other ones if I have to. Started messing with the rad hoses. Image Not Found Hmm. Keep my feet warm. Image Not Found Image Not Found I'll run some sort of hard pipe from here to the back of the cab. Dunno what. I'd rather use plastic because it'll weigh less and be less likely to burn the $#!& out of me. And apparently I gave away my old lower rad hose... Might need it. Since the outlet/inlet sizes on the block don't match the rad. Or I'll get a reducer for the bottom hose or something. Got the top figured out at least. Still haven't bent any tube. But I did polish up that die that somebody left in the rain. -
You gotta cut the extra bracing off normally.
I wish it would rain. I have garage, but it's too hot.
So, the 4BTs are mechanical injection? A guy could probably get a lot of power out of one for very little money.
