DirtyComanche
    11
  1. I agree. The dakota needs to go.
  2. AFAIK those are 297X shafts. However, you have to measure them to be sure.
  3. I can't shift fast enough. Often you just need wheelspeed, but you need the acceleration of a lower gear. And you don't have enough time to pull off a shift before losing momentum. And power shifting is hard on components. I'm going to get another head if I start playing with it.
  4. Yeah, I've used a plasma a couple times. They're too pricey for me. I'd love to have one, but I have enough debt.
  5. A guy can do some decent work with them if he's good. More fun than cutting out brackets with a sawzall.
  6. I wish I had a cutting torch... And a larger shop.
  7. Maybe. I think I want to try to get more revs out of mine. In first low the valves float really soon.
  8. A guy can get roller rockers. Rather expensive. Too bad the chevy ones won't fit. I don't know if there's any other valve train options other than larger valves.
  9. What's this pulling the motor business? Take the rad out... If you have A/C not realyl a good option. But I can pull a rad pretty quick, especially if it's on a vehicle I have owned for a while (and alreayd loosened all the fasteners and thrown away all the BS in the engine compartment). Oh, power mods... Start with the not-so-power mods first. Gap all the spark plugs and check the ignition system for not being a pile. Check all the sensors and make the rest of the engine runs right (renix motors can need some TLC). Clean the TB. And perhaps even take the intake off and clean it and the ports in the head (mine were all coked up).
  10. The exchange is about .93... So, we're talking about 1150 instead of 1200.
  11. Boring barely increases displacement unless your really go at it. But, you will probably need to bore it over .010" at least anyways.
  12. It gets spelled comanchee a lot too.
  13. Where ya live? 91s and 92s are hard to get. Truth be told, if it is in good shape, $4100 is probably not bad if you brow beat him down to about $3800. I know, all the guys south of the border will be freaking out. They'll have to deal with it. Vehicles for the most part retain their value better here, and cost more to begin with. I bought my pile of a 89 at $1600 and figured I did pretty good. And anything with 4wd up here is automatically worth a bunch more - because we actually need it. Unless of course we're talking about my cherokee. Which I managed to sell for $900. Whoop-dee-@#$%ing-doo.
  14. The bed is an easy removal. 8 bolts or something. But you'll need to put a couple peices of HSS (square tube) accross where the front mounts to hold up the gas tank. The fill neck will stay put decently on it's own, or you can stick it down however you like.
  15. Yes, they seem to think that $150 in brokerage fees on a shipmet worth $100 is about right. And for your convenience they make you wait for about a week or two while they broker it. I won't buy anything that is shipped by them anymore.
  16. There is a fuse, but not specifically for them. It normally ins't the problem, those lights just seem to suck for some reason. Mine worked every now and again.
  17. At 4.5" you could get away without trimming if you used slightly longer bumpstops. I'd trim it.
  18. Nice bumper sticker. That's one of the better looking over-built bush bumpers I've seen.
  19. I had something shipped from the deep south all the way to BC. It was hilarious where they actually sent it. It wound up going up the east coast. Finially it crossed the border into Ontario after about 2.5 weeks, then finially got shipped accross Canada to me. Total time was about 6 weeks after all the customs BS got cleared up. Wasn't the most efficent system.
  20. They take a funky cylindrical bulb. You should be able to get the P/N for them looked up in any auto parts store. If not, I can track down the P/N for you, it says in the manual.
  21. Mustang 5.0s.
  22. IMHO, cam failures are almost always to do with improper break in or install. Crane has been making cams for a long time, and I've not heard of rampant failures with their other cams. But, if a guy hates crane, there's other cams out there. And the right cam is always worth it in the power department. And your older t-case won't bolt to a newer AX-15. Well, it might. But normally the input gear needs to be swapped because it'll have the wrong number of splines.
  23. Yeha, you'll need to buy/make brackets for upper/lower control arms, track bar, and the coils/shocks. People make them specifically for jeeps, but all want antidisestablishmentarianism too much. Ballisticfab, BTF, and a few other places like that sell brackets for misc. purposes and can be peiced together to make what you need. Or, you can convert to leaf springs. :nuts:
  24. Yes, it seems to be intentional. I've seen lots of things to 'fix' it, none of which work.
  25. On the Waggy D44s? They're disk front (chevy calipers) and drum rear. You'll need to swap your master cylinder in order to get proper braking, the pistions and cylinders are too big for the stock M/C.
