Kenosha Warrior
Everything posted by Kenosha Warrior
  1. dude above me, thats partially right. He needs to know if there is a striker difference And no. Its only 1997 and up doors that need the striker modofied.
  2. The dude I got my truck from has the shift-plate (Or gear selector) from a 3spd Cherk in my AW-4 MJ. How do you get the 'T' piece off so I can switch the panel?
  3. Don't know about the poop, but isn't that a long black console. If it wasn't all smashed it would be worth pulling. :cheers: you want a long black console? Tradej'a mine for a black bench seat :D
  4. 'member. Thats AW-4 lore only. His is an '86 so its sporting a Chryco TF904 auto I feel the need to say 3.73's as the ratio, but don't quote me.
  5. 1.09/L +/- in the cities 1.04/L +/- on the reserves. (indian reserves up here in the southern part of the provinces sell gas and have large strips of stores and such with no tax) FINALLLLLLY!
  6. Man, $180 is pricey. If you can wait, get the #'s of your ECU and toss a line to Wildman and get one of his.
  7. as I started reading this thread, I had a feeling the last page would be something completely along the lines of what the MJ has become, or the Dodge being unholy-ly unified with the XJ.
  8. Yeah, my XJ always did this. The pump was getting cranky and after about an hr of highway/city cruizin' it would run like Id forgot to feed it. sold it before I ever figured out the problem
  9. Not just Americans, worth everyones time. War is war and the heroes who never return are mourned not by one but by all. good story though, thanks for sharing Jeff. :D
  10. Make damnsure the plug in the right fenderwell beside the air cleaner box is plugged in, I had the same issue, as well as whacky headlights, that was the culprit, along with, as Eagle stated, bad front turn signal sockets. Wanna make it easy? If you have the time, hit a few JY's and steal the ENTIRE harness from the headerpanel, its one big unit that has the main plug between the airbox and inner fender, check the sockets and if they're good, then grab it, saves hacking and splicing.
  11. Got'er. The harness on the headerpanel is tuckerd. Swapped in the original one and we're all lights go!
  12. http://cgi.ebay.ca/Jeep-CJ-7-1985-CJ-7- ... dZViewItem The ad speaks the truth, I want to go to this mine and see what is left :D
  13. oh?
  14. Where are you acctually located? We can give great suggestions on where to grab MJ's in key places depending on the area you reside in.
  15. Got'er last Friday. As per your experiences, the conical grommet stayed firmly planted in the tank, got the pump'n'stuff out and swapped, props to Jeff for the tip on the rubber line disco spots. Final report? SHE RUNS! First AW-4 Jeep and hoooboy, its a nice'un
  16. Where's that switch located Pete? I'm heading up to the truck in a bit so Ill look for it./
  17. Modified:: I have no Highbeams still, Pete, anymore insight on that switch you mentioned? I now have an indicator light on the dashboard but still no highbeams, is there any possible way a wire is broken or am I just sporting some dud bulbs?
  18. Duderama, lighten yourself. This is the norm, sarcasm is rampant, roll with it :D we all love Pete, and he knows it
  19. No. Not on the old ones. Neutral on the transfer case disengages the transmission from the transfer case, but it locks the front and rear drive shafts. If they try to tow it like that with the front wheels on the arms and the rear wheels on the ground -- it'll get interesting in a hurry. For a short tow leave it in 2WD. For a long tow, have them use a flatbed. slightly offtopic, I did a flat-drag with my newest MJ in T-case-Neutral and the trans in park, should I be lookin' for aother AW-4 or am I still cool? No weird noises during the tow?
  20. I saw that two :brows:
  21. Ill trade you MJ buckets for a bench seat? These seats are minter than mint. Grey.
  22. Ah, thanks for the tips. I'm going to attempt it with the tank in the truck still, Ill have an extra set of hands to keep stuff steady. If that fails, then Ill drop the tank,
  23. Never done an MJ fuel pump before, any hints tips tricks? Will have to do one on the new truck.
  24. Wow, 2 years gone since I joined here and owned my first one, now I'm dragging the second MJ home.
