offroader461
Everything posted by offroader461
  1. i had a new motor put in the MJ and it cost me 1800 rebuilt and installed...took them way to long and when i got mine back i had to replace oil adapter o-rings, valve cover gasket and then fought the cooling system for a month...i should've done the install myself and saved the money but just didnt have the time to do it then...
  2. He is SOA and he has a pic of them in his projects page....those are Lebarron hood vents...just cut a hole and put them in..
  3. i like the full door better than using the rear doors off the 4dr XJ...just looks cleaner in my opinion
  4. Nice pair of MJ's...wish i had room and id have more than 1 :D I say keep um both :cheers:
  5. needs a V8 then ill drive it :D
  6. Crank Case Ventilation
  7. did mine on the 4.0....look in my projects page and youll see the final pic....will be doing it on my XJ here shortly also
  8. no i don't think that the izuzu axle can accept shafts w/ a 5x4.5 pattern...never heard of it done b4...the 8.8 is a good swap when having a welder...an MJ 44 is the best BOLT-IN application out there...an XJ 44 would require welding...and izuzu 44 is a tad narrower and also require welding along w/ the wrong bolt pattern and weird gear ratio's
  9. that would be correct
  10. you need to change the radiator, heater valve and eliminate the pressure bottle...not that hard to do..did both of mine in under an hour total for each
  11. i had the same problem...truck was idling in front of my g/f house and "BOOM" it started boiling over real bad...fixed it or so i thought and then again 2months later did it again...turned out to be the pressure bottle and cap were bad...check those i finally got fed up and swapped to an open system and never had a problem since...that was the first upgrade i did when i got the XJ...they both run great
  12. Wow...been awhile since i updated...here's the recent scoop: I have been playing around with some other things and the lift is just sitting in the garage waiting for a free weekend to install it...I'm waiting on some funds to buy the cross-over steering kit from "lead-not-follow" and that will be going on too...i plan on using my Adj lower arms and stock uppers with the brackets but got a great deal on some fixed Rubicon Express UCA and fixed Pro-comp LCA (going on the XJ) for $65 shipped, and got my RK trackbar so hopefully i can finally get going on this and get it done! Pics will be up before, during and after install :cheers:
  13. i run 32 on 4.10's about 80mph on the freeway...I'm upgrading to 33's so my rpm will be a bit lower at that speed...i knew i was going to 33's thats why i decided on 4.10
  14. i have two setups between my XJ and MJ: MJ is 32" with 4.10's (4.0L 5spd) great acceleration but could have a better top end...it will be better when i get my 6" kit and 33's on it XJ is 32" with 3.55 (4.0L Auto) great all around...good acceleration and highway speeds really i don't prefer one over the other but i did notice a HUGE difference in my MJ when i went from 3.07's to 4.10's...totally night and day
  15. ill take a pic of the wiring tomorrow....MJ is at home awaiting install of the 6" lift...so I'm driving the XJ for now...my pedal position is exactly where it was prior to the swap..just much stiffer and better :D
  16. i swapped in the pedal assembly also...wasnt to difficult...4bolts on the firewall and 2 under the dash..that was the easiest way to do it...ill get some pics of it and post them up
  17. i did the same thing but instead of using the 87 brake light switch i just put the 95-96 style one in instead...was very simple to do
  18. :agree: ...at that height you need to definatly address control arms either with longer ones or Drop brackets
  19. all u need is the ZJ tie rod....you can use the XJ/MJ draglink (same as ZJ) and your stabilizer...unless it needs replacing
  20. look at chiefjosh...he has done it on his MJ
  21. No...most just swap in a XJ proportioning valve and eliminate it totally...i have my "arm" just wired in the up position...i lost my "arm" about 6mnths after i bought mine... The D35 isnt bad while using it carefully in stock form :roll: but anything "hard" and it may be upgrade time :D
  22. D35 sorry and that ball is for an arm that connects to the load sensoning valve....it should be up above that with another ball on a swinging arm
  23. its actually not that hard...we did it on a couple of my buddies XJ's...we bought the YJ trans b/c they were cheaper than the XJ's and we swapped out the tail section and it reclocked the t-case to the proper position...i planned on doing this but havent been able to locate a tranny for a decent price....oh well my trans is great so eh :cheers:
  24. you can pull the rear portion of the tranny off where the t-case bolts up and swap it with a XJ rear trans part...thats what i was going to do b/c the YJ clocks the t-case at about 10* more upwards...
