8
Everything posted by fiatslug87
I might have an extra temp gauge you can have, I'll check tonight after work and let you know.
Pull the pump and hit it with 12 volts, if it pumps it's working. I had a similar problem, I couldn't hear the pump priming but it worked when tested as above. I then found a loose connection in the wiring harness by the e-brake. Check all the harness connections and the fuel pump relay. Not sure of tubing size, but your assumption seems logical. Good Luck.
NOT true. if you remove a battery terminal it kills the circuit and the engine will die. on a carbeurated motor you could probably get by with pulling the terminals but on a fuel injected system, all sensors will die and it will no longer run. You are incorrect, I've done this and the motor continues running (on RENIX at least), that's how I diagnosed my bad alternator, replaced it and all was fine. Thanks for the confirmation DirtyComanche.
Not exactly sure of answers to your questions, but once you get it started pull one of the terminals off the battery. If it dies your alternator isn't working properly.
Can you bench test an IAC?
fiatslug87 replied to DirtyComanche's topic in MJ Tech: Modification and Repairs
So what happened? Was it your IAC? Thanks -
Here it is http://www.pirate4x4.com/tech/billavista/PDFs/Jeep_Renix_Fuel_Injection_manual.pdf
I'm sure, check out the Renix manual at http://www.pirate4x4.com or Google Renix manual, the '90 FSM also has the same procedure. Yes, I'm running at 17%. You divide the Output voltage (A to C) by the Input voltage (A to B), that ratio should be 0.17 (17%).
Well, the manual says to use Miller tool #7558 (formerly Ele. Ct.01) excerciser, whatever that is. I assume you have an automatic transmission since you set the TPS to 82%, otherwise it's 17% for manual transmission. The '89 FSM is in error and states 83% for both AT & MT but the '90 FSM and RENIX manual say 17% for MT. Hopefully someone else has more information.
Check the Idle Speed Stepper Motor next to the TPS. It may have gotten fried. I don't have the FSM with me (I'm at work) to post how to check it. If no one else responds I'll post later.
Pics needed for of hitch mount
fiatslug87 replied to swilson's topic in MJ Tech: Modification and Repairs
It's a 2" receiver. -
I have a picture on one of my short beds: http://home.comcast.net/~fiatslug87/wsb ... html-.html It's a Draw Tite which fits either long or short bed but says with factory installed step bumper only. The part number is 75021 and it's only $158 http://search.cartserver.com/search/sea ... E&GO=GO%21 -
I just went through the same thing. I opted to replace the power steering pump instead of disassembling, cleaning, replacing O-rings and having it still leak. The pump is less than $80 at NAPA (ask for the AAA discount), I felt that was well worth it. I also decided to change the pressure hose, return hose and serpentine belt while I was at it. Now there’s no noise and I don’t have to strain turning the wheels.
You almost made my wife spill her bourbon, she was laughing so hard.
It would really help us and you, if you answered the questions we've been asking. Just repeating that you replaced the CPS doesn't really tell us anything new to go on.
Is this correct? If it is, are you getting fuel? Can you hear the fuel pump prime when you turn the key? If you put fuel into the TB will it start? I had an intermittent no-start problem and it was a loose connection of the fuel pump wiring inside the cab near the emergency brake.
Source for new floor mat for 86?
fiatslug87 replied to dotis's topic in MJ Tech: Modification and Repairs
I've seen them in JC Whitney, ~$120-$150 I think. -
Check the EGR valve and transducer. Although "popping" doesn't really make sense for the EGR, it's an easy check.
Are the rear bumper end caps the same between MJs and XJs? Thanks.
tail lights / brake lights
fiatslug87 replied to whatis42's topic in MJ Tech: Modification and Repairs
There's a stop light switch connected to the back of the brake pedal and when it's depressed the switch completes the circuit lighting up the brake lights. I'm sure that's your problem. I had problems with NAPA stop light switches but good luck with ones from Federated Auto Parts. It's a very easy replacement, just make sure you remember the order/location of all the bits you remove. -
If you're getting a compatible cluster there shouldn’t be any other wiring requirement for the fuel gauge. There are two ribbon connectors that plug into the back of the cluster that take care of everything. You might have to move the bulbs around in the "message center" to match your configuration however.
low end torque problems
fiatslug87 replied to mjstiltheydie's topic in MJ Tech: Modification and Repairs
Check your EGR valve (I assume you have a pre '91). Mine would stick causing the MJ to bog down while accelerating. -
I didn't replace the clutch in my '90 until 202,000 miles (I'm the original owner so I know it hadn't been replaced) . The problem was actually that the slave cylinder was leaking very badly. The mechanic told me the clutch plate was still fine and was very surprised it was original, but as Eagle stated, if it's already apart the plate might as well be replaced.
Wouldn't it only be accurate if the markings are in the same places as the original?
I just measured the center holes of my spare set of stock Eliminator wheels (10 hole) and they are ~59mm (2.32 in).
Well, I like the ones from NAPA PN 718023(+) & 718024(-) they're the perfect lengths with non-lead clamps. I can see some people not liking the clamps, but they're fine by me. The on-line price is whacked, mine were less than half that ($15.89 & $10.59) maybe still a bit high though.
