fiatslug87
Moderators
    8
Everything posted by fiatslug87
  1. Don't drop the bolts in the bell housing and you'll need a series of extensions and a universal joint socket extension. There are no "adjustments". Hope it runs for you.
  2. The Chrysler part numbers are: 5AG28JX9 (Right rear) 5AG29JX9 (Left rear) They appear to still be available through http://www.chryslerpartsdirect.com/ About $58 each
  3. I'm too old to mod it out and deep down I'm a purist- I'll leave it stock(ish). Haven't yet looked at any fluids, this weekend will be my first real look. I have the new clutch hose and that's going in tomorrow. By the way, I still have 20+ days of CarFax, anyone want their MJ run? Just PM me if interested.
  4. Just picked up an 88 Pioneer 4x4, 4.0, MT, short bed. The body and frame are in great condition (no rust or dents) the interior looks brand new and the motor runs strong (not bad for 280K miles). The only problems are the trans is rough in 1st & 2nd, the clutch hydraulic line needs replacing and the power steering pump whines occasionally. This is my first 4x4. Now my collection is complete (see signature). I’ll post pictures eventually.
  5. If it was weeping you need a new pump. That's the point of weep holes.
  6. The "1" in the 8th position designates base model. Already came upon that conclusion. But a base Metric Tonne got an 'F' in position 8, which is what is confusing. Mine is base trim, but has the Metric Tonne package on it. I've got all the external markers, the different springs, and the D44 but its got a 1 in the eighth position. Easy there whowey, I was just confirming the "maybe" and you’re correct about the Metric Ton Here's the list I have for position 8, the list is labeled as being for 1987-1990, but now I doubt its accuracy since when I just looked at my 1990 FSM, the 8th digit is the Engine. F 5,001 - 6,000 lbs. Comanche, base & Custom, Metric Ton, Big Ton J 3,001 - 4,000 lbs. Wrangler base & Cherokee base K 3,001 - 4,000 lbs. Wrangler Sport & Cherokee Pioneer L 3,001 - 4,000 lbs. Wrangler Laredo & Cherokee Laredo M 3,001 - 4,000 lbs. Wrangler Sahara N 5,001 - 6,000 lbs. Grand Wagoneer & J-10 Truck P 4,001 - 5,000 lbs. Comanche Pioneer P 6,001 - 7000 lbs. J-20 Truck R 5,001 - 6,000 lbs. Comanche Pioneer, Metric Ton, Big Ton S 4,001 - 5,000 lbs. Comanche Chief S 7,001 - 8,000 lbs. J-20 Truck T 4,001 - 5,000 lbs. Comanche Laredo U 5,001 - 6,000 lbs. Comanche Laredo, Metric Ton, Big Ton U 6,001 - 7000 lbs. Grand Wagoneer & J-10 Truck Y 8,001 - 9,000 lbs. J-20 Truck 1 4,001 - 5,000 lbs. Wrangler base, Cherokee base, Comanche base 2 4,001 - 5,000 lbs. Wrangler Sahara & Cherokee Pioneer 3 4,001 - 5,000 lbs. Wrangler Sport & Cherokee Chief 4 4,001 - 5,000 lbs. Wrangler Laredo, Cherokee Laredo, Wagoneer Limited 5 4,001 - 5,000 lbs. Cherokee E.C.E. & Comanche Eliminator 9 4,001 - 5,000 lbs. Cherokee Limited
  7. Okay, here is the vin run down. 1- US built J - Jeep T -truck M - 4.0l L - 5-spd manual tranny, part time t-case 65 - LWB 4-whl drive 1 - Not sure, FSM shows only letters (for the trim package) X - Check digit H - Model year 1987 T - Built in Toledo 049647 - serial number Edit- Got to thinking about that '1'. On a hunch I checked the vin on my 88 MJ. I have the same '1'. Mine is a custom ordered Metric Tonne, any chance you know whether yours was a custom order also??? The "1" in the 8th position designates base model.
  8. It's an '87. Run it through this Jeep VIN decoder http://jeep.avtograd.ru/VIN/vin_en.asp
  9. The '90 FSM says to tighten bolts using the tightening sequence to: 22 ft. lbs. then 45 ft. lbs. then recheck at 45 ft. lbs. then to 110 ft. lbs. except #11 to 100 ft. lbs. (bolt #11 should be coated with Locktite 592) The tightening sequence is as you're looking from the front: #1 -middle bolt on left #2 –middle bolt on right #3 -bolt in font of #2 #4 -bolt in front of #1 #5 -bolt behind #1 #6 -bolt behind #2 #7 -bolt in front of #3 #8 -bolt in front of #4 #9 -bolt behind #5 #10 -bolt behind #6 #11 - bolt in front of #7 #12 - bolt in front of #8 #13 -bolt behind #9 #14 -bolt behind #10 You’re basically making a spiral from the center. It specifically says do not apply sealing compound and to reuse head bolts only once. I'd get new ones, I've broken them upon reinstall and had to pull the head back off to get the suckers out.
