Ok I will try to explane better.
I have an 89 comanche and an 91 cherokee.
The comanche engine was toast so I took out the engine in the cherokee(4.0 H.O.) including all the componants,wire harness,computer everything.
I put it all in the comanche and nothing.It turns over and thats it.
So I then today took out the intire wire harness out from under the dash of the cherokee and put it in the comanche.When I turned the key everything worked,clock,lights and even the fuel pump but still no spark to coil.So I checked the CPS like everyone told me still with nothing.(I even tried cutting the plug off and wiring it solid no luck)Is it possible the CPS in the trans is toast or could it be something else.Like a ground to the block off somewhere.I found a few wires that were not attached to anything just don't know where they go.Help please getting frustrated..
Buckey
