fiatslug87
Moderators
    8
Everything posted by fiatslug87
  1. 99-04 Grand Cherokee lower control arms. The metal sleeves in the bushings have to be ground down for them to fit (grind each side the same amount), not very difficult.
  2. If they're in decent shape they're worth some $$, check out eBay don't throw them out.
  3. Nice, it has the factory Marchal 750 fog lights, or at least one. Make sure to add its info to the Registry page. https://comancheclub.com/forums/forum/28-comanche-registry/
  4. Here is a pic of the harness side connector, the red wire from the CPS is in the center so it connects to the white (?, can't tell it's dark) wire in the center.
  5. NICE!!! How about a write up, or is it simple plug and play?
  6. Yup, have them already. A member on here, dasbulliwagen, works at a dealer and was able to get a detailed build sheet for me.
  7. The mount was not loose, there was movement at the front where the electrical portion enters the valve body, no movement at the TB. Well, I went with the NAPA IAC, in stock and 10% of when reserved online. My idle now stays at ~800 RPM (cluster tach) and I haven't gotten the occasional high idle at startup.
  8. If you look closely in the garage under the JEGS fender protector there's a set of wheels (16" or 17"?? it's been so long) awaiting a lift for installation.
  9. to CMNCHE3. It rolled off the assembly line on 1/4/1988 and still looks like a baby today!
  10. Yup, all is clean and the o-ring looked good.
  11. 1990 4.0L 5 speed. My idle will increase as the engine warms up. When I push on the IAC the idle starts dropping, there is movement in the valve at the front where the electrical connector enters the valve body, not at the throttle body. I will be replacing it, my question is should I go with MOPAR (>$100) or aftermarket (<$40)?
  12. Yeah, Matt is a good guy, too bad he lost his ride, I mostly meant Logano as Don stated.
  13. My wife is really glad you recognized it as Tony's car and not any of the other yahoos that have since driven the 20.
  14. Yeah SCIENCE, b i t c h! Sorry, been watching the Breaking Bad marathon.
  15. That's funny, I see my first with pic and the second saying double post. In any case this was the original post: Come on, someone has to post something! Let's get things rolling.
  16. Come on, someone has to post something! Let's get things rolling.
  17. The stock set up was a nut with integral washer.
  18. Yeah, I hate mobile device keyboards, thought I changed it in time.
  19. Nice Airstream.
  20. They both attach in the same location with the same three screws. The long ones have a plastic center plate that the clips screw through into plastic inserts in the sheet metal. The headliner also has a cut out in it where the plate attaches, not sure if it's there for the short ones.
  21. Got a new BBQ, actually a roasting box that can cook a whole pig (not hog), shiny! And for an MJ the Boostwerks hidden winch mount.
  22. Looks great! I like the new fabric better than your original plaid, it does look very similar, if not identical, to OEM.
  23. Two Santas, check Three elves, check Four Comanches, for the win 😜
