Everything posted by jpnjake
Very cool truck with a very cool story, be sure to add to the original owners Thread. How is the goose neck ball mounted?
Nice, I have the Cooper Evolution MT’s in 31 x10.5 and they ride extremely smoothly and are very good.
Wow, that’s quite the transformation. Incredible work
I know on the late model xj’s they split the harness and had them fused individually, but I’m not sure thsy did that with the Mj’s , other than that. I’d check the wiring diagrams and find the body ground for the lights and clean it up. Bad grounds do funky things
I have the metric ton leafs on my Swb, rn it is 21 inches from the center of the wheel to the bottom of the flare. It used to be alot more than that, but it’s settled over time. Currently I have 1 overload out because my u-bolts on my dana 35 aren’t long enough, will update this thread again when I have the 44 in with longer u-bolts
The plow itself could’ve been in nicer shape but what do you expect for the condition of the truck. I did really consider taking the plow mounts and everything for my xj but taking all the wires and putting them back wouldve been a big hassle
Early b body axles are slightly narrower than the Factory MJ axles. later B,E,and C body Axles are wider and would be slightly better in an MJ
Jeep Comanche Behind the seat Molle Panel!
jpnjake replied to ThatJeepGuy's topic in MJ Tech: DIY Projects and Write-Ups
Very cool, an MJ for hunting is definitely a cool idea, I like my bed box, but I do see how the loss of space may not be worth it. For reference here’s how much room in a swb that a side toolbox takes up -
Very cool idea, what are you planning on running on the molle -
Idk if this has been suggested before but me and my dad were talking about a post on the amc board and he thanked them with a little like button type thing, and I just thought that would be a good idea for Comanche Club, so you can acknowledge all the posts to your forum without always having to come up with a response.
You can also upgrade to 97+ windows that don’t have the corner window. In order to do this you would also need matching regulators with them, and manual window regulators in 97+ are somewhat hard to come by
No problem, just watch out if you buy wing windows, the bottom attachment rod that the window pivots on is very commonly broken, but can be welded as long as you have access to a welder.
To my knowledge the window and frame are all one unit, you have 2 options. One replace it with another wing window, or replace the whole unit with a solid window and lose out on the wing window feature Solid non moving Moving wing window note these are directional and are specific to drivers/passengers side
What year specifically, I have the 87,89,90,91,92, and 93 books with all the Comanche options for that year in them
Brown Betty ('86 AMC Eagle)
jpnjake replied to acfortier's topic in Member Projects: Other Cool Stuff
Wow that’s quite the adventure, I’m super glad the trans is working out so well. Plus now it’ll sound like a 4.0 while cranking now -
I’m glad to see that the trans is in, and that you could use that flex plate. Getting excited to see it on the road soon. And that transmission should be good, as the motor that was next to it under the bench for the last 20 years is in my soon to be daily lol. -
If the parts are still in there I can, at some point in it’s life a lot of the parts for the truck were removed
My 87 is a 4.0 Peugeot that had factory cruise
Looking for 60mm bored throttled body
jpnjake replied to Whitaker717's topic in MJ Tech: Modification and Repairs
89 comanche parts
jpnjake replied to Roadrunner's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
89 comanche parts
Horseshoe auto wrecking 360.674.2515 Bremerton wa -
lol I should come down someday soon
Lol a lot of them are because of how many CC members I’ve met this year lol I should start a “How many Comanche club members have you met this year” Thread
