Everything posted by 1989commanche
1989 Comanche 4x4 4.0 I6, 5 speed manual, 231 transfer case, D30 front, D35 rear with 3.73 gears and Eaton TruTracs F&R, a few inches of lift, 31â BFG All Terrains. Stock interior with gauges, factory A/C, bench seat. Homebuilt Bumpers and Rock Rails. Led light bars, Warn M8000 Winch in receiver cradle mount can plug in front or rear, Plus a few extra doodads. A never ending project. Palmdale, Ca USA
Itâs not a B or a MC style fitting. Looks like an old airco style fitting. They make an adapter for them they look like a hex barrel, one end screws onto the tank and your regulator screws into the other side. I probably have one in the toolbox.
Female End Seat Belts
1989commanche replied to Ls2xjcomanche's topic in MJ Tech: Modification and Repairs
It goes to the annoying latch your seat belt buzzer. And the little red light. That accompanies it. -
Comanche Rear Bumper
1989commanche replied to 1989commanche's topic in MJ Tech: DIY Projects and Write-Ups
Yes I added 10 watt LEDS left the stock ones alone. I was thinking about changing all the external lights to LED but havenât yet. Just the headlights so far. They are way better than the stock halogens were. -
Nope just a good angle itâs not even very clean. Stock window from when it was newđ
Iâm glad mine didnât overheat. My overflow had a crack in it when I got it. Always bubbled out of a crack when hot. But not bad. Replaced it with a jy pulloff lasted a few years but developed the same leak in the same spot. Just bought a new amazon special for around $20.00. Letâs see how long this one lasts.
Put on my Comanche Club sticker finally. It came the day of my Hernia Surgery. Was not feeling like installing it that week.
Picking up a new hobby I've always wanted to learn!
1989commanche replied to Knucklehead97's topic in The Pub
The first time you get a nice red hot ball of spatter sizzling itâs way through your eardrum youâll know why to use ear plugs and a welding hat. -
Rare Toyota Camry truck
1989commanche replied to MJXJjeepguy's topic in Craigslist/eBay... i.e. Not Your Stuff
They could have at least cleaned up all the crap in the bed? Back? Bucket behind the winderr. -
I have the gm,Chrysler & ford cartridges and a few adapters. When I got it I was only looking for it work on my Ford Taurus back in the day. I have had it in a drawer in my toolbox for the last 10 years or so almost forgot I had it. I bought it used from my Snap-on rep 15-20 years ago. Paid way too much money for it back in the day. I will need to look at my newer OBD-II scanner and see if it will adapt. It has a few adapters in it too. Maybe a Jeep set??
Iâve got one of those MT 2500 and a few cartridges in a drawer in the garage. Iâll have to see what adapters and cartridges I have. What all do I need to use on a 1989 4.0?
Paint with 3 coats Rustoleum Black Hammered. Add 10 Watt LED Reverse Lights and Install. All finished for now. -
A few more pics of lining up and squaring . Welding up hitch. Plus I built my own Receiver Tubes but didn't take any pics that I can find. Doesn't really show but hitch and recovery points go all the way through and are welded both sides. -
Once placement figured out make 4 different patterns then build bumper brackets. Not really shown but spent lots of time on locating bolt holes in frame and also tap the rearmost nutsert thingy that is there but not tapped for threads, Tap threads and get 8 grade 8 bolts to fasten bumper to body -
Rear bumper build. OK First step Square 1 end of 2X6 tube, then cut to approximate length. I added 2" just to be safe.
Whereâs part 3. I watched 6 or 8 different banks videos. Could not find #3?
how many miles on your truck's factory engine?
1989commanche replied to Pete M's topic in MJ Tech: Modification and Repairs
340+K -
Looking for victi....errr worthy canidates!!
1989commanche replied to whowey's topic in Comanche of the Month (MJOTM)
This is where mine is at now. I havenât done a build thread here on it so far but I need to find all my pictures off the other phone. Thatâs where my bumper build pics are.and the winch cradle build and wiring it all up. I do have lots of pics of the Rock rails being figgered out. Lots of small projects to get it here. Most of them you wouldnât know were even there.
