89 MJ
    8
Everything posted by 89 MJ
  1. We also got some rust free doors for it too. He got the truck and the doors for $550.
  2. He bought home the truck he fill be fixing now. We believe it’s an 83. It’s a short bed, 360, Auto, with a factory sliding rear window and roll bar and 64,000 original miles. We rescued it from the local junkyard. It also appears to have a small lift. Maybe 3 inches.
  3. Thank you!
  4. Gotcha, thanks!
  5. Is it possible to put a 96 gauge cluster into my 89 (my 89 will be getting a 96 engine, but not the full HO swap). I know cruiser's website says that some sensors need to be changed to have the HO engine work in a Renix, but I am not sure if I keep some HO sensors if they will work with the full cluster. I will be swapping 4.0 for 4.0. I will also be swapping to a 97 AX-15.
  6. Ok. I'll likely be ordering some.
  7. Looks like it worked
  8. I know its legal in the woods, but my truck is a pavement princess most of the time and I live in deer country. I'll look into them.
  9. Thank you!
  10. Sounds good. Thank you!
  11. Thanks!
  12. Wow! Those a bright! I can’t do that as I need it to stay legal. I’ll look into those. Thanks! Ok. I’ll check some of those out.
  13. Doh!!! Thanks! Thank you!
  14. Ok. Where can I find one of these relays?
  15. That makes them brighter? Do you know how?
  16. Thank you!
  17. What is everyone using for brighter headlights? I’m sick of my old candles.
  18. Always wanted to see this done.
  19. You will need to create a build thread including details of your build, then send me a message and I’ll get you taken care of.
  20. Oh, this changes it a bit. Wheels and tires are going to be expensive. If you already have JK wheels and tires, that might make it more justifiable.
  21. I’d be in for one in something like a 1:18 Scale. You cold also scan mine if you needed to.
  22. Beautiful truck! Mid ot in the registry yet? @Pete M, can you move this?
  23. Then why swap the front axle? You’d be going D30 to D30. I’d swap it with one from a 97+ and do a Ford 8.8 rear. Then it will be as strong (maybe stronger) than the JK axles for a fraction of the cost. You could probably do it for $500 or less.
  24. How many MJ beds do you have? Don’t you also have an MJ shell that isn’t listed in your sig?
