89 MJ
    8
Everything posted by 89 MJ
  1. Ok, I am prepping for my engine swap and I realized I forgot to order a new crankshaft position sensor. I will be using the 89 Renix wiring harness with a 96 4.0 and a 97 AX-15. For which 4.0 do I order the CPS for?
  2. I really like this, everyone has their own use for their trucks.
  3. You could get the AMC 20 in 86 MJs (like yours). It wasn’t available after that though.
  4. I can definitely look at those. I was thinking of doing POR15 on the underside, but I am open to suggestions like yours. I will take a look at them Chassis Saver is basically POR-15 with fewer harmful chemicals.
  5. Fluid Film, Chassis Saver (to paint over current surface rust), and very frequent car washes are a must then.
  6. 4wd and 2wd have the same brakes. I understand wanting bigger tires though.
  7. Welcome! I live in WI. I will also say, do not drive these trucks year round. The salt will eat then regardless of undercoating.
  8. I’m glad so many people still use these as trucks.
  9. LOL
  10. We just had our sewer back up in our house earlier this year. I guess you could say it was a crappy situation. Or in short, a $#!&uation.
  11. Bump, we've gotten a lot of new members since the most recent post. I like stories, lets hear them!
  12. I would pull the engine and rebuild it. Who knows what could've gotten in some of the waterjackets or other places. If you don't want to rebuild it, I'd buy a running Jeep with a 4.0 and swap it in. If you have a Renix, I'd try to find a 87-90.
  13. Many people use their MJs for different things. I want to know what you use yours for! Mine is my daily driver from spring through fall and my car show truck, but I also use it for hauling and towing things.
  14. 6 month(ish) later review. I still like it, I've towed my garden tractor with it and hauled some heavier parts in the bed and had no squatting, which I had before even if I just sat on the tailgate. I wouldn't call them a substitute for Metric Ton leaf springs though, as I believe those have 2 overload springs, I only have the 1. This would be a low-buck alternative if you can't yet afford/don't want the stiffer ride of the Metric Ton springs, but want your towing/payload bumped up a little bit. I think the ride is a little bit softer than a 2017 JKU. I also seems to corner better now because of the stiffer springs-it stays flatter, almost like it has a rear sway bar, but it does not have a rear sway bar. That may be a future upgrade though.
  15. Why do you want a 4wd truck? Also, @Pete M, should this be moved over to tech questions to get more eyes on itS?
  16. Honestly, I don't think I would convert a 2wd truck to 4wd. If you live in the rust belt, you shouldn't drive the truck in the winter because they are rare and climbing in value, and if you live in the south, you won't probably need 4wd for the snow. There are quite a few people in AZ that do mild wheeling with their 2wd trucks.
  17. Here are 2 threads that have done 4x4 swaps. Both of these guys did the swap well if I remember correct.
  18. I have some quick questions before I go about answering your questions. Is your truck a 5 speed or an automatic? The only 5 speeds that came in MJs were manuals. Yes, the easiest way would be to buy a similar year XJ (I'd look for an 87-90 because you have a Renix truck) and then swap the transmission/transfer case/front driveshaft/front axle into your MJ. Then you will only need to get your stock rear driveshaft shortened (~1 foot if I remember right). I will link some threads that cover this for you.
  19. Sounds good!
  20. I need to get some supplies from school today (because we have to have online school BS), so I should be able to get some good pictures in the school parking lot. I'll see what I can do and try to PM them your way in the next couple of days.
  21. If you want to try to scan another truck to see if that makes a difference, you could always come up near me unless you want to scan a closer truck.
  22. I'm sure @eaglescout526 might be able to find one in a dealership or @Red Mistress might be able to pull one out of his magician's hat...lol.
  23. I don’t need any, but the b-pillar inner vent might be a good thing to make.
  24. I’m sorry to hear that.
  25. Build Thread- https://comancheclub.com/topic/59378-driving-on-the-street-to-street-truck/ Year/Model - 1988 Comanche Pioneer Drivetrain- L33 5.3 chevrolet LS, AX-15, RWD Chrysler 8.25 Cooling- Summit racing 22x19 aluminum radiator, ebay shroud, FFDynamics 16" fan Electrical/Ignition- Stock wiring harness mixed withadditions for V8 swap, Holley EFI standalone engine harness, Cruiser54 updates, stock chevy van 105 amp alt, 0/1 gauge cables Suspension/Steering- Grand Cherokee ZJ V8 steering, red head box, speedway tie rod with hiems, Grand Cherokee ZJ rear springs up front, energy bump stops, stock leafs with 2 inch lift blocks (for lowering in this case), xj shackles, About 2 inch drop in front and 3 in rear. Bilstein shocks all around. ADDCO 1 1/8 MJ front sway bar, ebay heim links, Belltech rear Chevy blazer 1 1/8 swap bar, custom mounts, Jeep commander links. Poly bushings everywhere. Rubicon express tubular control arms upper and lower. Interior- originally grey interior, now swapped to almond interior all around, new stock carpet, Bucket seats out of an XJ, generic amazon center console, redone headliner, sound deadened all around, NOS pioneer cassette radio, bosch tach, holley EFI dash, stock speedo/gas gauge dash, MOMO leather steering wheel Brakes- rebuilt stock brakes front and rear (for now) Lighting- Hella e code housings with hella bulbs, generic fog lights, clear corner lenses Exterior- Patina paint style, 10 slot chrome grill with trim, s10 rear roll pan bumper, new windshield, ebay hood louvers, Downey tonneau cover, s10 bed rail caps, s10 lower front splitter, Wheel & Tires- American racing Salt Flats 17x8 front and rear, 245 45 17 Falken azenis fk510 tires Misc- Truck started out as a 2.5 4 speed amc 35. It was ROUGH. gutted the entire thing within the first weeks. Swapped in half a honey interior, then almond this past summer. Did a soft rebuild and refresh of the motor enough to make it a reliable daily. Swapped in a 8.25, then a ax5. drove till this spring while buying v8 swap parts. Spring of Rona 2020 swapped the v8 and got it running and driving in 2 months. Honestly covid was great for this because all I could do was work on the truck. within 1 year of owning it, it was lowered, freshened up and v8 swapped. Best MJ story- Last summer I took the truck in stock form to the Roadkill Nights event in Pontiac Michigan. 700 miles one way trip. It screamed at 4 grand at 80mph the whole time. I entered the truck in the car show portion of the event with my buddies 2018 gt350. Out of all these amazing cars I could barely get away from the jeep because people kept talking to me about it. Even met someone from this site. The show offered a free dyno session on a mobile unit and my buddy talked me into doing it. All these insane cars making 500+hp and I roll up with people crowding around asking what i have in it. Get up on the dyno and the guy about died laughing when I said it has a 200,000 mile 4 banger. With a crowd of about 75 people I pushed it to 5 grand and it made a whopping 89 HP. Honestly more than anyone thought. I was shocked. Second run I tried for 90 but shredded the belt. Sounded like the bottom end exploded at first. Drove it back to my spot and got high fives all the way back. Then had to go buy another belt and fixed it in the show. That was the only issue that whole trip. And then the clutch master exploded in the driveway the moment i got home... CC is Awesome! Why? The whole community aspect of this site is amazing. I have been helped so many times from people here and met so many cool people from selling and buying stuff. The wealth of knowledge on this site is incredible. Other forums i've been apart of don't even compare to the friendliness and help i've gotten on here. Congrats @70barracuda!!
