AZJeff
Everything posted by AZJeff
how about a single layer of fiberglass mat bonded to the back side of the existing headliner base material? Not too heavy, but stiff enough.
Plastic film inside doors; what is it called?
AZJeff replied to Big_Mark's topic in MJ Tech: Modification and Repairs
The term they used to use was "watershield paper" back when those types of things were made from some sort of wax coated butcher paper, around 1000 years ago when I started working on cars. Eagle is probably quoting Jeep's official term for it. When I have ones that tear, etc., I make a new one out of 3-4 mil think polyethylene sheet, and cut it to shape with scissors. The BEST way to attach it to the door is using the method that the factory did, which is a butyl tape. You can get the stuff on Amazon: https://www.amazon.com/Sealant-Headlight-Retrofit-Headlamps-Windshield/dp/B09SF18Y8T/ref=sr_1_4?keywords=butyl%2Btape&qid=1673119896&rnid=2941120011&s=automotive&sr=1-4&th=1 -
There are TONS if videos on YouTube covering the R&R of the RMS and pan gasket on the 4.0 Often the video shows the job being done on a YJ, TJ, or XJ, but they are the same as the MJ, except for how one goes about getting the oil pan out after it is detached from the engine. My preferred method to getting the pan out is to jack the vehicle up so the front wheels clear the ground, and then place jack stands under the "frame" by the lower control arm pickup points. Then place the jack under front axle, and remove the front wheels. Then lower the front axle down as far as it will go. If that is STILL not enough to get the pan out, then remove the lower shock mounting bolts, and lower the axle a bit more with the jack. Once the pan is out, put some jack stands under the front axle to support it while you do the seal work. Once you are ready to reinstall the pan, take the jack stands out and lower the front axle as needed to get the pan back in.
what condition might cause this to a spark plug?
AZJeff replied to Pete M's topic in MJ Tech: Modification and Repairs
That’s a new type of plug failure I have NEVER SEEN, either in person or via photo. And I have been working on cars for 55 years. what does the plug hole in the head look like? -
I remember seeing a member here who posted a link to someone who makes reproduction underwood decals for Jeep vehicles. I am looking to replace several decals on my 1989 MJ, but has the driveline of a 2000XJ, so I need those XJ specific decals. Does anyone have the link to that vendor?
Occasional noise when heat is turned on
AZJeff replied to Classy Comanche's topic in MJ Tech: Modification and Repairs
Yeah, I might sound like I am stating the obvious, but in my years on the XJ forums, I found a ton of owners who complained about belt squeal, only to discover they were not using a belt tension measuring tool, and/or they underestimated the amount of tension actually required. And you are absolutely correct. The older 4.0 tensioning scheme for the XJ and MJ sucked. It was much harder to get sufficient tension than with the later system (which, unfortunately was used only on the later XJ's.) -
The 4.0 in the MJ and XJ models is VERY sensitive to lack of proper belt tension. On top of this, they seem to need a hellacious amount of tension compared to some other vehicles. This means that many DIY guys under-tighten the belt, and noise ensues. Add in belt aging, and crud on the belt and/or pulleys, and it can be really annoying. -
If you are attempting to restore the dash so it has the same appearance as when it left the factory, “JustDashes.com” (or any of their competitors, if they exist) are your best choices. The OEM construction is foam over a plastic dash structure, and that is covered by a layer of vinyl. Duplicating that without the right fixtures an d materials will be almost impossible.
I put a complete Teraflex kit on my D44, and although its' been a few years, I seem to remember the spacers that Teraflex provided were of an incorrect dimension. I cannot remember for sure, but I seem to think they were too thick. I am going to go check my records to see what instructions I gave the machine shop that altered them for me.
I tried to type in a description into both eBay and some search engines, and I got nothing. If you have a part number, that would help in a search.
Actually, I would like a few (6?). My interior color is redone to match my 2000XJ dash, so I would respray any color I got with the proper Chrysler "Agate" interior paint.
Several of the interior panels of the MJ have screw holes that are covered by a plastic plug to conceal the hole once the panel is installed. When putting in a new heater core recently, I lost one of my hole plugs. Does anyone have a source of replacments? (other than trying to find some in a junkyard) I supposed I could modify (shorten) the conventional hole plugs that can be had from hardware suppliers, but they are not exactly the right diameter, and the modification will be tricky due to the small size.
Full suspension bushing kit available?
AZJeff replied to Jlindsey86's topic in MJ Tech: Modification and Repairs
What you are talking about are "polyurethane" bushings. Polyurethane is much stiffer than regular rubber, when used in bushings. Its commonly used on applications where precision handling is needed (like on race cars or the like.) It is not used on "regular" street vehicles because the polyurethane transmits much more shock and vibration back into the chassis, and can make ride quality quite harsh. Unless you are running the baja in your MJ, I would steer clear of polyurethane. -
THANK YOU!!!!
The AC lines that connect to the evaporator have a secondary "safety clip" that surrounds the joint. It's made of sheet metal, and I assume it's intended to insure the line will not slide apart due to pressure of it's own accord. My MJ, which has a 2000 XJ evaporator in it, has that clip on the low pressure (suction) side, but lacks one on the high pressure ("Liquid") side. Can anyone provide the Chrysler part number (or a source) for the clip for the high pressure side clip?
brake reservoir sediment (red mud, rust, ???)
AZJeff replied to brucecooner's topic in MJ Tech: Modification and Repairs
Interesting.....I admit my forays into major brake system repairs were not steady through my years of working on stuff, since I am not a pro and strictly DIY. All I can say is that, over the years, I never saw anything but the almost clear (straw?) colored stuff, and then the cruddy brown/rusty/icky stuff I removed. Good to know about this.....THANKS. -
Yep, that drill and chisel method is what I use as well. And air hammer (air chisel, in this case) are a Godsend for this kind of stuff. -
That part you state in bold is something I have never encountered, and I have been working on cars since about 1970. I wonder if that was that just a Canadian thing (?) -
In additon to the hydraulic arbor press, the OP will need some sleeves to press against the outside edge of the currently installed bushings. Pressing against rubber doesn't do very much, even at 13+ tons of pressure. It MUST be exerted on the outside sleeve of the old (and then the new) bushing. -
Defrost works but heater won't
AZJeff replied to Shharks's topic in MJ Tech: Modification and Repairs
Agreed. The connector in front of the radiator is NOT a vacuum connector. It's an electrical connector. -
Good brake fluid is clear, with a slight tinge of a yellowish color, but certainly NOT green or brown (or any other weird color.) It seems that your brake system is contaminated with something besides plain brake fluid. Since your plan is to remove the master cylinder from the booster, you might want to consider making the plunge to put a new master cylinder on the vehicle while you are at it. They are not that expensive, and with a new one, you know the start of the system is not contaminated. As far as getting the fittings loose from the MC, if the car lived it's life in AZ, a "flare nut wrench" will keep the chances of rounding the hex shape on the nuts to a minimum. If that STILL seems to be likely, then I vote for heat from a propane torch next, to break up the rust between the nut and the steel line. The area around the MC has lots of room, so the chances of burning your MJ to the ground are slim, as long as you use some thought before waving the torch over anything and everything. (I have used the torch method to loosen fittings on cars that lived in corrosion central, better known as N. Illinois, when I lived there years ago.) Once you have the new MC installed, and begin the bleeding process, if the fluid fails to run clean after a significant amount of fluid has been pumped through the system (1 quart or more), then maybe it's time to consider replacing wheel cylinders and calipers as needed. Funky brake fluid will attack and damage all the parts of the system, especially anything with rubber seals that slide. Sorry..... -
Yeah, taking bushings out of ANYTHING can be fun if you don't have a large arbor press and, more importantly, the right size bushings to press on the sleeve of the rubber bushing assembly. On an MJ/XJ, unless you have a lifted vehicle, I recommend replacement control arms. They can be had pretty inexpensively (under $20 each), and beat the hell out of burning out the rubber as Cruiser was demonstrating in the photo above. The only area where you will have to use brute force is the upper control arm FOREWARD bushing, which is pressed into the axle housing, and is not part of the control arm (unfortunately). If you have access to an air chisel, that job isn't too bad. Otherwise, a hand chisel, a pair of Vice-Grips to hold the chisel, and a machinist's mallet are the next best approach. (I am not real fond of burning out those bushings in the axle under the car, because of the proximity to things that don't like flames.) As far as the leaf spring bushings go, you need to make sure that your springs are original Jeep parts, first. On my MJ, some previous owner had switched them out for some aftermarket springs, and none of the OEM replacement bushings had the correct outside diameter to press into the spring properly. I ordered bushings from several sources, all of which would not fit right, until I gave up. I wound up taking the spring apart, and taking the main leaf to a truck spring shop where they matched up and installed some bushings using their press. Then I put in new centering pins and new inter-leaf plastic anti-friction pads and reassembled the spring packs. If your springs are OEM, it would still be easier for you to find someone with a large arbor press to remove/install the new bushings rather than burn and beat the old ones out (and beat the new ones in.) -
Agreed, and to elaborate on the response before the one from Pete, I will say, from personal experience, that a cracked head or head gasket won't manifest itself as water the the tailpipe. The pressures from the combustion process will drive exhaust gases INTO the cooling system, not the other way around. My first clue to a cracked head (yes, one from a 2000XJ with the infamous "0331" head casting) was funny looking oil. The exhaust looked perfectly normal.
Rotors and Pads recommendations
AZJeff replied to NC Tom's topic in MJ Tech: Modification and Repairs
If I was buying the stuff, I would go with Wagner pads from Rock Auto (semi-metallic) for $25. For rotors, don't bother with cross drilled and slotted stuff for a small 4WD truck. Unless you drive like you are on the Baja, you won't get them hot enough to notice any benefit. Again, from Rock Auto, Raybestos can be had for $29 each, but there are other comparable brands (Centric, Bendix, etc.) for similar prices. I would stay away from auto parts stores "house" brands like Autozone's Duralast stuff. They tend to be mediocre quality at premium prices.
