AZJeff
Everything posted by AZJeff
Punctuation would make this easier to read/understand. Let's start with what the manifold leaks can do: 1. leaks on the intake ports will confuse the MAP sensor, and that will mess up mixture. 2. leaks on the exhaust ports will cause the cat. converter to get erroneous combustion mixture, and send erroneous information to the PCM. The manifold gasket design on the 4.0 is prone to leakage. I recommend you spend the money on a "Remflex" gasket, as it compensates for the issues the OEM design fails to do. There are three bolts that are used on the 4.0 that hold ONLY the exhaust manifold. There is one at each end of the head, and one in the center at the top near the throttle body. ALL the other bolts due a shared job of holding both the intake and the exhaust manifold onto the head, using special conical washers. This means you can remove all of those bolts and take off the intake by itself, and then focus on removing the three exh. manifold bolts separately. This is important because the frontmost and rearmost of the manifold bolts can be tough to get out. (They are actually nuts on studs, BTW.) To address these, you will want toSOAK those two nuts with a bunch of penetrating oil before you try to remove them. PRO TIP: I find trying to line up the bolts with the conical washers on them when reinstalling the intake manifold to be a HUGE exercise in frustration. I replaced all those bolts with studs and nuts (and reused the conical washers.) A helper to align the manifold when installing them make the job easier, so offer your buddies some pizza when it comes time to put it back together.
I doubt that spring was ever available as a replacement part unto itself. You can probably create a functional replacement from some stock spring purchased at a decent hardware store. You might have to cut it to length and bend the ends to make the appropriate "tails" on the spring.
The FSM vacuum diagram should work out OK. One thing you can do is to blow into one end of a given vacuum hose, and have a helper see if the other end sees an output. Of course, one needs to know the names/locations of the various items connected via vacuum to verify that some previous owner didn't make mistakes reconnecting stuff. That might be worth a check.
Carbon fouling is an indicator poor combustion. With the misfires you are seeing, that might be a contributor. However, it takes more than just good plugs to make a good ignition. When you say "I have a plug tester so that's all good", does that mean that the light in the plug tester shows consistent spark on each plug? Rough idle is caused by inconsistent combustion, and that can be caused by a bunch of stuff, but ignition is the first place I always look. I also talked about vacuum leaks in my other message. Do you have a vacuum gauge?
Back brake skids...
AZJeff replied to speeding_infraction's topic in MJ Tech: Modification and Repairs
The fact that the skldding issue returned after being gone immediately after installing new wheel cylinders makes me wonder if the drums were adjusted correctly once the new wheel cylinders were installed. In addition, are the self-adjusting mechanisms properly installed and functioning as expected? (A lot of guy crab about the self adjusters being a POS, but we old guys lived with those devices for decades, and learned to keep them clean. Also, the self adjuster only really works when the brakes are applied going BACKWARDS.) -
Now that you have removed the faulting fuel injectors from the equation, the only other possible reasons for rough running would be something like a large vacuum leak or (more likely) something amiss in the ignition system. The ignition system should be pretty easy to diagnose. Here is what I would do: 1. pull all the spark plugs and examine for proper gap and no cracking of the insulator anywhere on the plug. Regap/replace as needed. 2. pull the distr. cap and inspect rotor and inside of cap for carbon tracking that will cause misfires. Replace as needed. 3. reinstall plug wires onto cap and do a "nighttime spark arc" test. This is done by placing the vehicle in a location where it is DARK (nighttime works well for this.) With the engine running, observe closely all the spark plug wires for any arcing between the wires and any grounds (or adjacent wires). The will be easy to see in a pitch black environment 4. A more definitive test than the nighttime spark arc test is to get a spark plug tester in the link below to observe spark when running for each cylinder. https://www.amazon.com/Ram-Pro-Engine-Ignition-Tester-Fool-Proof/dp/B01HU2L1NU/ref=asc_df_B01HU2L1NU?tag=bngsmtphsnus-20&linkCode=df0&hvadid=80882941400092&hvnetw=s&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=&hvtargid=pla-4584482468120795&psc=1
Instantaneous loss of almost all power boost on the steering is usually traced to either low fluid, or an obstruction in the hydraulic lines. It is EXTREMELY rare to have the steering gear proper go from providing normal boost to no boost in very short order. Is the fluid CLEAN? Maybe you can start by trying to flush the system.
Virtually all the bolts that go into the engine block of the 2.5 or 4.0 are going to be SAE thread, because the engine was designed LONG before the push to metric hardware that started in the 1980's. That's a good little tip to remember when you start searching for wrenches or replacement bolts.
Sway bar end link too close to coil spring
AZJeff replied to Duncan Moody's topic in MJ Tech: Modification and Repairs
The sway bar proper supposed to have it's end (where the round hole for the sway bar link is located) positioned so it is parallel to the ground when the Jeep is at normal ride height. As one begins putting lift on the vehicle, and increases the ride height, it begins to pull the end of the sway bar downwards. The fix for that, of course, are extended sway bar links. HOWEVER....as the lift above normal ride height becomes more significant (and 4 inches is pretty significant), just adding longer links won't keep the sway bar from interfering with the spring. The fix for that is to reposition the sway bar mount where it attaches to the chassis further down and further FORWARD. Your Jeep has brackets that reposition the bar further down on the chassis, but they need to have an offset to reposition the bar mounting locations so the bar is moved forward slightly as well. One last thing you might want to check before you dive into relocating the sway bar on the chassis and/or putting on longer sway bar end links: Is your caster set up correctly, and is your wheelbase correct per factory specifications? I ask this because the photos show you having adjustable control arms on the vehicle, and all of that can be fiddled with to create the proper caster and wheelbase when they are installed. And likewise, if they are not adjusted properly when they are installed, they can create all sorts of incorrect dimensions an angles that can make getting the sway bar to line up and function correctly almost impossible. I say all of this because I went through your pain on my MJ a few years back trying to straighten out what a previous owner had done (or not done.) -
The standard test for a vacuum operated brake booster to verify functionality is this: 1. with engine OFF, pump brake pedal repeatedly until the pedal feels solid 2. while HOLDING pedal down, start the engine. 3. as the engine begins to run and generate vacuum, the brake pedal should "sink" further with existing foot pressure If it does NOT do this, the booster is defective (assuming the hose from the booster to the manifold is connected and not cracked).
If the pulley on the compressor is moving, it is probably due to a worn out bearing in the compressor clutch hub. This can be confirmed by removing the belt, and turning the compressor pulley by hand. It should spring smoothly/freely, with no noise. If it is determined to be bad, a replacement bearing can be had from Rock Auto pretty reasonably.
That looks like one of those fancy Iridium or Platinum tipped plugs. The 4.0 doesn't benefit from them in the slightest, and may actually run worse, since they lack the extremely high voltages needed to jump that type of gap reliably. Put in some good old fashioned conventional plugs (Champions were OEM.)
No, it’s not supposed to touch. I don’t have the routing diagram so I can post it from my iPad, but someone can chime in with it, I am sure. if you do not have AC, do you have the AC delete pulley installed?
Belt squeak - harmonic balancer?
AZJeff replied to CO MJ's topic in MJ Tech: Modification and Repairs
Who is your helper, there, Cruiser? And did she find the issue using that stethoscope? -
It’s hard to tell from your photo, but I think I see cracks in the rubber. That would suggest a new balancer is in order -
A/C Receiver Drier to Expansion Valve hose
AZJeff replied to ktmall07's topic in MJ Tech: Modification and Repairs
This is the best solution -
If you do NOT replace them, the condenser will flop around on it's top end. The will eventually lead to a condenser with cracks, and that will cause all the refrigerant to leak out. The rubber mounts are available new, so bite the bullet and get a new set.
Power windows not getting power
AZJeff replied to Warren99's topic in MJ Tech: Modification and Repairs
So I have the 1990 FSM in digital format. How can we go about adding that to the downloads section mentioned above? -
Do I have the wrong coil springs?
AZJeff replied to Eagle_SX4's topic in MJ Tech: Modification and Repairs
I agree that the yoke of the “C” looks splayed, with the upper branch of the “C” looks bent upwards. That might also imply the entire “C” is bent inward at the top. I will try to photograph one of my axle ends when I get home and post it. -
A question for those who are reporting various electrical issues on MJ’s that usually start with a questions such as “what does this blue wire coming from the fuse box do?” ”what color wire powers my backup lights?” I have the electronic versions of the wiring diagrams for several of the MJ/XJ series, and find them invaluable for answering questions as this. I have had them for years, so I don’t remember where I got them. Are these available in a digital format from an non-copyrighted source that CC members can access? -
Like almost all hydraulic valve lift equipped engines, the 4.0 does not have any way to adjust the valve lash. The lifters are supposed to accommodate that, assuming all valve train parts are of OEM spec. The only time you see any sort of adjustable valve lash system on a 4.0 is when people install aftermarket camshafts and rocker arms with other than standard lift ratios. One way to confirm if it's truly a valve train noise is to remove the valve cover and start the engine, and then try to use an automotive stethoscope to listen to each rocker arm at it's pivot fulcrum to pinpoint the noise. (Taking the cover off also lets you inspect the valve train for any abnormal stuff at the same time.)
2wd steering linkage for 88 comanche
AZJeff replied to Blazer25l0's topic in MJ Tech: Modification and Repairs
All the steering linkage from a 2WD is the same as 4WD. Also, XJ linkage parts are interchangeable with MJ pieces. -
BTW, the perimeter of the evaporator and heater core need to be surrounded with some sort of foam or similar material when they are installed into the heater box. If they are not surrounded, they will rattle around making noise, and air will leak around the heater core or evaporator, lessening their performance. Finding OEM foam is pretty close to impossible, so I recommend buying foam from a hardware supply place and cutting it to fit the spaces. the foam can be attached to the heater core or the evaporator with contact cement.
The fast-turn thread that goes in to the holes in the heater box is pretty easy to strip out when being reinstalled. If that happens, the best thing to do is to epoxy the screw into the stripped hole, and let it cure before trying to thread a nut on the other end. The nut is NOT attached with Loctite or anything similar. The integral washer on that nut is coated with a sealant on the surface that mates against the firewall. The sealant is designed to keep water from entering the cab through the mounting holes in the firewall. If the threads are coated in this stuff, they can be cleaned with a solvent (as can the nuts). A bit of clear RTV can be placed around the hole before the nut is tightened and that can provide the water sealing action that is needed. The thermostatic tube that is part of your older-style expansion valve should be placed in the center of the evaporator, between the fins. IT needs to sense the temperature of the evaporator in it's coldest area, so it can control refrigerant flow properly.
