13
Well, @Pirate_Stazand I finally met up today. Picked up some Jeep parts and talked Jeeps for a bit till we had stuff to go do. Was a fun filled day!
This is actually and '88. JT in the VIN denotes that. Theres also and extra "1" in your VIN *X2 -SA Charcoal AGC Black Ram 1500 Sport Group APA MONOTONE PAINT PACKAGE BCQ Battery - 750 Amp Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGW Air Bags - Front, Next Generation** CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CLE ACCESSORY FLOOR MAT - FRONT &&&&&&&& REAR CUF FULL LENGTH FRONT CONSOLE DDQ Transmission - 5-Speed Manual ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT JAY Instrument Cluster w/Tach JGB Clock - Digital JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL KD8 DELETE TAPE STRIPE COLOR SEPARATION LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NHQ Transmission Heater PB3 MEDIUM BLUE PRIMARY COLOR - GB3 QB3 Intense Blue Pearl Coat RAB Radio - AM/FM SBA POWER STEERING TBG SPARE TIRE - COMPACT WJN 15" Aluminum Wheels XEA TOW HOOKS Build sheet Build date is 3/24/88 Body code:JL61- 4WD Low price line, short bed.
Renix Cruise Control
eaglescout526 replied to eaglescout526's topic in MJ Tech: Modification and Repairs
I’ll have to get in contact with him. You would think more of that tester would be around as it seems Dana was the leader in cruise control tech back in the day. -
I need to get a vacuum tester and gauge, but as far as I know everything works. I have done light tests and volt tests at all electrical connections to see what does what. -
I've seen enough X-files to know they are hiding something. Should people storm Area 51? Sure why the hell not? Natural selection. Plus we could truly find out if Nellis is really hiding anything or not. I do recall on the long road as you travel through Nevada a random chain link fence closing off access to a canyon. Why that is there? I don't know.
That honestly sounds like an aftermarket kit. I think I'm gonna bet I need a new regulator. -
Its an electro-vacuum set up. So far I'm at a loss. The original regulator blew a resistor. The new one just won't do a damn thing. Everything seems to be in working order but I can not tell for certain. It all worked prior to tearing out the dash to install AC. But that is it. I haven't disturbed the set up and all I did was unplug the servo from the vacuum line and unmount it to move it out of the way for the moment. The only thing I found on the dash side was the ground cable that Cruiser recommends to do was torn away from the mounting stud. That has since been repaired. -
Oh, yes that makes more sense. -
(two hours ago)Well damn...I blew something on the regulator. Plugged in the old regulator after doing some adjustments and poof a plume of smoke. Did some tracing on the board to the wiring after I got home and found it is the white wire that leads to the servo. Servo bad? I don't know. All I know is that it has Ohm resistance that is less than infinite according to the FSM. -
Yup. I keep testing them with the pots in different positions. H.O. Won’t work with Renix sadly. H.O. Computer has cruise built in so it’s plug and play. Renix cruise isn’t a PITA, well installing it is but once it’s in there and some fine adjustments it’s awesome to have. I’ve just never heard or have cruise just lay down and die until now. -
I’ve tested both factory and aftermarket switch. I’m gonna look into my vacuum harness on the engine side tomorrow. I put hell of a battle up today just electrically. Seems like everything functions as it should. Don’t know if the regulators(computers) do. -
I smell an excellent ruse.
Reproduction Comanche Emblems
eaglescout526 replied to carolinajeepman's topic in Vendors- members making products for MJs
Nice!!! Is there any chance we will see them wrapped in chrome then painted like from the factory? Also glow in the dark is a really neat touch! -
It has almost gotten to the point where you will have to rebuild your old winch or use the brackets and adapt one of the “big three’s” winches to the MJ bracket. I did that.
Has anyone ever had cruise control just stop working? I go to engage it one day as I was driving home and I smelt an electrical burning smell. I have replaced everything(including wiring harness) with a spare set I had. I did get it to engage for maybe a minute with the old regulator but now nothing. I have done the FSM adjustment and it engages for a second and it stops operating. I have vacuum where I need it to be and I am getting vacuum from the cannister. Anyone just run into this and be baffled by why it won't engage? Does anyone have the dealer tool? AM PC-1-R?
Clutch problems
eaglescout526 replied to Wallace Krempa's topic in MJ Tech: Modification and Repairs
If it’s the original master cylinder and if it’s in good shape on the inside you can rebuild it. But the cylinder can’t be pitted or else the rebuild is nulled with the same leak. -
I may have a really messed up drivers side that I can give ya.
94 ugly cherokee
eaglescout526 replied to MJXJjeepguy's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
To quote R Lee Ermey from FMJ. “What is that?!” -
NOS Tail Gate
eaglescout526 replied to Ls2xjcomanche's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Damn he’s quick. -
NOS Tail Gate
Damn. I’d get that if I could. -
Fuel pump and sending unit
eaglescout526 replied to CarterD's topic in MJ Tech: Modification and Repairs
Guess we wait till Friday and see. If it works out then all we need is someone to make taillights.(nobody drag anything about those in this post!) -
Holy Crap! We could get a source of new sending units! -
Probably the type of clear coat to make the silver darker
*W7 Cloth Lo-Back Bckt/Red Accent Seats -H9 3LZ ADA LIGHT PACKAGE ADL SKID PLATE GROUP AGL PLYMOUTH SPRING SPECIAL PACKAGE AHY Hybrid Electric Vehicle 15 KW Group APB TWO TONE PAINT PACKAGE - I APP TWO TONE PAINT PACKAGE AWE UP COUNTRY SUSPENSION GROUP BCQ Battery - 750 Amp Maintenance Free CAC BUCKET SEAT - LO BK CGW Air Bags - Front, Next Generation** CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DGQ TRANSMISSION-5SPD AUTOMATIC 5-45RFE DMR 3.42 Axle Ratio ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LDA UNDERHOOD COMPT LAMP LMA HALOGEN HEADLAMPS LNJ Fog Lamps LPE EXTERIOR CARGO LIGHT MBF REAR BUMPER - STEP TYPE (BRIGHT) MCA FRONT BUMPER GUARDS MCB REAR BUMPER GUARDS MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I MWF BOX SIDE RAILS NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 20 GAL FUEL NHB HVY DTY/AUX TRANS OIL COOLER NHM AUTO SPEED CONTROL NMB ENGINE COOLING - STANDARD DUTY PXJ Diamond Black Crystal Pearl Coat QA2 SILVER MET CLR CT SECONDARY PAINT - FA2 RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE TBL TIRE CARRIER - INSIDE WJD WHEELS - 15 X 7.0 STYLED STEEL XEA TOW BELTS Wow. Well optioned! Build Date: 1/28/87 Body Code: JP62 Course there are some things on this build sheet that are wrong
