13
Is it common for MJ owners to not make the best of choices when getting MJ specific parts? I'm starting to think so. Anyways this bumper is mostly intact with light surface rust. Only the support failed and so I will fabricate something new out of the old bumper that was on my truck. Took a few days but I cut all the welds loose. Now to make the bumper straight and rust free.
- 657 replies
- 2.5litre hurricane
- pioneer
(and 2 more)
Tagged with:
Sounds good! Let me know what you come up with.
I know I'm asking for some rare stuff but you guys usually pull through with leads or info. Anyways I'm looking for the OEM rear bumper end caps. Preferably just a right side end cap and the hard ware. Not sure what I'm gonna do about the hard ware yet but I have an idea. Let me know if you have anything.
OEM Renix stuff too are getting hard to come by.
I know nothing on those MJ's but I have the same ad. Makes me kinda want to switch to Pennzoil but I got it because weather its MJ history or a work of art, it is MJ memorabilia.
Got a factory MJ bumper!!! Havent torn into the package yet but the underside is rusted. I have a spare bumper out back I will use to repair the rust.
- 657 replies
- pioneer
(and 2 more)
Tagged with:
MJ won’t start. Need help.
eaglescout526 replied to Raven's topic in MJ Tech: Modification and Repairs
I strongly recommend running through some of the tests here. We boiled it down to his injector being toast but yet still Ωhms out good. Despite being an 86, 87-90 are very much similar other than the Wide Open Throttle switch moving to the P/S pressure switch. -
Team Cherokee timely response?
eaglescout526 replied to 87MJJeep's topic in MJ Tech: Modification and Repairs
My 2 cents. I have gotten everything I exactly order from them. Yes shipping sucks for the $12 you pay. I remember I wanted to return a grill I bought form them as it was an HO grill and I never got any email back with a shipping label to return the product. But otherwise id give them a 3 and a half stars. -
Weird, hate it when you find loose or suddenly missing bolts or connections. What baffles me more is I probably had just tested four headlamp delay modules about a week prior to today too.
- 657 replies
- pioneer
(and 2 more)
Tagged with:
Well had no headlamps on the way home. Tore everything apart and tested everything for power. Took out the headlight switch and found a nice pristine non melted plug on the other side of the switch(was very surprised). Swapped it with a Mopar switch, no dice. Put the headlamp relay harness back together, still nothing. Decided for the hell of it to clean the ground bolts for the harness and then viola the headlamps are back in business. Don't know why that was a deciding factor for them not to work as I never cleaned the ground bolts to begin with. here's the best acrobatics pic I could get of the plug
- 657 replies
- pioneer
(and 2 more)
Tagged with:
He did away with the printed circuit and wired everything directly. Kinda impressive actually.
Actually, I just recently learned that CC can host short MP4 files in PMs. Havent tried it with an actual post yet.
I found a piece of mine under the vents in front of the center console.
Chunk, A 1984 XJ
eaglescout526 replied to eaglescout526's topic in Member Projects: Other Cool Stuff
Actually yes! I will be up there June 11-20th. So I will actually be able to do things and get y’all pics. -
I know the owners manual calls for power steering fluid for power steering but I’m curious as to what some of you may be running in yours. The T-bird says to use ATF for its power steering but I’m curious if anyone runs ATF in their MJ.
Holy moly does my truck ride better now. Wish my past self put the shackle in right. I got the XJ bushing in on the drivers side shackle. Now to do the ZJ gear box as mine is just tired and done with steering. Hopefully I’ll get that back from being rebuilt and I’ll do that swap and should be good to go and should cure the last of the vibrations.
- 657 replies
- pioneer
(and 2 more)
Tagged with:
