13
Project: Cruise, a 1960 T-bird.
eaglescout526 replied to eaglescout526's topic in Member Projects: Other Cool Stuff
So aside from the whole oil thing, I will put some ATF down the cylinders. I am tearing down the carb right now and am discovering it has never been rebuilt and a lot of it is just gummed up and not rusted thank goodness. -
Want the long story or the short story? He is fixated on WD40 being the cure-all to rust. -
Ill have to get some but I also thought about ATF too. But I gotta get my grandfather to hush and let me put some stuff down there. -
Right now the engine has almost a whole can of WD40 in the cylinders. Ill tell a bit of history. Yep, seems like the PO got a rebuild kit from a ford dealership(still operating) here back in 2002. So the PO was set on rebuilding the carb as they replaced the points, cap and rotor thinking it was an ignition issue. Seems to be more on the bad head gasket side. Radiator was full of the same brown crap I found in my MJ. Which isn't a good thing, but who knows. PO has new belts and hoses so hopefully I'm not diving into something bad here. History-It was in my friends family since new. His moms boyfriend, his grandfather had it since new. It got passed on to his dad, his dad passed away a year and a half ago at 71 and got passed on to the boyfriend. So neat to learn it hasn't been anywhere bad. They did have plans to keep it and do stuff with it but they didn't have the place, nor time or money to do much to it. So I'm thinking this motor needs a good soak and it should either move with a big bar or bump the starter to help it. -
Yeah....hoping this won’t be too much of a problem. Obviously needs to be rebuilt but here’s hoping that soaking the motor will turn up something good than a stuck motor. -
Should indeed help. Much appreciated!
Wish I took a pic of the NOS harness I got a year ago. But Blaines drawing is pretty accurate on how it goes. Worse comes to worse, I planned on making these hard lines. Depending on how many of the vac cannisters are around, ill probably make a harness that allows another reservoir to go up by the blower motor. Thanks @Blaine.D!
Do you mean like the MS-1700 scanner or the REM tool?
Oh I'm not in search of a set up for myself, I'm more gathering parts from those who aren't going to add cruise and make complete kits for guys who want to add. Shoot me a PM if you want to part with it.
Yup that's the plan. As far as everything else, nothing is really rusty. Just aged and greasy. Trans linkage is loose but that can be fixed when the car runs and drives. -
Lol you might be right on that. But theres not a lot of rust on the linkage so I'm not sure what gives? Unless the internals are gummed up from fuel sitting in the bowl. -
So a little bit about the car, everything the owner has circled in the manual is correct. It is a 352Ci with a cruise o matic with a ford 9in with 3.10-1 gear ratio. Tomorrow afternoon I will be going to the car to do a little work and see if the internal will move with no issue. Then see why the carb linkage doesn't want to move. Gonna have to buy some WD-40. -
Sending you a PM.
87 2.5L ISA and Idle issues
eaglescout526 replied to billyjp2's topic in MJ Tech: Modification and Repairs
Meant tach, autocorrection from being on the phone. Once you get the tach I can tell you which pins on the diagnostic port the tach goes to. -
Alrighty. I’m out and about at the moment but here’s a quick summary of it. You need to connect a tach to two pins on the diag port D2, don’t remember which right now and with the ISA disconnected the idle will be high and loud. You screw the bolt counter clockwise or clockwise until the tach reads 3500 RPM -
I gotta think on this one. Have you ever seen any of the ISA's move? Edit: there is an ISA adjustment procedure that has to be done when installing a new ISA. How far out is the bolt on the ISA plunger? -
So the car has been moved. It now resides at my grandparents house. Kinda excited for this project. Thank goodness the PO loved this car because there is all sorts of literature and restoration places that exist. Hell even one of the restoration shops is here locally and stocks a lot of 50-60's ford part and even has some remanufactured. So this will be a fun one. -
'86 MJ 2.5L ECM....good?
eaglescout526 replied to SoCalManche's topic in MJ Tech: Modification and Repairs
Sounds good! -
That's a better idea, shoot even if someone had a 90's GM injector you could use it. -
I think cleaning the injector would be the first best route for all this. -
Well it just boils down to which one is truly bad, the injector or the ECU. I am thinking the injector, it is cheaper of the two parts but what bothers me is it isn't Ωhmed out. But it could also be dirty. I think we have hit that fork in the road now where all the tests that can be done have been done and voltage has been repaired where voltage is needed. -
Lol. Like I said, all it does is spark when I ground it out. But I didn't try the other orientation as that shouldn't matter.
